Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Aug 8, 2019 at 10:09 AM
    DakoTaco
    DakoTaco Well-Known Member
    North Coast
    2016 MGM OR Tacoma
    Avid front bumper guard OVtune HPS Intake Tube Meso designs counting
    @Shellshock , @hr206 , easy enough to do the flash to 04B04 for a guy who remembers when the only classics were cars, not Lay's potato chips & Coke? I'll do a search in this thread for the walk through if it is.
  2. Aug 8, 2019 at 10:10 AM
    Light1984
    Light1984 Well-Known Member
    24 TRD OR Hybrid Bronze Oxide
    So what do you guys think: buy a license now that comes with a cable or hold off until the handhelds become available? If I buy now, I will need to get a laptop to flash as well. Trying to figure the best option. Any idea on handheld pricing, can anyone that pre-ordered comment?
  3. Aug 8, 2019 at 10:11 AM
    rainyben45
    rainyben45 Well-Known Member
    Ben
    Ventura County
    2018 TRD OR DCSB 4x4
    I love all this feedback I’m seeing of 2.0 EROM. :cheers:
    I’m stoked for my ECU version to be available. I’m holding off on regearing to 4.88’s now (stock truck) and going to see if 2.0 can make me content! Obviously when I go to larger tires and armor up, regearing will be necessary:rolleyes:
  4. Aug 8, 2019 at 10:23 AM
    Shellshock
    Iowa
    If you can read and follow directions, it’s pretty idiot proof. I believe @lapoltba has a link in his signature and a write up.
    DakoTaco[QUOTED] and tonered like this.
  5. Aug 8, 2019 at 10:23 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Per Mat's post:
    The current 2.0 beta works on 04B04 and is for 2016-2017 Trucks that have automatic transmission only. So, when the 2.0 beta comes out for the 2018-19 trucks (with radar cruise control) we will see, but I assume that it will work with the radar cruise control.
  6. Aug 8, 2019 at 10:24 AM
    Ron1965
    Ron1965 Go Bruins.......
    Ron
    Socal
    2018 Cement TRD ORSB PREMIUM/TECH
    OVtune Mooseditty Custom;DD Exhaust;Nitro 5.29’s;SCS Brushed Copper;AFe Custom CAI
    S+Ect = Gearlock. It’s the only thing I drive in..
    BlkTaco47[QUOTED] likes this.
  7. Aug 8, 2019 at 10:25 AM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    I upgraded from 04B02. I was pretty nervous to do it, but it was indeed straight forward.
    The instructions are in this thread some where. What built my confidence was I read that it won't let you take an invalid upgrade path. I installed the flash tool and went to upgrade and there was one of those "are you sure, yes/no" dialog boxes. I said no, and went through trying to load the wrong version and it told me it can't do the upgrade. Which confirmed that it won't let me take the wrong upgrade path or flash the wrong file. It was fast and easy.
  8. Aug 8, 2019 at 10:28 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    D + ECT on 1.05.1 has been great for me, no issues at all. I thought I read that with GearLock active
    it will not down shift unless the RPM's get very low and Mat said he didn't recommend that with
    City driving - which I do a lot of. I have not tried any version of GearLock.
  9. Aug 8, 2019 at 10:46 AM
    Ron1965
    Ron
    Socal
    He doesn’t recommend D+Ect for city driving because it doesn’t downshift correctly..
  10. Aug 8, 2019 at 10:48 AM
    BlkTaco47
    BlkTaco47 Unhinged
    support@ovtune.zendesk.com
  11. Aug 8, 2019 at 11:15 AM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Might not be necessary. I'm on 33's with stock gears and am heavy. If I have 2.0 a few weeks ago, I might not have purchased 5.29s.
  12. Aug 8, 2019 at 11:41 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    All previous gear lock tunes, including the 2.0 beta, use ECT to activate and then s mode to shift through the gears. This effectively disabled standard use of the ECT button and used it solely for gear lock mode activation.
    Apparently this is set to change with the 2.0 final release and ect mode will retain its OEM function.
  13. Aug 8, 2019 at 11:49 AM
    perkj
    perkj Well-Known Member
    Have we gotten official word from @OVTune yet as to whether 2.0 Beta 93 is okay to use with 91 octane or not?
  14. Aug 8, 2019 at 12:06 PM
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    Dude, as it has been mentioned here before, you cannot use lower octane gas than what the tune is made for.
    A couple members mentioned doing so simply because they are at high altitude, which supposedly helps avoid pre detonation as if they were running 93, but with no concrete numbers and testing, I wouldn't risk it.
  15. Aug 8, 2019 at 12:06 PM
    BlkTaco47
    BlkTaco47 Unhinged
    Based on the statement below from his 2.0 blog page, I'd say no.
    "This is a beta version and some features may be limited (i.e. no octane learning or map switching is enabled)."
    perkj[QUOTED] likes this.
  16. Aug 8, 2019 at 12:12 PM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    Roger that. I just wouldn't be that great at explaining it. Let me get some more mileage in and I'll submit a ticket.
    The tune is frikn awesome tho Mat! It's everything you said it'd be in your blog post. Just needs a little minor refinement.
  17. Aug 8, 2019 at 12:22 PM
    GPatriot
    Cincinnati, Ohio
    Shifts too early from 2nd to 3rd (or was it 3rd to 4th?, I need to drive it some more) and it downshifts a little too fast for one gear I believe.
    I was also getting a surge or hang which I think someone explained was TC slip?
    Like I said I'm not good at explaining this stuff plus I need to drive it some more to nail it down.
    I guess I should also add I'm carrying a little extra weight. One size larger/taller C-load tires and 150lbs of rock sliders. I'm not sure how much of a difference that would make though.
  18. Aug 8, 2019 at 12:32 PM
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    Thanks. I got it downloaded and will probably flash tonight.
  19. Aug 8, 2019 at 12:47 PM
    SpeySquatch
    2016 TRD OR DCSB
    I’m glad I did the 4.88’s for me on 32’s with some armor. The truck seems to have better power to weight ratio. The high revving and constant shifting to maintain speed made me nuts and scared me the transmission wouldn’t last
    go2cnavy[QUOTED] likes this.
  20. Aug 8, 2019 at 1:02 PM
    SpeySquatch
    2016 TRD OR DCSB
    It’s not ok. He has said it many times. Some people who stay at very high altitudes say it’s ok, but the risk is your own
    tonered likes this.
Thread Status:
