Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 12, 2019 at 7:04 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Common sense or not instructions say reset LV with engine running. I asked Mat to verify. He said:
    Turns out ‘Reset LV’ has to be done with engine off.
    MLee likes this.
  2. May 12, 2019 at 7:13 PM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    I flashed 1.05.1 93 performance (yes I had bad shudder) from 1.05 87GL and drove it. Tip in is gone.
    I also got "unsuccessful LV Reset" with engine running but everything seems great. I only drove a couple miles but she shifted like a dream.
    kevron, skyking3 and TRDOBSESSED like this.
  3. May 12, 2019 at 7:35 PM
    wiljayhi
    Jim
    3G, Tuned
    I also thought that the tip in was gone from 87 GL. I didn’t find any necessity to feather the throttle. Might be just a placebo effect. Mat didn’t mention removal of tip in.
    Also, Reset LV will work with ignition on, engine off, same as flashing. Reset AT works either way.
  4. May 12, 2019 at 7:35 PM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    Interesting. I’ve been running 93 base happily for months. I flashed 93 performance on Friday just to feel the ridiculous tip in again and to be able to compare to the anticipated 93 performance without ridiculous tip in. Tonight I flashed 93 base 1.05.1 because I thought the tip in wasn’t fixed. Anyone else have comments on the performance tip in of 1.05.1?
  5. May 12, 2019 at 7:44 PM
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    When updating with the newly released tune, do I need to delete and re-download the particular tune that I am using in my downloads? Or does it update the current tune when I hit update in the flash manager, and then just flash?
  6. May 12, 2019 at 7:47 PM
    wiljayhi
    Jim
    3G, Tuned
    I flashed 1.05.1 87GL, a performance tune, and did not feel the tip in that I found with 1.05 87GL in Feb. Tip in fixed? Seems like it is but won’t know for sure: @OVTune ?
    TRDOBSESSED and YotaDriver631 like this.
  7. May 12, 2019 at 7:50 PM
    El Taco Blanco
    Stock (for now)
    Easy enough. Thanks! :thumbsup:
  8. May 12, 2019 at 7:50 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Just flash the new tune,it overwrites/replaces the old tune.
  9. May 12, 2019 at 8:48 PM
    SurfratTX
    SurfratTX Well-Known Member
    Lee
    SE Texas
    2017 Tacoma TRD OR Quicksand
    Must be quite the eagle eye to see a delta from these images.....
    SpeySquatch[QUOTED] likes this.
  10. May 12, 2019 at 9:56 PM
    Sierra Taco
    Sierra Taco Active Member
    2018 Inferno Tacoma 4x4 Limited AT
    Thanks for the advice. I will look at the Ranger. :)
  11. May 13, 2019 at 4:08 AM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    I think there’s more to 1.05.1 than just a “bumpy road fix.” I’ve been running 1.05 91 Base for thousands of miles. Loaded 1.05.1 91 Base this morning. I never had a shudder or bumpy road feeling, but did have a weird rpm drop after the upshift to 3rd during normal acceleration. It is now much less noticeable on 1.05.1.
  12. May 13, 2019 at 5:07 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Hoping for more feedback on Performance tip in or confirmation from @OVTune. Will be flashing 1.05.1 Performance 93 if so. :bananadance:
    BlkTaco47 likes this.
  13. May 13, 2019 at 5:11 AM
    Deucer01
    North Georgia
    Noticing this on 93 Base as well. One more reason to flash 1.05.1 even though my Taco doesn't shudder.
    BlazinBlueTaco and BlkTaco47 like this.
  14. May 13, 2019 at 5:42 AM
    wiljayhi
    Jim
    3G, Tuned
    Might be as simple as connecting the tactrix to your computer. It should appear in FM after the first connect.
  15. May 13, 2019 at 5:51 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    B30, B31 (2019 AT) 1.05.1 will be posted this week. Fixes include -
    Revised shift points (performance, GearLock) for Rev limiter
    Torque converter mapping (all gears)
  16. May 13, 2019 at 6:05 AM
    Burmapeak
    Burmapeak Well-Known Member
    Oregon
    2017 Tacoma TRD PRO Cement
    I’ve been noticing a strange misfire feeling when accelerating Up the on ramp entering the freeway. Comes on around 3,000 RPM. If I keep my foot steady I can make it keep doing it until I either increase pedal input or decrease. I think the speeds are around 50-55 when it does this. Is this what everyone is calling Shudder? @OVTune 1.05 87base
  17. May 13, 2019 at 6:14 AM
    MLee
    MLee Well-Known Member
    Mark
    Knoxville TN
    2018 Limited Cement
    OTT 7.0
    Uh, common sense has nothing to do with it. Been in IT for over 40 years and learned a long time ago to follow the instructions exactly, even if it seems a bit strange, and this was what the developer said:
    "Yes. After flashing the update, you will need to reset the AT and LV values in the ECU.
    Perform it this way:
    1. Flash the truck. After completion, start the truck.
    Run flash Manager P5Flash Utility
    Select "Reset LV" after completion select "Reset AT"
    After completion you are finished."
    So after that didn't work I tried another approach and was successful and I thought I'd offer it as a suggestion to help others (Unlike your worthless post) if they ran into the same thing.
  18. May 13, 2019 at 6:20 AM
    Burmapeak
    Oregon
    T
    Thanks for that explanation. Strange thing is I've only started noticing it for the last couple Months. 20k on the rig and mechanically everything is sound. Is there a reason not to try 1.05.1?
  19. May 13, 2019 at 7:15 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Give the update a shot. It isn't going to hurt anything to try and worst case, you can always flash back to whatever you're on now.
    Burmapeak[QUOTED] likes this.
  20. May 13, 2019 at 7:45 AM
    OVTune
    OVTune
    Throttle tuning has not been modified on 1.05.1, however tip in will likely feel different due to torque converter changes.
Thread Status:
