Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 25, 2019 at 1:00 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    It's the "American" version of the Ridgeline.
  2. Apr 25, 2019 at 1:00 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Reg keys sent for pending tickets.
    I wouldn't be surprised if the 3rd gen Tacomas short fall was because of the Tundra. Toyota has fleet wide mpg requirements. Certain requirements for all things classified as "truck."
    So by getting good MPG on the Tacoma, they can force one more drop of blood out of that 3UR-FE..and engine that's nearly 15 years old..all the way into 2020.
    Our developer will be on vacation from May 1rst to May 12th. During that time, we will be taking a few days to update several sections of our website. (FAQ page, new info, etc). There may be some site issues during this time.
    Reg keys will not be sent during this time.
  3. Apr 25, 2019 at 1:01 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    I chose the Tacoma because I felt, in stock version, my off road 4x4 was the most capable. Not because it's a Toyota.
  4. Apr 25, 2019 at 1:02 PM
    cstern1
    cstern1 Well-Known Member
    Caleb
    KCK
    2017 DCSB Sport
    But if the reliability remains and thats what buyers pay for, what is the problem? Its not perfect, but I doubt anything else is for all buyers. If the consensus is reliability and resale, thats what I wanted.
  5. Apr 25, 2019 at 1:03 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Man, some of you guys bit hard lol.
    Stop it and he'll go away.
  6. Apr 25, 2019 at 1:03 PM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    UM I don't know...Because they have far far more stopping power? "Adequate" is not worth $40K. Toyota Tacoma is merely "adequate" That's about it. Stop rationalizing Tacoma's faults.
    Why discs are better:
    1. High stopping power
    2.Quick Heat dissipation
    3.Do not cause wheel damage- Drums have shoes connected to a spring that causes friction with the inside of the wheel. This can cause overheating inside the wheel and cause weakness leading to damage. Not the case with discs.
    4.Easy maintenance- Disc brakes just need simple sanding done on the brake pads and the disc. The drums need the entire wheel to be removed during periodic maintenance.
    5.Cheap spares- Changing the brake pads is quite cheap and if the disc needs changing, even then it is not that costly. But is the drums go bad, then there is a chance they cause loads of damage to the wheel on the inside which could become quite costly in the long run.
    6. Adaptability to technology- Drum brakes are purely mechanical, but disc brakes, though mechanical also support ABS fitting. Hence an added win-win.
  7. Apr 25, 2019 at 1:08 PM
    OVTune
    OVTune
    Nothing on 2.0 right now. However Flash software is expected to be ready before he leaves May 1rst
  8. Apr 25, 2019 at 1:09 PM
    ihatemytruck
    Dave
    Southern California
    From what he's said before ....2.0 is still a ways from being released......closer to fall or end of the year
  9. Apr 25, 2019 at 1:10 PM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    I thought this was the OVtune thread, not the upset Tacoma ex-girlfriend thread?
    Neutron, TFly, inksin and 6 others like this.
  10. Apr 25, 2019 at 1:14 PM
    OVTune
    OVTune
    updated the OP so it doesn't confuse anyone. the 4/22 date was when it was posted. There is no expected date right now
    Inferno__Taco and BlkTaco47 like this.
  11. Apr 25, 2019 at 1:22 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Sounds like you drank the other kool-aid
    :jerkoff:
    Deucer01 and Vlady like this.
  12. Apr 25, 2019 at 1:39 PM
    ihatemytruck
    Dave
    Southern California
    The green kool-aid...
    Anchovy[QUOTED] and Deucer01 like this.
  13. Apr 25, 2019 at 1:43 PM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    :rofl:
    turners1222 and ihatemytruck like this.
  14. Apr 25, 2019 at 1:48 PM
    Shellshock
    Iowa
    Well I guess that explains why you bought a ford and not a Toyota
    :rofl:
    chittyrox, Neutron, RocRan26 and 8 others like this.
  15. Apr 25, 2019 at 1:54 PM
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Good catch
    Shellshock[QUOTED] likes this.
  16. Apr 25, 2019 at 2:14 PM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I had the same mindset of drum brakes prior to working on both recently. Why would a new generation tacoma in 2016 have drum brakes?! If you sit back and think what Tacoma are built and advertise for its not a bad idea. Tacoma's are off road adventure utility trucks.
    1. Rear braking only accounts for 30% braking force. Worse case scenario would be extensive down hill driving require braking but engine braking should be considered at that point (Side note my brother tundra and my tacoma came down a mountain existing windrock park warped his front two disk while mine are still going strong at 50k).
    2. Heat dissipation from what? Track days? Hill decent? Should be more worried about regular brake fluid flushes to prevent boil off and break down.
    3. Drums last 2 to 3 times longer than disk brakes... not sure if your point is valid.
    4. Have you taken apart the rear drum brakes? I just tackled both rear drums do to torn E-Brake cables need replacing (to much droop) and it literally took me 5 mins to remove the cover and all the components and another 10 mins to put it back together. FYI first ever rear drum brake job!
    5. Again drums last 2-3 times longer so cost might be the same but only have to take the wheel off once vs 2 or 3 times.
    6. Drums require less pressure to achieve the same brake force. When you are climbing and running crawl control or MTS the rear brakes require the majority of the braking force so drums would be a huge plus. You do know the drums are activated the same as disks... through hydraulic fluid. You are thinking of the E brake purely mechanical which is a very nice option in location and is under utilized in off roading.
    TFly, Atl_taco_, xxTacocaTxx and 2 others like this.
  17. Apr 25, 2019 at 2:16 PM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    Why are you guys continuing to discuss brake technology in the already bloated OVTune thread? Come on.
  18. Apr 25, 2019 at 2:27 PM
    Chad_QS18
    Chad_QS18 Well-Known Member
    Chad
    NoVA
    2018 Quicksand Tacoma Offroad
    Slammed on 16s
    On to a topic that actually pertains to this thread...
    I just picked up my truck from the 10k/12mo service. While driving home, it drove as if I was on the original ECU tune. Prior to dropping the truck off this morning the truck was on 1.05 87Perf for over 1k miles.
    Has anyone noticed an ECU returned to the OEM tune after a ToyotaCare service? I can’t say for certain that my ECU is no longer on 1.05 but I’m going to take the computer outside soon and check the software. Will update after doing so.
  19. Apr 25, 2019 at 2:29 PM
    DuttonCD
    DuttonCD Well-Known Member
    Alabama
    2018 TRD OR CEMENT
    So today I sent my calibration email, hope to get my tune files back so I can flash this weekend
  20. Apr 25, 2019 at 2:32 PM
    Shellshock
    Iowa
    Almost Friday? :help:
Thread Status:
