Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Aug 10, 2019 at 9:42 PM
    SpeySquatch
    2016 TRD OR DCSB
    If you are running 4.88’s the 2.0 tune will blow you away. The power is crazy different (in a good way) uphill and just daily driving
  2. Aug 10, 2019 at 9:54 PM
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    That's really good to know! I seriously considered going straight to the 2.0, but I wanted to establish a baseline using an "in-between" --for my very first re-tune. The 1.05.1 is what I would now consider to be the perfect "stock" tune.
    I'll give it a week or so, and then upgrade to the 2.0
    SpeySquatch[QUOTED] likes this.
  3. Aug 10, 2019 at 10:00 PM
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Is 2.0 a limited release or test file? I tried to DL and not available yet.
  4. Aug 10, 2019 at 10:30 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Should 4.88s or Ovtune be first?
    Philexport likes this.
  5. Aug 10, 2019 at 10:39 PM
    Shellshock
    Iowa
    Tune
    SpeySquatch likes this.
  6. Aug 10, 2019 at 10:41 PM
    PNWTacoma
    Paul
    Depends on if you’re on larger tires but the tune is less coin so I second the tune option first.
  7. Aug 10, 2019 at 11:01 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    It depends on your ECU version. If the download fails it's not available yet.
  8. Aug 10, 2019 at 11:25 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    IMO, it dpends on the use. For example, crawling with/or larger tires, vs highway miles. IMO, OVtune is an immideate difference, and well worth it over stock (including being patient with Mat and experienced with a laptop).
    4:88 gears definitely compliment the auto transmission (including normal driving and, especially, when crawling in 4lo-1st gear).
    My buddy's stock truck gets 22 mpg without OVTune, and he has no concerns (he doesn't know what he's missing). It's definitely personal preference. I'm currently running OVTune with 4:88's (DCLB-OR).
    On a side note, performance mode doesn't work well (because of the throttle response) with 4lo-1st gear because of the touchy tip-in. I'm currently running 1.05 Base mode and it works much better compared to performance mode/map (anxiously waiting 2.0 for 18-19 tacos).
  9. Aug 10, 2019 at 11:58 PM
    Dbronco20
    Dbronco20 Dbronco20
    RJ
    Gilbert, AZ
    2017 Toyota Tacoma TRD Sport 4X4
    Bilstein Suspension, OME Leaf Springs, Full Skid Plates (steel), Ditch and Fog Lights, OVtuned , Thinking about 4.88 Gears
    I will start off by saying my tech understanding is suspect at best...but I can get through downloading a base 91 tune after reading and watching the instructional items 3 times (minimum).
    So, I am stepping up and asking about Tech Stream (TS) portion of these tune. What does TS do, and is it just for dongle users?
    Lastly... I am truly happy with by 91 Base Tune. Its put me in the place I assumed I would have been in, but had no idea how wrong I was putting full armor, 2.5 lift and 33's on a stock Tacoma. My need to mod and geek it out a bit felt like it ruined the truck. Side Note: I feel like the 2nd Gen I had for 10 years would have taken a lift and 33's no sweat. No weird down shifting, the if the pedal moved, the truck moved - not like with the 3rds.
    With my current 1.05 91 Base Tune I am feeling like I am knocking on the door of 2.0 given 1.05 improvements. 2.0 will hopefully summon the soul of the 2nd Gens driver experience back into the 3rd, and all is right in the force from then on.
  10. Aug 11, 2019 at 12:01 AM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    2.0 beta is fucking awesome. This is the first time in 2.5 years and 73000 miles that I drove my truck in in D mode, 2017 3.5 liter auto with 3.91 gears and 265 e load bfs heavy with a shell, and the truck felt connected to the throttle peddle.
    Absolutely how it should have felt from the factory. Cruise control was awesome also.
    I still have a studder 1st gear 1800-2000 rpm. Hopefully full2.0 will address the half lock torque converter for sound control.
    99.5 % perfection for me.
    I can’t wait for 91 octane 2.0 EROM . I can tell the 87 octane timing drop.
  11. Aug 11, 2019 at 12:09 AM
    kelownatacoguy
    kelownatacoguy Member
    Hrmmm... this is interesting. I've been wondering what there are for tunes out there. I think my 2018 TRD Sport would appreciate this.
  12. Aug 11, 2019 at 12:13 AM
    godzilla888
    godzilla888 Just a plain white T
    Paradise
    2017 Super White SR5 DCSB AT
    Can't download the 2.0 beta from flash mgr, you need to use the link above
    And iirc all files are for 04B04 and all are gear lock
    If you don't have 04B04 then do not use the beta, you will have to wait until 2.0 is released for whatever ECU you have
    PNWTacoma[QUOTED] likes this.
  13. Aug 11, 2019 at 12:32 AM
    scifidelity
    scifidelity Well-Known Member
    so this 2.0 beta is the first one with the available option for 4.88 gearing, is that right?
  14. Aug 11, 2019 at 12:47 AM
    RyanDCLB
    4/19 DCLBOR
    Yes, a file is currently there ( including 4:88's w/ Gearlock), but it's currently for 16-17 year taco.
  15. Aug 11, 2019 at 12:49 AM
    scifidelity
    sweet! I've been waiting a hot minute for this! I'll wait a bit longer for the final/ non beta version though.
  16. Aug 11, 2019 at 3:09 AM
    siKjiTz
    siKjiTz Well-Known Member
    E
    Oahu, HI
    2017 DCSB TRD Sport Inferno
    TUNED 2.0 Beta 87 Eibach Pro Truck Lift Kit Stage 1 Wheelers 1.5” Progressive AAL Level 8 MK6 17x8 Falken Wildpeaks 265/70/17” Redline Tuning Hood struts Matt Gecko LED Bed lights OEM Roof racks GoRhino RB20 Running boards A/C drain Mod Kicker speaker upgrade w/kicker key amp. MESO Stage 1 Tail light upgrade OEM Bed Mat
    Flashed to 2.0 and only was able to idle for 10 mins. I didn’t take it for a spin. Going to go at first light tomorrow. Sweet Dreams TW! :rasta:
  17. Aug 11, 2019 at 4:06 AM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    93. Coming from 91 Base on 1.05.
    mackdave likes this.
  18. Aug 11, 2019 at 4:49 AM
    JabambyBrew
    JabambyBrew Well-Known Member
    JB
    Denver NC
    2019 Toyota Tacoma TRD PRO
    Mat, Release the Dragon! 04B31 Please!
  19. Aug 11, 2019 at 5:07 AM
    go2cnavy
    200 miles.
    Still feels great. Shifting is smooth and predictable. TC lock/unlock improvements are huge - no harsh downshifts, unlocks to allow slippage for increased rpms to pull in high gears without downshifting.
    I was hoping for more “seat of the pants” hp/tq below the 3,500 rpm mark. My least favorite characteristic of this truck is the 3,500 rpm light switch like power band - reminds me of my first 125cc 2t dirtbike.
  20. Aug 11, 2019 at 5:54 AM
    buckyop
    buckyop Well-Known Member
    2018 Tacoma off-road xp Black maverick edition
    Any helpful suggestions appreciated...
    I have a prepaid card from my bank (can’t add additional money). The total is not enough to pay for OVTune. Yes I screwed up and overlooked shipping and taxes. OV website does not allow for “split” payments.
Thread Status:
