Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jul 25, 2019 at 2:48 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    From what I’ve read about @OVTune 2.0 with gearlock, the slip will be eliminated. The trans will shift correctly and hold a gear if you want it to. :cheers:
    Vlady likes this.
  2. Jul 25, 2019 at 3:22 PM
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    Not eliminated, but greatly limited. The issue I have with that is I don’t like the gear lock tune because I don’t like rowing gears in an auto. I like being able to limit the top gear and letting the truck down shift if it needs to. Plus I really like ECT and would rather not give it up.
  3. Jul 25, 2019 at 3:51 PM
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    Got a question now. Im trying to follow the instructions and after I add the registry, it says to hook up to the truck and check the ECU ID. Do I have to copy and send this back to OV Tune and wait for the tune to be sent back before I can flash the truck?
  4. Jul 25, 2019 at 3:53 PM
    Shellshock
    Iowa
    if you have the registry file, you just need to check the ECU ID so you know what tune to download.
  5. Jul 25, 2019 at 3:56 PM
    Venator_2033
    Venator_2033 Well-Known Member
    4" inch lift Dakar leafpacks/Bilstein 5100 B110/Fox 2.0 coil-overs/Catless Dual Exhaust w/H-pipe/OVtuned1.05/RCI Sliders/HID kits Hi/Low/AFE Intake with scoop and 76mm throttle body/Total chaos Fab UCA's
    No you need to check what your ECU ID is so you know what tune files to download in flash manager.
    Just keep following the instructions.
  6. Jul 25, 2019 at 3:58 PM
    Sierra Nevada
    KDMAX Tooooned
    TC = Torque Converter
    I believe our trucks have three conditions:
    Open
    Half lock
    Full lock
    When the TC is not locked, it allows the engine to keeps the RPMs up to try to avoid a downshift. This creates a lot of heat though. I think the only time it’s open is when your not on the throttle, but somebody can correct me if I’m wrong.
    I like full lock because it keeps temps down. There’s probably other reasons that others like it but I think they are better applied when the engine is making more power.
    Again, this is just how I understand it. I stand to be corrected.
    tonered likes this.
  7. Jul 25, 2019 at 3:59 PM
    CVOTRDSPORT
    That's what I thought, but if you follow the instructions it says to get the ECU ID and send it back to get the tune files installed. So are you saying now connect to truck, run the P5flash, choose the tune then flash it?
  8. Jul 25, 2019 at 4:00 PM
    Shellshock
    Iowa
    connect to truck
    identify
    download desired tune from flash manager for your ECU
    Flash tune to truck
    2016trdtacoma likes this.
  9. Jul 25, 2019 at 4:12 PM
    CVOTRDSPORT
  10. Jul 25, 2019 at 4:14 PM
    su.b.rat
    su.b.rat broken truck
    unless you'll be happy with mere mad speculation, there is no way to answer this. nobody has compared all these in stages from what I've seen here, and there is certainly no data.
    but i can say the following:
    - 3"sounds decent, 2.5"sounds bad (typical v6 buzz) for the mid pipes. TRD cat back has 3" mid
    - 3" mid pipe does not lose significant torque, but it does feel different to the 2.5"mid pipe (most notably throttle response)
    - URD Y pipe and re-route also eliminates the rear cats & crush pipe that hangs low, so major restrictions removed. and sound changed, may want a resonator or resonated muffler.
  11. Jul 25, 2019 at 4:17 PM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    Neutron and AMOORE_93 like this.
  12. Jul 25, 2019 at 4:20 PM
    ShouldItBeDoingThat
    ShouldItBeDoingThat Well-Known Member
    Unclean
    The West
    18' MGM Tacoma TRD Sport OVTuned
    Eibach pro truck kit + Icon 1.5" progressive AAL 255/75/17 Continental Terrain Contact AT LED interior light kit. Derp: wheels, grill
    Thanks again. Thinking OVTune + catted dumps first and go from there.
    wahoobie and BlazinBlueTaco like this.
  13. Jul 25, 2019 at 4:21 PM
    su.b.rat
    solid plan, can't go wrong with that.:thumbsup:
    mZiggy likes this.
  14. Jul 25, 2019 at 4:46 PM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Anyone using SSP with Gear Lock? I assume that SSP still works as normal if you simply move to S mode and Gear Lock is activated as normal per the video.
    I'm hoping Gear Lock and SSP give me ultimate flexibility when driving and towing.
    Anyone have experience in these matters?
  15. Jul 25, 2019 at 4:57 PM
    ShouldItBeDoingThat
    Unclean
    The West
    Another question (possibly dumb)... when looking on OVTune's website the tune package says 15-20 hp gain at such and such an rpm while the tune + dump tube page gives 16-20 gain for 91 and 20-25 hp gain for 93. I am assuming the 15-20 range stated on the standalone tune page is the 93 performance tune and therefore you can possibly gain an extra 5 hp with dump tubes? Not trying to get picky about hp since it is wildly climate and altitude specific but what real advantages do the dump tubes give you (I assume something since they are larger diameter/stainless/thicker metal).
  16. Jul 25, 2019 at 4:58 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    FIFY,in my experience the drone at certain RPMS/loads was terrible
    su.b.rat[QUOTED] likes this.
  17. Jul 25, 2019 at 5:20 PM
    CVOTRDSPORT
    Probably wont get to do it till tomorrow after work. I will post thoughts
    FritoBandito[QUOTED] likes this.
  18. Jul 25, 2019 at 5:25 PM
    ShouldItBeDoingThat
    Unclean
    The West
    Bday present to me, tune and catted dump tubes ordered... Stoked! Still want an answer from earlier post but it's kinda pointless at this...uh...point.
    SteddyTeddy and wahoobie like this.
  19. Jul 25, 2019 at 5:30 PM
    ShouldItBeDoingThat
    Unclean
    The West
    Oh, how much reported hp gain (if any) do you get from dump tubes?
    SteddyTeddy likes this.
  20. Jul 25, 2019 at 5:45 PM
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
    Mixed with a muffler bearing swap to apex Premium with a TW 5” decal probably 20 HP min
Thread Status:
