Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 12, 2019 at 6:14 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Huh. All this time I thought it was normal driveline vibrations from my lift.
  2. Apr 12, 2019 at 6:20 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    If increasing the rpm doesn’t make it go away perhaps you have a driveline issue as well.
  3. Apr 12, 2019 at 6:29 PM
    Frito
    Frito Well-Known Member
    Hey, someone point me in the direction for procedure to delete the Gear Lock tune once you have it downloaded to the truck ?
    Probably staring me right in the face.....
  4. Apr 12, 2019 at 6:33 PM
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    I experience the same thing getting on the highway from work, its an incline and the transmission dances nonstop 5,6,5,6, lock, unlock. Sometimes it pisses me off so bad that i just switch to S5. I run 91 Base with 4.88 gears and 33" wheels. Going uphill to work it has a tendency to stick to 5th and doesnt accelerate when i press the pedal then it shifts down to 3rd and redlines that bitch. I started pushing the ECT button when getting to that hill and it fixes it .
  5. Apr 12, 2019 at 6:38 PM
    Frito
    That's a suck..... Which version of the tune are you running ?
  6. Apr 12, 2019 at 6:42 PM
    wiljayhi
    Jim
    3G, Tuned
    If you don’t want the gear lock tune on your truck, just flash a different 1.05 tune or flash the stock tune.
    If you want to delete the tune file from your computer, click on the file, press “delete”.
    Shellshock likes this.
  7. Apr 12, 2019 at 6:43 PM
    Kclamer
    Konstantin
    1.05 Base 91 Octane version. I have about 3k miles on this tune and really like it, just a few quirks that I found a way to deal with. Waiting on that 4.88 gear update which is coming sooooon....
  8. Apr 12, 2019 at 6:44 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I think your 5/6 is more current shift points and your setup which is making it happen, not the shutter issue which is in every gear
  9. Apr 12, 2019 at 6:47 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Agree, I would be satisfied as well.
    I saw the post that pesky misfires are being taken care also. I think my truck is like my passed away grandma,sensitive to the weather. One day I get over 15 misfires, other - zero. Go figure.
    Other than that, I'm enjoying the 87 base all around. Had 4 full tanks, drove 1588 miles, average mpg 21.1(my rough estimation is 50% city/50 highway)
    But.....
    Last year for the same period of time my MPG was better by 0.5 on stock tune.
  10. Apr 12, 2019 at 6:51 PM
    Frito
    Thanks for the comeback..... So by flashing the truck from Base to Performance or vis a vis it will delete Gear Lock ?
    I thought Gear Lock is a separate tune and download itself ?
  11. Apr 12, 2019 at 6:55 PM
    Shellshock
    Iowa
    It’s a separate tune.
  12. Apr 12, 2019 at 6:59 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Wtf, how are you guys nuking this?
    -Base
    -Performance
    -Performance Gear Lock
    Choose one and enjoy. Not rocket science
  13. Apr 12, 2019 at 6:59 PM
    Frito
    So, to delete just Gear Lock I do what..... ?
  14. Apr 12, 2019 at 7:00 PM
    Shellshock
    Iowa
    Flash a new tune that’s not a gearlock tune
    xxTacocaTxx, wiljayhi and mZiggy like this.
  15. Apr 12, 2019 at 7:00 PM
    Frito
    No Gear Lock for Base ?
  16. Apr 12, 2019 at 7:00 PM
    OriginalMan
    Oahu 808
    2017 TRD OR 4x4
    I'm done.
  17. Apr 12, 2019 at 7:00 PM
    Frito
    :thumbsup:
  18. Apr 12, 2019 at 7:01 PM
    Frito
    Thanks for checking in.....
    Mike O likes this.
  19. Apr 12, 2019 at 7:07 PM
    wiljayhi
    Jim
    3G, Tuned
    Gear lock is a selectable option that attaches to performance tunes only. If you did not select Gearlock when you downloaded your tune file on Flash Manager then you don’t have it flashed to your truck so no need to delete anything.
  20. Apr 12, 2019 at 7:20 PM
    wiljayhi
    Jim
    3G, Tuned
    Correct.
Thread Status:
