Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Sep 10, 2017 at 6:27 PM
    #4301
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    I did, until I saw that its in all new vehicles. Plus my old taco didn't do it. Doubt toyota changed the flywheel design to be heavier for a weaker engine.
    Toytaco2k17 and MOC221_ like this.
  2. Sep 10, 2017 at 6:27 PM
    #4302
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Herniator[QUOTED] likes this.
  3. Sep 10, 2017 at 6:30 PM
    #4303
    Toytaco2k17
    Toytaco2k17 Well-Known Member
    Kenneth
    Chapmansboro Tn
    2016 Nissan Titan XD Pro4x Diesel
    Stock
    My FJ did it but not as bad as this truck.
  4. Sep 10, 2017 at 6:54 PM
    #4304
    Sean73T
    Sean73T Well-Known Member
    Sean
    SoCal
    17 Pro
    When I go to run pcmflash, it will identify, but it will not read the truck........Going to start going through the many pages of this thread for an answer, maybe those of you who are on your 20th time can chime in.
    Truck is in on, not running, and no issue of connection with the wires. Should the obdII unit be flashing like a light show?
  5. Sep 10, 2017 at 6:58 PM
    #4305
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Make sure any anti-virus, Spyware protection, or other monitoring software is disabled. My kit did not come with a USB cable and the first one I tried was flakey. Try another cable.
    If all else fails try the standard troubleshooting step of rebooting your computer and running as administrator(although it should not be necessary).
  6. Sep 10, 2017 at 7:07 PM
    #4306
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    I get your post, I really do. Been Running OV Tune since Just after the alpha...I think I was order #1859. The truck runs much smoother,poer comes on sooner than before. I completely agree in the fact that this truck should have been tuned like this from the factory. I'm running 285's a and on a Icon 3" lift with a catback an Afe intake an MRBP catback. But in the end, it's your truck and you choice.....
    I completely agree. My review on 1.02 mirrors yours with about 150 miles....
    It will get even better as it learns.....if you doubt making this truck
    drive like it should've from the start don't buy it.
    OvTune has already demonstrated his ability to mend toyotas inability to
    Finish what they chose not to.
    dYL0n, ajsabra[QUOTED] and lapoltba like this.
  7. Sep 10, 2017 at 7:11 PM
    #4307
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Not sure if they are incapable..I bet Toyota ECU programmers could have made this thing run like a bat out of hell if they wanted to. I think it comes down to what specifications/criteria they have to meet and make the truck drive To those standards . But, alas we have a savior amongst us, so no more frustration when driving!
  8. Sep 10, 2017 at 7:32 PM
    #4308
    lapoltba
    CT - 06076
    I imagine it was a time/budgetary constraint. The engineers probably said something like "yes, this engine is very similar to what we have used in our other vehicles and some of the ECU data can be transferred, but this engine is not identical and there will be some extra work that needs to be done." Big wigs/upper management/pencil pushers probably heard "The ECU software is close enough to what we have already developed for our other vehicles and we won't need to put much time or effort into it."
    This translates to there not being enough time allotted to developing the maps for this truck and the engineers scrambling to put something together that sort-of works. Maybe i'm wrong but as a controls engineer I've had this conversation more than once. Even though the machine I am supposed to be working on is "exactly the same" as seen by those not familiar with my job, there are inevitably differences that are non-trivial to consider and work around.
    rnicholls, hbaade and MESO[QUOTED] like this.
  9. Sep 10, 2017 at 7:39 PM
    #4309
    Sean73T
    Sean
    SoCal
    17 Pro
    Had to go home as it seems to only work on a buddies laptop.
    Could it be because it's a PRO and there's a slight chance of it being different? I know not likely.
  10. Sep 10, 2017 at 7:45 PM
    #4310
    lapoltba
    CT - 06076
    Pro or not should make no difference the ECU is the same. Win-Blows can be quirky. I don't have a good answer for you unfortunately. Were you able to get it to flash on your buddy's computer?
  11. Sep 10, 2017 at 7:57 PM
    #4311
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    email me your dongle serial number (pcmflash shows it when you run the software)
  12. Sep 10, 2017 at 7:58 PM
    #4312
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    :p
    hbaade, Boxerocks and ajsabra like this.
  13. Sep 10, 2017 at 8:01 PM
    #4313
    MESO
    State of Jefferson
    That doesn't mean dick pix folks
  14. Sep 10, 2017 at 8:50 PM
    #4314
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    Does anyone have a real time AFR/misfire/knock app for their phone? I have Torque pro but haven't played enough with it, curious if anyone has one they like.
  15. Sep 10, 2017 at 9:13 PM
    #4315
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    A heavier rotating mass is actually better at maintaining torque. I am personally planning to purchase a heavier flywheel for my truck to assist with low speed operation. URD has them on there website already. I believe the stock flywheel is 29 lbs. URD flywheel is close to 40 lbs if my memory serves me correctly.
    http://urdusa.com/store/Trans,-Clut...y-Flywheel,-2GR-FKS-3.5L-V6/product_info.html
    As for the rev hang there is an easy solution for that... Lift then shift.
  16. Sep 10, 2017 at 9:38 PM
    #4316
    ajsabra
    Sin city
    Lift and shift:rofl: Do whatever makes you happy, I do it right now, but if possible I would rather have it like manual transmissions have been for decades.
    Good to know on the heavier flywheel. I wont be purchasing one unless absolutely necessary. Which means if i ever get a supercharger, both clutch and flywheel are getting swapped out.
    RedBeard1[QUOTED] likes this.
  17. Sep 10, 2017 at 9:48 PM
    #4317
    RedBeard1
    Red
    I have always run heavy mass flywheels on my trucks. Makes trail driving, towing and working around the farm much easier.
    I agree with you that the rev hang is a useless slice of programming there only to make the tree huggers happy. However the lift and shift negates it.
    FinnJ and ajsabra[QUOTED] like this.
  18. Sep 10, 2017 at 10:38 PM
    #4318
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Trail driving towing around the farm? :rofl:
  19. Sep 11, 2017 at 3:45 AM
    #4319
    RedBeard1
    Red
    Unlike some around here I actually use my truck as a truck. There is typically barb wire and T-post in the bed. It regularly hauls cattle feed, mineral/salt blocks and lots of steel for my side business as a fabricator. I tow with it almost daily. Summer time it gets to haul our hay bailer, wheel rake and my car hauler with my 3000 ford tractor on it from the main frame to our lease property. It has my welding trailer tied to it 2-3 days a week. I haul livestock to the sale and the vet with it in my 16' cattle trailer. It has also seen several thousand miles of off roading in Texas, New Mexico, Colorado, our 210 acre farm and 50 acre lease property in East Texas.
    hbaade, nevadabugle and speedtre like this.
  20. Sep 11, 2017 at 5:52 AM
    #4320
    dYL0n
    Dyl0n
    New Orleans, LA
    So do you have the tune?
Thread Status:
