Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 18, 2019 at 6:12 AM
    TRDOBSESSED
    TRDOBSESSED Well-Known Member
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
    I'd like to know too ...i run that combo and its pretty ferocious :wink:
  2. Apr 18, 2019 at 6:17 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    87 perf + ECT is the only way I run the truck
    TRDOBSESSED likes this.
  3. Apr 18, 2019 at 6:39 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I run the SSP - sometimes I use it and sometimes I don't. Have not flashed GL yet - holding out for the 4.88 tune to see if it adjusts shifting. Usually use the s-mode and simply lock it down to nothing higher than 4, or engage SSP and let it shift at higher rpm. Either work but I sure wish 2>3, 3>4 and 4>5 shift points were 250-400 rpm higher in D mode. Still have to say the Tune is 1000 times better than stock!
    honey, go2cnavy and Deucer01[QUOTED] like this.
  4. Apr 18, 2019 at 6:53 AM
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    @OVTune Is the EROM 2.0 patch used for or with 1.05 Performance tune?
    su.b.rat likes this.
  5. Apr 18, 2019 at 6:56 AM
    jarrasp
    jarrasp Member
    17 special edition tacoma
    any other user with ECU ID "" 04B23-AT "" 2017 or 2016???
  6. Apr 18, 2019 at 7:08 AM
    Pruby18
    Pruby18 Well-Known Member
    2019 DCSB OR 4X4
    Who has gotten better mpg with 87 performance from stock? I’m all stock tires, no lift and I get 17-18 if I baby it. About two tanks through it, 80% highway.
  7. Apr 18, 2019 at 7:25 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    I get 20-21 on my daily commutes, 65-70 mph, 90% hi-way, no lift on 32s.
    Pruby18[QUOTED] likes this.
  8. Apr 18, 2019 at 7:38 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Interesting. Is that a Mexico build? I follow this thread closely and you are the first I've heard with that build.
  9. Apr 18, 2019 at 7:48 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Mats FB page noted:
    04B23 AT - 2016 S.A. Cal
    04B24 AT - 2017 S.A. Cal
    SC4333[QUOTED] likes this.
  10. Apr 18, 2019 at 8:06 AM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    For context, I have not taken the leap to OVT, stock Limited excluding custom exhaust (Magnaflow mufler, 3" cat to muffler, 2.5" muffler to tail), 90-95% city with a heavy foot. I have a lifetime average of 20 MPG.
    When I run highway (75-80 mph) that trip typically runs a LOWER MPG than city driving (40-55 mph). Note: my city driving is NOT stop & go, more industrial so typical speed is 50ish, in 17 miles there are normally only 4 -6 stops, each stop >3 min (Florida has geriatric stop lights). Commute time is normally about 20-25 minutes unless one of the stops is for a train, then all bets are off.
    Pruby18[QUOTED] and tacothyme like this.
  11. Apr 18, 2019 at 9:14 AM
    tacothyme
    tacothyme Well-Known Member
    Cory
    Seattle, WA
    18 DCLB OR
    265/70/17
    About to pull the trigger on OVT after following this thread for the last 2.3k pages. I've got a 2018 with none of the TSB's done and am wondering - is it recommended to get the TSB's done prior to OVT? I assume the answer is "no" but wanted to get some opinions.
    I understand a portion of the issues would be solved with the TSBs but if there's no difference once 1.05 is applied then I'd rather save my time and not go to the dealership...
  12. Apr 18, 2019 at 9:15 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    TSB is not required.
    Only time TSB is required is on 2016 trucks with very old CAL IDs that toyota updated multiple times.
    **however, if your truck experiences the exact issues the TSB does fix, it's recommended **
  13. Apr 18, 2019 at 9:16 AM
    Rus$
    Rus$ Well-Known Member
    Russ
    2018 Tacoma DCLB AT TRD Off Road
    No you don't need to. I got them done though so they didn't write over my tune sometime down the road. I don't go to the dealership anymore so its a moot point. They've screwed up my truck too many times so they don't touch it anymore.
  14. Apr 18, 2019 at 9:21 AM
    tacothyme
    Cory
    Seattle, WA
    18 DCLB OR
    265/70/17
    Awesome - thought this was the case. Thanks Mat.
    Good point.. I'll probably cover my bases and make the trip. Last thing I'd want is to go backwards with the dealership overwriting the OVT...
  15. Apr 18, 2019 at 9:29 AM
    OVTune
    OVTune
    If the dealer ever does, it is not an issue, you can just over-write it with a copy of the updated ECU IDs tune file
    So lets say you're ECU is 04A60. You tune it.
    You get an oil change, they update your ECU (unlikely since the dealerships seem so reluctant to) to 04A61.
    then just flash 04A61 tune
    taco 16, SC4333, Shellshock and 6 others like this.
  16. Apr 18, 2019 at 9:36 AM
    Pruby18
    2019 DCSB OR 4X4
    I definitely feel that anything over 65mph lowers your mpg below city driving.
    Shellshock likes this.
  17. Apr 18, 2019 at 9:49 AM
    Shellshock
    Iowa
    it sure does. i got lots of miles to prove it. anything over 65-70 and fuel economy falls off a cliff.
    go2cnavy, BlkTaco47 and 2001 4x4 like this.
  18. Apr 18, 2019 at 9:59 AM
    OVTune
    OVTune
    p5Flash Utility update will include 3 new features (with explanations)
    - Read Live RAM > This allows to dump live data while engine is running from the ECUs RAM, allows for us to quickly add our custom code to new ECU IDs.
    - Clear All Memory > Clears All stored memory on the ECU. (vehicle will run rough during relearning)
    - Clear Learned Values > Clears learned values back to default.
  19. Apr 18, 2019 at 10:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice!
    So that should eliminate any need to disconnect the battery?
  20. Apr 18, 2019 at 10:03 AM
    OVTune
    OVTune
    Correct.
    No disconnect battery, no need for techstream
Thread Status:
