Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 26, 2019 at 2:51 PM
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    Problem is 5th and 6th are already over geared even on a stock truck with the Auto. The truck has to downshift to 4th for almost any hill, or wind or acceleration. Add in altitude, weight, bigger, heavier tires and mountain grades and the truck constantly needs 4th gear even on the highway. Mat's work has made the double overdrive way more usable but my truck still rarely sees 6th and that is with 33-inch skinnies. I think 4.88 will let it use 5th and 6th more effectively.
    commbubba19 likes this.
  2. Apr 26, 2019 at 3:00 PM
    Taco16LB
    Taco16LB Well-Known Member
    From what I have experienced , The tunes have enabled the use of the 5th and 6th gears by locking them in at a 95 + load as per Fusion . Yes they use the higher gear but is it really good for the drivetrain ?
  3. Apr 26, 2019 at 3:05 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    The way load is calculated with this ECU is, 100% load basically means manifold pressure = same as outside pressure.
    you can get 95% load at less than half throttle.
    ihatemytruck and Inferno__Taco like this.
  4. Apr 26, 2019 at 3:10 PM
    Taco16LB
    To exaggerate , one could be at 100 % load at 1% throttle while in 4th gear at 5 mph . It just stalls .What is different ?
  5. Apr 26, 2019 at 3:15 PM
    OVTune
    OVTune
    Not sure I understand your question, but my post was trying to convey that load alone does not necessarily mean the engine is "working hard."
    For example at 2000 RPM and 30% throttle engine load may be 80%.
    now increase throttle to 80%. Load is now 90%.
    Are we only seeing a 10% different in torque from those two different throttle angles? nope
    Inferno__Taco likes this.
  6. Apr 26, 2019 at 3:24 PM
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    Awesome! Now I will have another person who wants the 4.88 tune to chime in.
  7. Apr 26, 2019 at 3:24 PM
    OVTune
    OVTune
    We have an upcoming update for this
    paleh0rse, Inferno__Taco and wahoobie like this.
  8. Apr 26, 2019 at 3:28 PM
    Taco16LB
    I have been watching the loads on fusion and feeling that the tunes were holding gears at really high loads . I HAVE been concerned that it was bad and the engine was working hard . From what you are saying it is not , and it is a misreading , or use of the load values ?
  9. Apr 26, 2019 at 3:32 PM
    honey
    honey Well-Known Member
    Jeff
    Wisconsin
    16 tdr sport inferno 4x4
    leather, T.C. 6", King coilovers, TC uca's, Alcan, amp, Pro comp, bushwaker, bamf, magnaflow, afe.
    I have 4.88 gears and am also patiently waiting on gear and tire specific tune. I am patient though!
    TWTaco, skyking3 and SpeySquatch like this.
  10. Apr 26, 2019 at 3:35 PM
    OVTune
    OVTune
    What you are seeing is accurate, but what I mean is that load alone is not an indicator of how hard the engine is working. You can see 70% load readings in 6th with your foot barely on the pedal, but the engine isn't working hard at all.
  11. Apr 26, 2019 at 3:37 PM
    honey
    Jeff
    Wisconsin
    Been kicking around selling this fall and starting over with a 2020 model. News of a new motor in 2023 might make me reconsider. Although with the tune and the updates to come, I am not so afraid to own a third gen anymore! Without the tune, not a chance.
    SC4333, TWTaco, skyking3 and 4 others like this.
  12. Apr 26, 2019 at 3:37 PM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    I couldn’t wait anymore. Went ahead and ordered OV Tune today.
  13. Apr 26, 2019 at 3:45 PM
    Rus$
    Rus$ Well-Known Member
    Russ
    2018 Tacoma DCLB AT TRD Off Road
    That relates to gas mileage as well?
  14. Apr 26, 2019 at 3:46 PM
    Taco16LB
    Thankyou for the explaination as the load does not always make sense as to what the truck is doing at the time when also watching the throttle % .I have most likely been over thinking this, and I await the shutter / misfire fix for dongles . Will the dongle version PCMflash be available at the same time as the P5flash ?
  15. Apr 26, 2019 at 3:50 PM
    SpeySquatch
    2016 TRD OR DCSB
    Indeed :thumbsup:
  16. Apr 26, 2019 at 4:34 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I'm running 4.88's and would like the 4.88 Tune! Tune made things way better - thinking 4.88's would put the bow on the top!
    Well that makes at least two of us! Poll showed more - they must have lost their voice!
    So ??? did you get 4.88's or 5.29's ?? 4.88's on stock is way better than stock AT in everyway, and even with stock tire size!
    Hunter399 likes this.
  17. Apr 26, 2019 at 5:04 PM
    jholc21
    Colorado
    My truck is going in next Thursday. Can't wait.
    GoldenBrew likes this.
  18. Apr 26, 2019 at 5:06 PM
    jholc21
    Colorado
    I see you are in Denver, How is 4.88 with 33's going up the Ike Gauntlet?
  19. Apr 26, 2019 at 5:20 PM
    ChickoSM1808
    ChickoSM1808 Well-Known Member
    Michael
    2018 dcsb TRD Sport (OVTuned)
    OVTuned, TRD Pro grille, 32's and many more
    What did u do to resolve this problem
    Taco16LB likes this.
  20. Apr 26, 2019 at 5:57 PM
    GoldenBrew
    Golden, Colorado
    kicks ass. came up heading east (long side of the pass) at 3500 rpm in 5th at 65 mph and never flinched. Plenty of power and no funky shifting. When towing it is perfect. S mode lock down to 4th and upshift when needed. Averaged 24 mph down and back from Golden to Durango.
    jholc21[QUOTED] likes this.
Thread Status:
