Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jul 8, 2019 at 8:30 AM
    rainyben45
    rainyben45 Well-Known Member
    Ben
    Ventura County
    2018 TRD OR DCSB 4x4
    Does a factory tuned 2019+ preform better than a factory tuned 2018?
  2. Jul 8, 2019 at 8:48 AM
    Shellshock
    Iowa
    naw its all the same for the most part. the later TSBs do perform better but still suck compared to the tune.
    honey likes this.
  3. Jul 8, 2019 at 8:50 AM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    Possibly. If the 2018 have not had the TSB done, they might have odd charactistics still. But not sure at what point Toyota would have updated them from the factory last year, if at all. I did not remember when that TSB come out....
  4. Jul 8, 2019 at 8:53 AM
    rainyben45
    Ben
    Ventura County
    Makes sense!
    https://youtu.be/AkUfx_sXXsI
    The guy in this briefly talks about it toward the beginning of the video. I guess he’s just talking about the tsb’s they did.
    2016trdtacoma likes this.
  5. Jul 8, 2019 at 9:53 AM
    Light1984
    Light1984 Well-Known Member
    24 TRD OR Hybrid Bronze Oxide
    Bumping my question as I did not see an answer. @OVTune should I take my truck to the dealership to have it flashed prior to purchasing and installing 1.05.1 or 2.0?
  6. Jul 8, 2019 at 10:44 AM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    While it isn't necessary, history has been the latest versions from OVT get released first. So if you don't, when 2.0 drops you maybe waiting for an older version to drop.
    SpeySquatch likes this.
  7. Jul 8, 2019 at 10:47 AM
    Light1984
    10-4, thank you for the info. I will try to make an appointment with the dealership. Any idea how to check which version I am on?
  8. Jul 8, 2019 at 10:52 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you have the OVT kit, you can update it yourself. You just need to find a hacked version of TS that is compatible with the 2019s and the TSB software. That stuff tends to get posted in the Tech forum. A lot of us MT folks updated the ECU with the TSB software as it was a struggle to get the dealers on the same page.
    crigg93 and Shellshock like this.
  9. Jul 8, 2019 at 11:37 AM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Are the tune files available again Mat?
  10. Jul 8, 2019 at 11:58 AM
    Pruby18
    Pruby18 Well-Known Member
    2019 DCSB OR 4X4
    On 87 base (less than 200 miles). Does anyone feel that the trucks acceleration, smoothness gets better after driving 50 miles or so? It seems like when I do a highway trip it’s a little rough at first then settles in each time. Maybe it’s in my head.
  11. Jul 8, 2019 at 12:27 PM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Between it feeling like settling in and getting used to the way it drives once settled I thing it has really smoothed out. One team, one dream!
  12. Jul 8, 2019 at 12:52 PM
    Taco16LB
    Taco16LB Well-Known Member
    Am I interpreting the new charts on page 1 that the TQ and the HP are both about 750% + higher at about 2200 rpm with the catless dump tubes with 91 octane ,over the Stock 04B04 with 87 octane ? If so this would be incredible . @OVTune
  13. Jul 8, 2019 at 12:56 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You see a similar thing with the tune and no dump tubes. This is the big complaint that we get for the 3.5l, esp from the 4.0l crowd. With the tune, that low end grunt is now there.
    The dump tubes look like they will give a bigger hit through most of the rev range. Not to mention possibly getting 300hp at the wheels.
    Taco16LB[QUOTED] likes this.
  14. Jul 8, 2019 at 1:01 PM
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    5.29s here and happy to test for ya
    Glad to hear it's in the works!
  15. Jul 8, 2019 at 2:23 PM
    Light1984
    Pretty sure it was mentioned somewhere else in the thread that the odd behavior at the low end on the stock tune had something to do with how their Dyno was setup. Someone correct me if I'm wrong.
  16. Jul 8, 2019 at 2:34 PM
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    @OVTune i submitted a ticket last week to buy a product key? No response, no want my monies? :spending:
  17. Jul 8, 2019 at 2:37 PM
    Shellshock
    Iowa
    he was closed for the holiday.
  18. Jul 8, 2019 at 2:37 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    This is because of the stock ECUs throttle and load limits for gears.
  19. Jul 8, 2019 at 2:45 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    how much faster is 87 vs. 91 and is the extra $ in gas worth it?
  20. Jul 8, 2019 at 3:14 PM
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    Okay, I was putting money back for a cat back system, but getting excited about these catted dump tubes. Costs more, but sounds like a legimate gain, not just noise. Anybody put either non cat or cat yet?
Thread Status:
