Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Aug 10, 2019 at 5:57 PM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    Just 33’s. 285 70 17
  2. Aug 10, 2019 at 6:04 PM
    SpeySquatch
    2016 TRD OR DCSB
    You just can’t help yourself can you...?
  3. Aug 10, 2019 at 6:06 PM
    Light1984
    Light1984 Well-Known Member
    24 TRD OR Hybrid Bronze Oxide
    10-4. Thanks for the reply. So the only way to truly know is to either purchase OVT or download TS and check? Guess I will look into getting Tech Stream going to see what I'm working with on my 2019. Thanks again.
  4. Aug 10, 2019 at 6:09 PM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    2.0 87 doesn't hold 6th on the highway as well as 91 base 1.05, for me (stock truck). Yes, I submitted my opinion.
  5. Aug 10, 2019 at 6:23 PM
    Shellshock
    Iowa
    Unless toyota secretly dropped a new TSB, you’ll have a supported ecu
  6. Aug 10, 2019 at 6:31 PM
    Light1984
    I know it will be supported, but could a 2019 need to be updated prior to OVT to get the best experience? Some of the posts in this thread make it seem that way. It may have only been directed to earlier 3rd gens, but wasn't clear. Also trying to decide if I should hold off for the handheld or buy now in which case I would also need to buy a laptop... decision decisions.
  7. Aug 10, 2019 at 6:32 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Handheld... unless you want to log. That’s assuming you HAVE to buy a laptop for this only.
  8. Aug 10, 2019 at 6:36 PM
    Light1984
    I don't have to buy a laptop necessarily, I could use my work laptop. But I would rather have a dedicated device in the truck just in case I need it for some reason. I agree, I think holding off for the handheld is the way to go which can store the stock tune plus others that can be flashed for quick switching... very nice, much like, great success. Thanks OVTune!
  9. Aug 10, 2019 at 6:42 PM
    Shellshock
    Iowa
    It was the 16s that required one. Everything since then is optional
    Light1984[QUOTED] likes this.
  10. Aug 10, 2019 at 7:51 PM
    Derrick2972
    Derrick2972 Well-Known Member
    2016 Toyota Tacoma SR5 4x4
    I'm having trouble flashing the software. Anyone know why I cant click on the P5Flash Utility? Its grayed out. Do i have to connect the laptop to my truck first?
  11. Aug 10, 2019 at 7:53 PM
    Shellshock
    Iowa
    Apply your reg key
    Or run as admin
    Ron1965 and PhogDog like this.
  12. Aug 10, 2019 at 7:55 PM
    Derrick2972
    How do I do that?
  13. Aug 10, 2019 at 8:00 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
  14. Aug 10, 2019 at 8:19 PM
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    Maybe 1 or 2 times in the first drive. Did not notice it today. Seemed to shift really well and hold the lower gear/higher RPM much petter if going up a hill and on turns. Still gotta get more time on it. Maybe some settling?
  15. Aug 10, 2019 at 8:48 PM
    SpeySquatch
    2016 TRD OR DCSB
    I think it may be settling. I find it amazing I can hold 6th gear uphill and when I press the gas it has power to spare in 6th (65mph or higher & 4.88’s)
  16. Aug 10, 2019 at 8:48 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    2.0 is a completely different tune. Stay on the pedal and don’t feather it like you did on previous tunes. Let the EROM do it’s thing.
    SpeySquatch and rainyben45 like this.
  17. Aug 10, 2019 at 8:54 PM
    rpete67
    rpete67 Active Member
    Rod
    2018 Cement Tacoma TRD 4x4
    Which tune are you running 87 or 93?
  18. Aug 10, 2019 at 9:08 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I had the same thing happen too. Try performing an update to the OV tune software and restarting the computer and truck. It may take a couple tries... GL!
  19. Aug 10, 2019 at 9:13 PM
    Ice8
    Ice8 Well-Known Member
    Vancouver, BC
    2017 MGM Tacoma TRD Off Road SB
    A few listed in the signature
    Alright here is a longer post of sorts. I have been an OVTune owner since the beginning purple dongle and all.
    As of a couple days ago I was running 04B02 and 1.05.1. It was a good tune, by far the best yet in that last series of tunes. Prior to 2.0 I would still say that 1.03 was my favorite of all the tunes. 1.05.1 did fix many issues, but it still didn't have the "feel" of 1.03 or many of the other vehicles that I have driven or have access to. I learned to cope with where the downshifts and up shifts would be pedal wise. I had to learn to drive it like a normal vehicle. (Cars I have access to or drive often are the 2019 Acura RDX, 2019 Acura ILX, 2016 BMW X3, 2015 Honda CRV, 2008 Acura TSX)
    Needless to say I didn't think 2.0 would bring that many changes, nor would 04B04 from Toyota. Rather than deal with another stupid Vancouver area dealership I installed Techstream and did the update myself. Pretty easy process which includes double clicking an exe file after setting up Techstream. 04B04 admittedly was a big step forward, I should have done it earlier... but once again the dealerships are a pain.
    *If you decide to do the update, please hook the truck up to your trickle charger in advance and turn off all electronics plus get your laptop ready. Ensure no interruptions from Windows Update or Anti Virus software.
    *I did use Techstream to clear all learned values from the engine and transmission
    After installing 2.0 I took the truck for a test drive. I've gotta say @OVTune , Mat you have done wonders with the tune. I can just hit the pedal and the truck acts predictable. It accelerates normally and the gear hunting randomness is basically non existent. I know it is a beta, but if you can fine tune it even more I think you've finally solved the problem.
    My gas mileage increase was quite noticeable and my wife said "hey the truck seems quieter"
  20. Aug 10, 2019 at 9:38 PM
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    Work has been super-busy, so it's taken me until today to do my first OVTUNE.
    Wow! What a difference it's made so far! I went from the crappy factory "tune" to the OVTUNE 04B31, 1.05.1, 91 octane, Base. In ~100 miles driven; much smoother & crisper shifts, and with a bit higher revs between gears 1 - 4. The throttle lag is gone, and the truck is "reporting" a gas mileage improvement of approx 3-4 mpg (I'll have to do the mileage calculations myself, before I'm convinced.)
    I had the Nitro-Gear re-gearing done (4.88's) which made a significant difference with the "constant finding gears" at highway speeds, when passing, and especially on hill climbs.
    So far, the re-tuning feels like it's fixed the throttle lag and lower speed/lower gear shifting issues!
    PvilleJohn, SpeySquatch and PNWTacoma like this.
Thread Status:
