Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 2, 2019 at 7:06 AM
    Shellshock
    Iowa
  2. May 2, 2019 at 7:14 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    :ohsnap:
  3. May 2, 2019 at 7:17 AM
    YotaDriver631
    YotaDriver631 Well-Known Member
    '18 Taco
    The Nissan Altima is the most stolen car in America as per Forbes, probably because there are so many of them..
  4. May 2, 2019 at 7:46 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Yes, all Toyotas. My Honda (and all other Hondas / Acuras) do the same. Definitely not limited to Toyota.
    BlkTaco47[QUOTED] likes this.
  5. May 2, 2019 at 8:02 AM
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
  6. May 2, 2019 at 8:05 AM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Shellshock likes this.
  7. May 2, 2019 at 8:17 AM
    SC4333
    Grant
    FL
    He isn't concerned about amperage though, he is trying to boost voltage output. Long story short, the truck doesnt put out quite enough voltage to keep an AGM battery happy in the long term, which can lead to sulfating / shortened life.
  8. May 2, 2019 at 8:18 AM
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    The alternator is rated for higher amperage output, but the voltage is still limited. I have the towing package in my 2017, and a voltage monitor in the cig lighter port. At highway speeds I don't think I've seen over 13.8 volts, and an AGM battery wants 14+ Volts.
    tonered and sd1uh8as[QUOTED] like this.
  9. May 2, 2019 at 8:19 AM
    Cricketeer
    Cricketeer owned by bird dogs
    Jeff
    Everett, Washington
    2017 Inferno DCLB TRD OR
    Leer 180, Bilstein 6112/5160, OME Dakars, OVTune
    I am starting with 87 Base tune. Like you, I worry about availability of 91 octane when traveling. In fact, just yesterday, my wife called and said the gas station she always goes to was out of 91... and that was in the city! I also am not always confident that gas stations always have in their tanks what they claim they are selling.
    Octane decisions may go away in the future as I've read that Mat is working on using the knock sensor to shift maps and adapt to the gas in the tank. Also coming is an update that will use the crawl control selector to change tunes on the road. Both sound appealing for adjusting while on (or off) the road for long periods of time.
    We do love the Cricket! We managed to use it 67 days last year, while still working full time. lol
    I'm really digging your ARB awning! I've been considering one for the truck or trailer.
    SurfratTX and cblow5 like this.
  10. May 2, 2019 at 8:55 AM
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    With the higher-octane tunes, will the ECU still retard the timing to cope with knock if you put lower-octane gas in?
    I am trying to see if it maintains that safety feature in case I lend the truck out (and they don't know better) after a tune or if I get stuck with no high-octane availability during a hurricane. I understand that you'd lose power and whatnot, I am just interested in it not blowing up the engine.
  11. May 2, 2019 at 8:56 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Yes the ECU will still default to OEM safety tables which are untouched. However, it has to knock to get to those tables, and we recommend people use the octane for the file so knock doesn't occur.
  12. May 2, 2019 at 8:58 AM
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    For 2018+, the voltage is ECU regulated.
    I wonder if anyone got a chance to play around with that yet to tell ECU to provide more voltage.
    xxTacocaTxx[QUOTED] likes this.
  13. May 2, 2019 at 9:01 AM
    Vinci
    Sarasota, FL
    '17 MGM Limited 4x4
    Gotcha. Thanks for the info. I had a flash-back to hurricane Irma 2 years ago when we had to hit the road and didn't see anything but 87 for weeks afterwards.
  14. May 2, 2019 at 9:26 AM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    @OVTune, I guess you gave up on the handhelds since I just received a refund notice. Any chance that it may still happen at some time in the future?
  15. May 2, 2019 at 9:29 AM
    OVTune
    OVTune
    it will be re-offered when released.
  16. May 2, 2019 at 9:31 AM
    dpippel
    Phoenix, AZ
    Awesome! Thanks Mat.
  17. May 2, 2019 at 10:17 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Do you have any idea or hopes for when the handhelds will be available? I was in on the pre-order and haven't been bothered by the continued wait time, and still intend to get one whenever they're available
    Or has it simply reached the point where there's literally zero idea on availability and no point speculating?
  18. May 2, 2019 at 10:43 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Keyword there is you emailed zendesk!
    GreyBaldTaco likes this.
  19. May 2, 2019 at 11:00 AM
    OVTune
    OVTune
    The issue that was encountered is extremely rare, and easily reversible. Sending a flash command to the ecu 100 times is just going to make it worse. Because the ecu will only initiate on that command once in its cycle. Clear DTC / cycle power would of likely avoided all of it.
  20. May 2, 2019 at 11:03 AM
    bunz559
    bunz559 Well-Known Member
    Fresno, CA
    2018 Tacoma TRD Off-Road
    What does DTC stand for?
    xxTacocaTxx likes this.
Thread Status:
