Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jun 20, 2019 at 10:14 AM
    usernotfound
    usernotfound Well-Known Member
    Brandon
    CO
    '20 4Runner TRD OR
    In the same camp. This is probably an obvious statement, but I'd check Craigslist. I ended up finding an older Acer Iconia Tab for $25. By all accounts its a garbage device but it runs Win7 and runs the OVtune kit just fine.
    SpeySquatch[QUOTED] likes this.
  2. Jun 20, 2019 at 10:15 AM
    dabbinuguay
    dabbinuguay Well-Known Member
    PDX, Oregon
    2017 Tacoma TRD OR DCSB
    Craigslist in my area has a bunch of decent Lenovo T### options under 200 bucks, but buyer beware of course.
    I wouldn't want to keep windows current with 2gb of ram.
    Cheapest options I can find on Amazon here:
    https://smile.amazon.com/ASUS-Ultra...ows+10+laptop&qid=1561050656&s=gateway&sr=8-7
    https://smile.amazon.com/CHUWI-Hero...ows+10+laptop&qid=1561050656&s=gateway&sr=8-8
    But to run windows for longer than 4-5 years, I wouldn't recommend those.
  3. Jun 20, 2019 at 10:17 AM
    dabbinuguay
    PDX, Oregon
    My apologies for derailing this mega thread... :burnrubber:
  4. Jun 20, 2019 at 10:17 AM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    No, but I am dongless in my tuning so I only need the one USB. It looks like that exact laptop isn't listed at the moment, but if you stick with those specs, you can find a comparably priced unit.
  5. Jun 20, 2019 at 10:22 AM
    cstern1
    cstern1 Well-Known Member
    Caleb
    KCK
    2017 DCSB Sport
    Don't know if VMware works any better, but I couldn't get the Tactrix to pass through from the local machine USB through Virtual Box or whatever the builtin Windows one is. Also tried it on a virtual desktop hosted on Unraid. No go either. I'm no expert, but I thought it should be simple. I think only standard USB devices pass through where the Tactrix cable is odd and does not work with native drivers. Or that is my theory.
  6. Jun 20, 2019 at 10:24 AM
    Shellshock
    Iowa
    Virtual box sucks. That’s your problem.
    HelloMyNameIs and SpeySquatch like this.
  7. Jun 20, 2019 at 10:27 AM
    Venator_2033
    Venator_2033 Well-Known Member
    4" inch lift Dakar leafpacks/Bilstein 5100 B110/Fox 2.0 coil-overs/Catless Dual Exhaust w/H-pipe/OVtuned1.05/RCI Sliders/HID kits Hi/Low/AFE Intake with scoop and 76mm throttle body/Total chaos Fab UCA's
    PCMFlash is for those that have a dongle kit, also those features haven't been implemented in PCMFlash yet, only P5flash as of now have it. Those of us with dongle kits still have to use techstream to clear learned values.
    Phich[QUOTED] likes this.
  8. Jun 20, 2019 at 10:29 AM
    Shellshock
    Iowa
    I’ve never cleared values in my truck... never had a problem
    Phich likes this.
  9. Jun 20, 2019 at 10:39 AM
    SpeySquatch
    2016 TRD OR DCSB
    V-Box didn’t work for me either, which is why I went Bootcamp with zero issues
  10. Jun 20, 2019 at 10:41 AM
    Venator_2033
    I found that by clearing the learned values it adjusts the knock correct learn value much faster so you get less misfires after a fresh flash but other than that there doesn't seem to be any value to clearing them unless you have problems or maybe if you decide to go for a different octane. Which soon won't matter anyways with v2.0.
    Phich likes this.
  11. Jun 20, 2019 at 10:41 AM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    Drool.
  12. Jun 20, 2019 at 10:53 AM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    S.O.O.N.
    Venator_2033[QUOTED] likes this.
  13. Jun 20, 2019 at 10:55 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    The stock Tacoma has a top speed governor that will simply kick in at lower speeds once you re-gear to 4.88 or 5.29's because the ECU programming doesn't know that you've re-geared. I believe it's somewhere in the neighborhood of 90mph with 5.29 gears (actual speed, not displayed, which would depend on your tire size and appear lower).
    In other words, the governor itself has nothing to do with OVtune, but I believe Mat did mention he would be able to adjust/eliminate it in future versions of the tune.
  14. Jun 20, 2019 at 10:58 AM
    Venator_2033
    Shellshock and riz_atx[QUOTED] like this.
  15. Jun 20, 2019 at 11:07 AM
    dynamicweight
    dynamicweight Well-Known Member
    I am going to be doing a clean reinstall of windows on my laptop. Will this cause a problem with OV Tune? Will I need to reregister or something? I think I have a dongle. I bought pretty early on and have a purple USB drive I need to stick in to make it work, that's the dongle, right?
  16. Jun 20, 2019 at 11:09 AM
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    Correct
  17. Jun 20, 2019 at 11:11 AM
    riz_atx
    Sohail
    Spicewood Texas
    I believe once you reinstall the flash manager and all the drivers for guardant and all, you will be good.
  18. Jun 20, 2019 at 11:19 AM
    SpeySquatch
    2016 TRD OR DCSB
    The 4.88 tune should fix that because he’s adjusting shift points so the ECU & TCU shouldn’t know any better right?
    paleh0rse[QUOTED] likes this.
  19. Jun 20, 2019 at 11:25 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    This happens with / without the tune. it's due to the gearing itself making the algorithms in the ecu wrong.
    We should be all wrapped up with everything by this weekend. I know you guys are waiting patiently for details.
    Dump tubes should be shipping out this weekend as well.
    hr206, 07taco, honey and 7 others like this.
  20. Jun 20, 2019 at 11:36 AM
    GAHLizard
    GAHLizard Member
    Greg
    NW Montana
    2019 DCLBOR
    2" ADS lift, Off Grid Dual Battery Kit, Twin ARB Compressor, Snomaster Fridge, Truck Vault, 23 Zero Byron RTT, Sliders, Bumpers, Winch, 33s, 5.29 Nitro Gears
    I have the 1.05 tune with 33s and 5.29s and rolled up to 96mph before calling that fast enough. I didn’t seem to hit a speed governor although it may have been ready to kick in at 97mph?
Thread Status:
