Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 19, 2019 at 10:46 PM
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    Mat was right, 1.05.1 isnt a good choice if your truck runs fine with 1.05. Spent 5k on 1.05 base and decided to try 1.05.1 performance but its a no go, the truck is jumpy as hell in low rpm. Drove about 1k and gave up, loaded 1.05 gear lock. Will see about that crappy hill on my way to work tomorrow morning.
  2. May 20, 2019 at 4:42 AM
    honey
    honey Well-Known Member
    Jeff
    Wisconsin
    16 tdr sport inferno 4x4
    leather, T.C. 6", King coilovers, TC uca's, Alcan, amp, Pro comp, bushwaker, bamf, magnaflow, afe.
    Isn't performance and gearlock the same tune? And gearlock is in S mode with etc on, and have to downshift to engage it. And at every stop have to do a down shift to engage from that stop again for it to actually be in effect. That is the way it seems to work for me.
  3. May 20, 2019 at 5:28 AM
    dialfonzo
    dialfonzo Well-Known Member
    Eric
    Tacoma 2016 TRD Sport Long Cab & Bed
    My issue is that it does the same thing at 55mph.
    With Performance it does kick in 6th and consume a lot less.
    At 68mph it's 17mpg
  4. May 20, 2019 at 7:00 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Will be available for download this week,
    we will also be releasing a base + gearlock tune option via flash manager for everyone.
    Boost3, honey, treimche and 16 others like this.
  5. May 20, 2019 at 7:01 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    Good stuff! Thank you!
  6. May 20, 2019 at 7:02 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Aww yeah... oh, wait...
    I guess I've got the gearlock thing covered at least.
  7. May 20, 2019 at 7:08 AM
    OVTune
    OVTune
    Also I understand 04B02 files are released for torque converter shutter, but we do also recommend anyone with torque converter shutter on 04B02, or 04B03 to update to 04B04, because that file was released by toyota specifically for that problem. If you still have the issue after updating to 04B04 (some trucks do) then use 1.05.1
  8. May 20, 2019 at 8:07 AM
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    It is ok to go back to 1.05 from 1.05.1 correct?
  9. May 20, 2019 at 8:49 AM
    Shellshock
    Iowa
    yes. you can goto any tune that's available for your ECU.
    Pistol Pete[QUOTED] likes this.
  10. May 20, 2019 at 9:03 AM
    SpeySquatch
    2016 TRD OR DCSB
    @OVTune
    Hey Mat, others may be interested to know as well.
    Is there anything wrong with freshly flashing a tune and towing for the first 2-300 miles? Since the tune is settling during this time will it settle differently than if I wasn’t towing for the 2-300 miles?
    Just curious because I did this and am now not towing, so will the truck drive properly now and recalibrate as I drive with no trailer?
  11. May 20, 2019 at 9:06 AM
    Shellshock
    Iowa
    I've done it multiple times and never had any issues with my truck.
    SpeySquatch[QUOTED] likes this.
  12. May 20, 2019 at 9:11 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Just before I flashed to 1.05.1, I started noticing difficulties to get out of 6th gear. Truck would hold it way longer and required more throttle inputs, just like stock calibration. I was on that version for about 5K miles as well
    Did not see anything weird with RPM , etc.
  13. May 20, 2019 at 10:15 AM
    Ron1965
    Ron1965 Go Bruins.......
    Ron
    Socal
    2018 Cement TRD ORSB PREMIUM/TECH
    OVtune Mooseditty Custom;DD Exhaust;Nitro 5.29’s;SCS Brushed Copper;AFe Custom CAI
    Reflash or remove negative battery terminal for about ten mins. Works for me
  14. May 20, 2019 at 10:23 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    After running 1.04 on 04B03 I updated to 04B04 and then the original 1.05 87 base. After about 1000 miles I began to notice a stall / dead pedal feel. I updated to 1.05.1 87 base and the stall / dead pedal is gone. Shifts so much better! Never thought the dead pedal /stall issue was torque converter? Must have been. Thanks for the work and the ability to clear trans and learning. Looking forward to the 1.05.1 87 base + gear lock!
  15. May 20, 2019 at 11:04 AM
    shacol
    shacol Well-Known Member
    Florida
    2018 Offroad DCSB
    If I've never used @OVTune , should I start with 1.05 or 1.05.1? I'll probably try 93 performance first.
  16. May 20, 2019 at 11:07 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Yup, its the learning. I flash it back to stock a couple days before I take it to get serviced at the dealership, then I flash back to whatever. Im also going to try disconnecting the battery.
    Question to you, or anyone else, when I disconnect the battery all I need to do is disconnect the negative right? Or both? Please help.
    Also, is that Borls 40665 Turbo XL center/offset worth it?
  17. May 20, 2019 at 11:18 AM
    Vlady
    Issy, WA
    Disconnecting the battery does absolutely nothing. Proven many times
    Wixo[QUOTED] likes this.
  18. May 20, 2019 at 11:25 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Start with 1.05
  19. May 20, 2019 at 12:00 PM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    From 1st post.......
  20. May 20, 2019 at 12:08 PM
    shacol
    Florida
    2018 Offroad DCSB
    Thank you.
    I saw that as well... but since I wouldn't be "updating" to 1.05.1 (since I've never tuned). I wasn't sure it applied.
    Thank you.
Thread Status:
