Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 21, 2019 at 8:24 AM
    habanero_taco
    habanero_taco Well-Known Member
    Randy
    2016 Tacoma TRD Sport
    OVTuned
    Oh so it's the ECU itself not a version level issue. Seems weird that toyota has some one-off ECUs out there like that.
  2. Apr 21, 2019 at 8:27 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    It was tried, with an USA ecu S mode stops working.
  3. Apr 21, 2019 at 10:01 AM
    jarrasp
    jarrasp Member
    17 special edition tacoma
    for that reason I refuse any dealer update at regular service, if you like send me email to do any test
  4. Apr 21, 2019 at 5:38 PM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    I really want to get the OVTune for my 2016 Tacoma but not sure if I need TSB 0062-18 applied first? My Tacoma is one of the early ones built in mid October 2015. I read somewhere that the early 16 Tacoma’s need the TSB applied before flashing the ECU. Do I need to buy the OV tune software to determine if I need the TSB? If I need the TSB can I apply the TSB myself with the OVTune flashing software or can it only be done by a dealer? Thanks in advance. I know that’s a lot of questions.
  5. Apr 21, 2019 at 5:59 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    It is possible you'll need the TSB with a build that early. The only way to know for sure is to hook the truck up to a scanner or use the hardware provided with the OVTune kit to do so. With that said, you can download a copy of TechStream (link is in this thread if you search for it) and update with latest TSB files (also in this thread). If you don't want to do that, you can always go the route of having the dealer do it. If your a little tech savy and can follow directions, TechStream is pretty easy to get installed and flash the new TSB.
    FritoBandito[QUOTED] likes this.
  6. Apr 21, 2019 at 6:06 PM
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    If you flash back to stock(testing purposes) , does your calibration id change like if you never had a TSB done? ?
  7. Apr 21, 2019 at 7:12 PM
    Bwinters
    Bwinters Well-Known Member
    2018 Tacoma Off Road cement
    $80 +shipping?
  8. Apr 21, 2019 at 7:34 PM
    SpeySquatch
    2016 TRD OR DCSB
    91 base is schweet
    sd1uh8as, go2cnavy and PhogDog like this.
  9. Apr 21, 2019 at 7:46 PM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Agreed!
    go2cnavy and SpeySquatch[QUOTED] like this.
  10. Apr 21, 2019 at 7:47 PM
    SpeySquatch
    2016 TRD OR DCSB
    Definitely better tip-in and power range of gear holding with the 91 base over 87
  11. Apr 21, 2019 at 7:49 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    You can't go backwards if you do the TSB. If you go to 4b04, you can't go back to a previous calibration.
  12. Apr 21, 2019 at 10:07 PM
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    Me guessing no update tonight?
  13. Apr 22, 2019 at 5:06 AM
    Crimson Flam3s
    So flashing back to stock means you are flashing back to the TSB? Just wasn't sure since I thought 4b04 is for TSB only.
  14. Apr 22, 2019 at 5:47 AM
    ihatemytruck
    Dave
    Southern California
    If you have done the TSB and are on 4B04, you can't go back to previous calibrations. Once you flash the TSB, your calibration is 4B04.
    Flashing to stock doesn't necessarily mean you are flashing back to TSB if you are on previous calibrations.
    mZiggy likes this.
  15. Apr 22, 2019 at 6:16 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    People make the mistake of thinking that their ECU calibration is the stock map. Which is only accurate at a stretch.
    For example, let's say you go from 04B03 to 04B04. You have updated the ECU version, and in doing so, you flash the stock map for that new ECU version simultaneously. You then flash an OVT map. Your ECU version stays the same, with the map having overwritten the stock map. If you wanted to return to stock, you'd have to flash the 04B04 OEM map, because your ECU version changed. ECU versions are not just maps. They're calibrations. The puzzle board/frame, so to speak, while the maps are the pieces that fit within.
  16. Apr 22, 2019 at 6:18 AM
    zeefarmer
    zeefarmer Well-Known Member
    San Antonio, TX
    '16 BR TRD OR
    I had to flash the TSB (04B04) on my 2016 using Techstream before I could install the tune. Fairly easy process if you're a little tech savvy. Install Techstream, download CUW files. Double click on the CUW file for your truck and flash.
  17. Apr 22, 2019 at 6:45 AM
    Crimson Flam3s
    This clears it up nicely, thanks!
    mZiggy[QUOTED] likes this.
  18. Apr 22, 2019 at 7:11 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    My understanding of what you’ve described here is: If I flash the downloaded OV stock tune I’m flashing back to the current ECU version OEM map ?
    mZiggy[QUOTED] and Stoked4 like this.
  19. Apr 22, 2019 at 7:25 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Correct.
    mZiggy likes this.
  20. Apr 22, 2019 at 7:29 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    I am ready to flash soon™. :D
Thread Status:
