Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 12, 2019 at 9:45 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Just to be clear you guys should be using ECT when you are towing
  2. Apr 12, 2019 at 9:46 AM
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    Is that being stock and/or tuned?
  3. Apr 12, 2019 at 9:48 AM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Yes, 1.05 93 performance
    It seemed to go away for a while with the tune and is back with a vengeance. I’m going to clear learning tonight and see what happens. I have an apt with the dealership Monday am just in case. Fearing low fluid.
  4. Apr 12, 2019 at 9:50 AM
    Shellshock
    Iowa
    both
    Inferno__Taco and BOMBS[QUOTED] like this.
  5. Apr 12, 2019 at 9:53 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Verify correct ATF level is a good place to start.
    Shellshock likes this.
  6. Apr 12, 2019 at 9:58 AM
    BOMBS
    Good to know.
  7. Apr 12, 2019 at 9:59 AM
    Shellshock
    Iowa
    low ATF makes a huge difference in these trucks, even a fraction of a quart. this needs to be where people start, not a last resort...
    uploadadventure and tonered like this.
  8. Apr 12, 2019 at 10:00 AM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    I’ll have it verified
    Potential damage due to a few hours on the road in the meantime?
  9. Apr 12, 2019 at 10:06 AM
    Shellshock
    Iowa
    unlikely unless it was super low. I ran my 2016 for about 20k before it was filled to spec and it didn't have issues after. it ran way better.
  10. Apr 12, 2019 at 10:28 AM
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    @OVTune Hey Mat, I know you were working on a fix for trucks with high misfire count. Have you come up with a fix for that? I heard it may be worked into the “shutter fix” update. Is that right?
  11. Apr 12, 2019 at 10:50 AM
    OVTune
    OVTune
    yes that's this weekend.
    Yes it's the 5.7L 3UR which has been added to the OVTune stable
  12. Apr 12, 2019 at 10:54 AM
    Frito
    Frito Well-Known Member
    And as an added bonus, for me at least...
    SSP overrides Gear Lock !
    So you get the both of best worlds !
    I really don't see me using Gear Lock unless I'm towing which isn't all that often and I was hesitant to give up SSP for everyday driving with ECT.
    This is a great bonus to me !
    treimche and Taco16LB like this.
  13. Apr 12, 2019 at 11:01 AM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    Feeling stupid, what is SSP?
  14. Apr 12, 2019 at 11:07 AM
    Frito
    No, no. No problem.
    SSP= "Shift Sense Pro"....
    (love it or hate it)
    It stretches out your shift points.
    I'm on the road or I'd give you a link. Easy to find here or in the web.
  15. Apr 12, 2019 at 11:08 AM
    OVTune
    OVTune
    Also, regarding radar cruise tuning. We are just waiting for the 2020s to be released to pick one up and make adjustments for radar cruise. it is on the list.
    Since it was only 2 files (93 per / 93 GL) that needed a small tweak, and there aren't too many 19's using it, we figured it would be less confusing to new people to just rebuild the same file with the slight tweak.
  16. Apr 12, 2019 at 11:14 AM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    No worries, I’ve heard about it. Just had a brain-dead moment!
    Thanks!
  17. Apr 12, 2019 at 11:50 AM
    Frito
    :thumbsup:
  18. Apr 12, 2019 at 12:15 PM
    wiljayhi
    Jim
    3G, Tuned
    Anyone interested in how my 2018 OR 6AT with 87 gearlock tune performed for my towing application?
    I took my camper for a shakedown cruise and used my ScangaugeII to keep an eye on what was happening with TC and pan transmission temps.
    I towed the camper from storage to a local CAT scale to be weighed. I used gearlock driving through the city, stop and go for about 45 minutes, highest speed attained was around 68kph (40mph). Lots of normal shifting up and down and what seemed to be adequate power and torque for each appropriate gear. When the TC temp hit 200F the first time, it appeared that the transmission cooler came on line. The pan temp dropped from 190F to 185F and held at 185F until I got to the scale. The TC temp went up and down, the highest being 205F and the lowest 190F.
    The truck was loaded for camping and scaled at 5360#, 340# of that was tongue weight. Trailer weighed in at 2980#. Combined weight, 8340#. (Still have room for the wife and some other "stuff").
    The next leg was a 120 mile roundabout highway trip to take the trailer back to storage. Using gearlock, I made my speed 95kph (about 57 mph), 2500 rpm in 4th gear and remained in 4th for most of trip. It was all flatland towing, at times against a headwind and a few minor inclines and overpasses. It was never necessary to unlock the TC in 4th gear for more RPM (nor to downshift) either against the wind or going up an overpass. After a few miles I found that both the TC temp and the pan temp achieved and maintained the same temp at 188F. This appeared to indicate that after the TC had locked up in 4th gear it was not necessary for the trans cooler to come online. The air temperature was 5C (about 40F) so I'll have to check again when towing after the weather warms up.
    I did try using 5th gear with the trailer attached, but found that it would not hold speed against a headwind and required the TC to unlock too often to gain speed back. I do suspect it would tow in 5th with a tail wind though. Have to try that later. Keeping the TC locked appears to be the best bet to keep the trans temp normal.
    Bottom line for my situation is that the 1.05 87 perf gearlock tune appears to meet my needs for towing. I'm quite satisfied with 87 octane and not going to the higher octane tunes because of the cost of the fuel here made all the worse after the @#$&* carbon tax was added.
    chittyrox, Inferno!, Frito and 3 others like this.
  19. Apr 12, 2019 at 12:20 PM
    OVTune
    OVTune
    Thank you for your review.
    If you were monitoring mpg at the time, do you mind sharing your towing mpg?
  20. Apr 12, 2019 at 12:34 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Fingers crossed for Tacoma + Tundra tune combo pack...
    (j/k, but looking forward to get the dongle in action on the tundra now too)
Thread Status:
