Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 13, 2019 at 8:14 AM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    Wicked :rasta:
    Soul Surfer likes this.
  2. May 13, 2019 at 8:15 AM
    dingel5
    dingel5 Mocphus
    Paul
    P Town, California
    2016 MGM SR5 AC AT 4x4 OVTuned 2.0B (Un)Dongled OG
    In progress.... And getting better!
    It’s been a while since I’ve been on the forum. I’ve been on 1.05 91 performance and really like it. Is 1.05.1 a recent update that I’m not aware of? Thanks.
    BlazinBlueTaco likes this.
  3. May 13, 2019 at 8:17 AM
    2017 TRD Sport
    2017 TRD Sport Active Member
    David
    2017 TRD Sport
    456 gears. OV tune. Lift. 285/70/17 tires
    I just downloaded the new files for auto pcm flash successfully but can’t find them to install. What am I missing?
  4. May 13, 2019 at 8:18 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    From Post 1......
    1.05.1 Files (Automatic only)
    04B02 ECU - Updated Torque Converter tables > All gears
    04B04 ECU - Updated Torque Converter tables > gears 2 > 5
    04A60 ECU - Updated Torque Converter tables > Gears 1> 3
    04A61 ECU - Updated Torque Converter tables > Gears 3, 4
    Should I update to 1.05.1 ?
    This update is only necessary if your truck experiencing characteristic "stumbling" or stuttering, "Bumpy road feeling" during low RPM (1200-2000 RPM) at low throttle and low to moderate speed (15mph - 50 mph)
    Are there other updates in 1.05.1 That require me updating the ECU?
    Unless your truck experiences this very specific issue, updating is not required.
    Are there any special things that are necessary to do when performing this update?
    Yes. After flashing the update, you will need to reset the AT and LV values in the ECU.
    Perform it this way:
    1. Flash the truck. After completion, start the truck.
    Run flash Manager P5Flash Utility
    Select "Reset LV" after completion select "Reset AT"
    After completion you are finished.
  5. May 13, 2019 at 8:21 AM
    dingel5
    dingel5 Mocphus
    Paul
    P Town, California
    Cool, thanks. I always forget to check the first post. One of these days I might remember. :rasta:
    Supr4Lo likes this.
  6. May 13, 2019 at 8:29 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    40 years of IT? I'll just leave this here...
    Shellshock likes this.
  7. May 13, 2019 at 8:44 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    @dingel5
    A note about the instruction to start truck then clear learned values. If you attempt “Reset LV” with engine running it will report “unsuccessful”. “Reset AT” will be successful either way.
    Simple way: do LV and AT reset with ignition on engine off same as flashing.
  8. May 13, 2019 at 9:04 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    "different" as in more or less tip-in?
  9. May 13, 2019 at 9:18 AM
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    First drive to work and it's 99% perfect!!!
    ChickoSM1808, GPatriot and PhogDog like this.
  10. May 13, 2019 at 9:24 AM
    wiljayhi
    Jim
    3G, Tuned
    It feels like “less” to me. Mat says it may feel “different” as a result of torque converter changes.
  11. May 13, 2019 at 9:38 AM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    You’re on performance?
  12. May 13, 2019 at 9:43 AM
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    Sorry, I should have clarified... 04B04 - 87 Performance. Flashed yesterday afternoon, also cleared AT and ECU learned values. Quick drive afterwards there was a noticeable difference. Today to work, was smooth as butter. Initial highway speeds was a little 'bumpy road' feeling, but that was VERY short lived... and was probably just... a bumpy road!
  13. May 13, 2019 at 9:51 AM
    Hawks4life
    Hawks4life Well-Known Member
    Joe
    17 Tacoma Pro
    where in NM, hope trip gets better
  14. May 13, 2019 at 9:52 AM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    I'm on 93 performance. @OVTune must've spent some time on this because it is WAY better. Very little tip in but what I'm really referring to is the drive through rush hour that has been VERY frustrating and made me damn angry every single day, until this morning. Stop go stop go for 10 miles and now the damn thing finally shifts like it should. My gf even noticed on the drive in this morning. The jerkiness, hard downshifts when pushing the pedal, even the hard downshift to 1st when coming to a stop (which was still slightly there) are all GONE. I think it still shifts too fast but with 93P there is power there at low rpm, and like I said it (down)shifts like it should now so the fast upshift is less of a bother. Let me get a couple of tanks through it 1st tho lol
    Prairie Hawk likes this.
  15. May 13, 2019 at 9:53 AM
    BlkTaco47
    BlkTaco47 Unhinged
    will have to try the new ones another time, I'm not getting anything other than
    file corrupted or wrong type when I try to write any of them. The only thing that
    stands out between 1.05 and 1.05.1 to me is the extension type is now .p5f as
    opposed to .pcm
  16. May 13, 2019 at 9:55 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    Are you a dongle user? If so, you're attempting to use the wrong files.
  17. May 13, 2019 at 9:58 AM
    BlkTaco47
    BlkTaco47 Unhinged
    haha, well that would do it! thanks man, too much
    going on today, downloaded and ran out and yep! had
    no dongle selected. Up all night diagnosing one of our
    esxi hosts that took a dump...... will give it a go later.
    I was updating both pc's, looks like I brought the right ones
    down at home, here at work I have the p5f files...derp!
    Stoked4, MLee and paleh0rse[QUOTED] like this.
  18. May 13, 2019 at 9:59 AM
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    I flashed 1.05.1 last night to 91Perf. On 1.05 I was running 91base because of the tip-in. So far on the update 91perf tip in feels the same as it did on 1.05. Planning on trying 93perf to see if I experience the different tip-in like some. I did notice on 1.05.1 it seems the power seems smoother all around.
    Hank Heel, GPatriot and paleh0rse like this.
  19. May 13, 2019 at 10:03 AM
    paleh0rse
    Raleigh, NC
    HA! I've actually been there with esxi, man. good luck!
    :cheers:
    MLee and BlkTaco47[QUOTED] like this.
  20. May 13, 2019 at 10:15 AM
    TWTaco
    TWTaco Well-Known Member
    Dave
    Albuquerque UNM my daughter just graduated! We had to get her moved back to Cali after Ceremonies.
Thread Status:
