Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jul 11, 2019 at 8:35 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cool. Thanks!
  2. Jul 11, 2019 at 8:51 AM
    Sunsetsearider
    Sunsetsearider Well-Known Member
    San Francisco
    2017 DCLB OR/1998 5 Lug
    Do you need to purchase windows?
  3. Jul 11, 2019 at 8:53 AM
    Shellshock
    Iowa
    If you want to. Or you can just install and not activate.
    After the trial period it disable stuff like personalization and windows updates but mine is only used for flashing so that’s no biggie.
    2016trdtacoma and tonered like this.
  4. Jul 11, 2019 at 8:56 AM
    Sunsetsearider
    San Francisco
    Good to know. Thanks
  5. Jul 11, 2019 at 10:41 AM
    2016trdtacoma
    2016trdtacoma Well-Known Member
    Trevor
    Utah
    OV Tuned 16 TRD OR 6MT
    If you have a PC desktop, you should be able to use the code from that. I think they allow a few activations with a single code...
  6. Jul 11, 2019 at 10:42 AM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    oh how I love being in the lucky 10
    wahoobie, 2016trdtacoma and tonered like this.
  7. Jul 11, 2019 at 10:43 AM
    grubburg
    2019 TRD OR MT
    that new fix didn't work.
  8. Jul 11, 2019 at 10:52 AM
    grubburg
    2019 TRD OR MT
    i'm trying to :burnrubber::burnrubber::burnrubber:
  9. Jul 11, 2019 at 10:56 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    The new flash software didn't, but the issue is the registration. We are working on new ones for everyone. This fix confirms works.
  10. Jul 11, 2019 at 11:40 AM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Baby yet? @OVTune
    New Wilson??
  11. Jul 11, 2019 at 3:33 PM
    Brucey
    Brucey Well-Known Member
    Bruce
    2018 DC LB SPORT 4X4
    Ovtuned
    I bet that is a honda fit. The steering wheel are light as fuck to turn.
    tonered[QUOTED] likes this.
  12. Jul 11, 2019 at 3:41 PM
    Hinder
    Hinder Active Member
    19 DCLB OR
    I noticed a mild shutter after about 500 miles on 1.05.1 87 base. Can’t remember if ac was on. It’s so mild I wasn’t sure if it was the road or shutter. It happened around 1,200 rpm around 50 to 55 mph.
  13. Jul 11, 2019 at 4:36 PM
    Shellshock
    Iowa
    Who cares about 1.05 numbers. Gimme the 2.0 hotness!
  14. Jul 11, 2019 at 4:50 PM
    Shellshock
    Iowa
    Pretty sure there’s 2.0 and 2.0 dump tube numbers coming
    tonered, 2016trdtacoma and 2001 4x4 like this.
  15. Jul 11, 2019 at 4:52 PM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    What are the thoughts on 93B? Most people comment on 87 to 91, but not 91 to 93. I’m sitting at 91B and have tried 87B and P. Wondering if I should try 91p and 93b/p
  16. Jul 11, 2019 at 4:57 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    If you have easy access to 93, then go for it! I usually just run 93 p
  17. Jul 11, 2019 at 4:57 PM
    jubreunig
    jubreunig 3" RC, 20x9 285/55
    Juergen
    Tuscaloosa
    2018 TRD OR
    20x9 +18 BigBlock 726m, 1.25in Hubcentric, 285/55 LEXANI SLAYER AT PLUS
    i'm sure you will get not a clear answer. however, same time last year, there was a amount between 22-28 HP with 93. and 18-22 HP with 91. Now the values are
    "Peak top end HP gains 10-17HP (measured at wheel) (stock vehicle 91 octane)"
    very dynamic values over the last 10 month
  18. Jul 11, 2019 at 5:02 PM
    OVTune
    OVTune
    I can post dyno results with dump tubes and 1.05 tune if you'd like but it as explained before VVT needs changed significantly, so running 1.05 + dump tubes is not ideal vs dump tube specific tunes.
    Above 5000 rpm there is about a 10-12hp loss vs 1.05 stock exhaust. This is due to VVT changes needed.
    So basically if this makes sense :
    Stock exhaust + 1.05 around 15-17 hp gain
    Dump tube + 1.05, HP loss vs stock above 5000
    Dump tube + dump tube tuning - 24-27HP
    So, from what we tested, if you run a truck with dump tubes and stock tune you are likely to lose some top end power.
    If you run dump tubes + 1.05, gains are less than stock exhaust + 1.05. If you use dump tube + dump tube tune - gains are better than any other combination.
  19. Jul 11, 2019 at 5:05 PM
    OVTune
    OVTune
    Yes we use these number because it's dyno jet "the standard" even though we've made more before. These are peak quoted values after 6000rpm which nobody really cares about, but there are bigger gains in lower rpm.
    xxTacocaTxx and Inferno__Taco like this.
  20. Jul 11, 2019 at 5:08 PM
    OVTune
    OVTune
    Correct. But if you DONT use the new tune you're likely to see a 10+HP LOSS, which is why we made dump tube specific tunes.
Thread Status:
