Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 21, 2019 at 4:42 AM
    Pruby18
    Pruby18 Well-Known Member
    2019 DCSB OR 4X4
    Tried looking to see what this “stutter” is all about. Anyone mind explaining what it is, not sure if I have the symptoms or not.
  2. May 21, 2019 at 6:56 AM
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    Did you look at page 1?
    Should I update to 1.05.1 ?
    This update is only necessary if your truck experiencing characteristic "stumbling" or stuttering, "Bumpy road feeling" during low RPM (1200-2000 RPM) at low throttle and low to moderate speed (15mph - 50 mph)
    Pruby18[QUOTED] and xxTacocaTxx like this.
  3. May 21, 2019 at 7:38 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice update! Thanks. :cheers:
  4. May 21, 2019 at 7:45 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    This is what Im talking about
  5. May 21, 2019 at 7:46 AM
    Wixo
    Hank
    Tint, LED interior
    I get much better gas mileage on 93 than I do on 87. I dont really notice any increased power tho
  6. May 21, 2019 at 7:47 AM
    Wixo
    Hank
    Tint, LED interior
    Mine are great 45mph in the "city." Its when Im on the expressway that I suffer.
    sd1uh8as likes this.
  7. May 21, 2019 at 7:51 AM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    I keep mine below 70mph in the freeway, otherwise MPG goes way down where the trade-off isn't that good
    Wixo, dialfonzo, BOMBS and 2 others like this.
  8. May 21, 2019 at 11:00 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    You need to lock TC in order to induce the shudder.
    Get the truck to 4,5 or 6 and keep the foot on the pedal and you need to let a pedal a tiny bit to get TC locked.start dropping rpms and speed. Once rpms below 1500 and speed around 50, start accelerating slowly (increase engine load without downshift).This where it starts to appear.
    Gear, TC locked, RPMs and engine load are the parameters to look for.
    You can get it even at low speed.
    Running Obd2 apps helps to monitor and test it out
    Pruby18[QUOTED] likes this.
  9. May 21, 2019 at 11:56 AM
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    On 1.05.1 I’ve been running 93 base for about 400 miles and I’ve attempted to replicate the “shudder” some are experiencing but haven’t witness one occurrence of it. I don’t remember ever having it on 1.05 but I was only tuned for about 2 weeks before flashing 1.05.1. I just seem to have the steering wheel buzz during the situation where people get the “shudder” feel.
  10. May 21, 2019 at 11:58 AM
    SpeySquatch
    2016 TRD OR DCSB
    That buzz (especially on the top of the steering wheel) is the TC on and is normal
    ry18Tac[QUOTED] likes this.
  11. May 21, 2019 at 12:01 PM
    ry18Tac
    North Texas
    Ovtuned
    I figured that had something to do with it. At first I wasn’t sure if I was even engaging the TC. But I guess I was. Thanks for the reply!
  12. May 21, 2019 at 12:03 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    if you did not have the shudder can I ask why you updated to 1.05.1
    BLUTRD, sd1uh8as and Inferno__Taco like this.
  13. May 21, 2019 at 12:11 PM
    ry18Tac
    North Texas
    Ovtuned
    I was having some weird, quick shifts which would result in the truck lugging where I could have to apply more throttle for it to downshift and accelerate quicker. I flashed 1.05.1 and haven’t experienced that since. I was also running 91 base with 1.05 and have only ran 93 performance and now 93 base with 1.05.1 and 93 base seems to run smoother than 91 base on 1.05. Not sure if it’s the result of being able to clear the AT and LV values. But 1.05.1 seems overall smoother. I also wanted to see how my truck would run on 1.05.1 and if it ran worse I would go back to 1.05. But so far so good!
    Are there any negatives that could result from flashing 1.05.1 if you did not experience the shudder on 1.05?
    paleh0rse likes this.
  14. May 21, 2019 at 12:15 PM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    I have/had that issue with 1.05 87P. The quick shift to 5/6 and lugging and or quick shift back to 4. I ended up going back to base tune for a weekend trip and I am actually digging base tune with ECT on.
  15. May 21, 2019 at 12:32 PM
    LDS 77
    LDS 77 Well-Known Member
    2016 OR
    Does anyone now if it’s normal that when I read it says wrong ECU? I’m guessing it is normal as I can still flash and reset LV and AT.
  16. May 21, 2019 at 12:40 PM
    ry18Tac
    North Texas
    Ovtuned
    It seemed to be more noticeable on the Performance tunes. But I also noticed it on the base tunes. 93 on 1.05.1 I haven’t noticed it yet. I just filled up for my second tank with the new flash. I’ll update if it seems to show back up.
  17. May 21, 2019 at 1:40 PM
    dialfonzo
    dialfonzo Well-Known Member
    Eric
    Tacoma 2016 TRD Sport Long Cab & Bed
    Hi All,
    I've put 91 Gearlock today for a week trial.
    So far a lot better, the truck shift in 6th on most of my roads and will probably be better at mpg.
    Which lead me to my real question:
    What are you relying on for MPG calculation ?
    There are several data in this truck whenever it's on the dash with Average / Fillup Average / Travel Average and on the media center App and i cannot seems to have a data which is the same everywhere.
    On top of that i'm connecting my Bluetooth OBD2 dongle with an app inCarDoctor which give me a lot of values as well and they do not match the truck.
    Yes, on my next pump trip i will be calculating my average the old way manually.
    All the best,
  18. May 21, 2019 at 1:43 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Not normal. You (based on '16) could be a O4B02, O4B03 or 04B04 if AT. ??? Identify the ECU and then determine which files to download based on ECU ID.
  19. May 21, 2019 at 2:21 PM
    SpeySquatch
    2016 TRD OR DCSB
    Yah when I first felt it and didn’t know what it was I was worried lol
  20. May 21, 2019 at 2:31 PM
    rainyben45
    rainyben45 Well-Known Member
    Ben
    Ventura County
    2018 TRD OR DCSB 4x4
    Do you have 4.88’s installed?
Thread Status:
