Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Aug 15, 2019 at 8:03 AM
    soggyBottom
    soggyBottom Well-Known Member
    Didn't miss it. I saw the post about the big/little endian issue on the build. This hasn't been any clarification on the timeline of the fix so I'm still waiting.
  2. Aug 15, 2019 at 8:10 AM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    It takes longer than 10 secs.
    I'd retry.
  3. Aug 15, 2019 at 8:32 AM
    2017 TRD Sport
    2017 TRD Sport Active Member
    David
    2017 TRD Sport
    456 gears. OV tune. Lift. 285/70/17 tires
    Thanks I reloaded and this it loaded like it should.
    PhogDog[QUOTED] likes this.
  4. Aug 15, 2019 at 8:44 AM
    rainyben45
    rainyben45 Well-Known Member
    Ben
    Ventura County
    2018 TRD OR DCSB 4x4
    2.0 IMO truly is the best and biggest change from my stock tuned truck. Not enough miles to say for sure but I’m very content with this version and probably will never sell my truck now due to drivability. Thank you @OVTune
  5. Aug 15, 2019 at 9:03 AM
    ChickoSM1808
    ChickoSM1808 Well-Known Member
    Michael
    2018 dcsb TRD Sport (OVTuned)
    OVTuned, TRD Pro grille, 32's and many more
    So the only thing I've noticed with my truck is that once I get to sixth gear, if someone slows in from of me to say 50mph then I try to accelerate slowly as I squeeze into the throttle it seems to stay in 6th and it will accelerate but I'm getting some TC shudder. I did reset learned values on AT so it might just need some time. 04A61 on 87
    Almost like it should have unlocked the TC till I got back up to 60 or so then locked up again.
  6. Aug 15, 2019 at 9:17 AM
    PatricNV
    PatricNV Well-Known Member
    Patric
    Reno, NV
    2018 Cement TRD OR Access Cab
    OV Tune Skinny tires Trail Gear Sliders
    This cracks me up - I just did this 2 weeks ago for my daughters Discovery II to get her back home.
    Cricketeer[QUOTED] and tonered like this.
  7. Aug 15, 2019 at 9:40 AM
    dinglehoser
    dinglehoser Well-Known Member
    2017 TRD OR AC SW JDM YO
    Coming from 1.05.1 91 base, the new 2.0 beta is so much better - shifting/throttle is much more predictable, and the weird 2-stroke jump at 3500rpm is pretty much gone. Interesting observation - the truck accelerated noticeably differently with each 1500-5500rpm pull during knock learning, even after the fourth pull ... so there definitely seems to be some adaptation happening. I'm on 92 octane.
    Shellshock likes this.
  8. Aug 15, 2019 at 9:46 AM
    Motorrad
    Motorrad Well-Known Member
    link?
  9. Aug 15, 2019 at 9:48 AM
    Fozzymandius
    Fozzymandius Well-Known Member
    2018 Black TRD DCSB
    Currently Stock
    I'd say this doesn't really address his point. He specifically asked about going from 87-93. If the truck has already learned on 87, there is a good chance it's programmed not to ever push the tables back up to 93. That is unless the truck regularly advances the timing just a bit to see what happens, maybe it does. Matt's quotes say it will learn from bottom to top, but that's during the learning process where it's actively trying to make adjustments.
  10. Aug 15, 2019 at 9:51 AM
    Motorrad
    exactly my question.
    if i let the wife drive it all week to work on 87. then i need the extra power to tow for the weekend so i fill up with 93... do i need to do anything else besides fill the tank with better fuel.....
    PapaRee and xxTacocaTxx like this.
  11. Aug 15, 2019 at 10:06 AM
    dinglehoser
    Reading between the lines, learning from more ignition advance to less is quick/reactive (as it should be), while learning from less to more is longer term/more adaptive (also as it should be). Without specifically driving the truck to force a quick learning cycle (i.e., 100% load from idle to redline a few times), it's likely to take a couple hundred miles of normal driving to relearn the advance curve for higher octanes.
    DES2009 and Fozzymandius like this.
  12. Aug 15, 2019 at 10:12 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    So you're saying that it only "learns" the octane once, after you first flash?
    That's not my understanding, but ok.
  13. Aug 15, 2019 at 10:14 AM
    Fozzymandius
    2018 Black TRD DCSB
    Currently Stock
    Unless Matt says otherwise I would say this is likely the case. Would be a nice feature to have on the handheld tuner, tell it you put it new gas so redo octane learning.
  14. Aug 15, 2019 at 10:17 AM
    sig916
    sig916 Well-Known Member
    @OVTune are you going to keep GL in D when ECT is enable? I love how GL work on 2.0 but would love to drive in D and ECT without GL. GL enable in S with ECT seems to be the way to go.
    2.0 beta has been very good although I do miss the tip throttle on 1.05.
    I think you nailed it on 2.0. You have have come a long way and its near to perfect. Hats off to you sir!
    PapaRee likes this.
  15. Aug 15, 2019 at 10:38 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I did log the data on this occurrence. Did not have time to look at
    I was in D. 87 fuel. No values reset
    City street, 25-30 zone coming to overpass. Must be in 1100 rpm range.
    This is was after I flushed and I'm sure it needs more miles.
  16. Aug 15, 2019 at 10:43 AM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    2.0 ole is pretty good.Im happy with it. Easily the best Tune to date. Now teach it to run E85 And give me some more ponies :rolleyes:
  17. Aug 15, 2019 at 10:47 AM
    zeefarmer
    zeefarmer Well-Known Member
    San Antonio, TX
    '16 BR TRD OR
    Same observations here on different acceleration behavior on each pull. First pull I was thinking to myself "man, this kinda sucks" as it was pretty sluggish and by the last pull I was thinking "holy shit, this rocks!"
    PhogDog likes this.
  18. Aug 15, 2019 at 10:53 AM
    Shellshock
    Iowa
    The whole point of this new tune is that it learns on the fly so you no longer have to sit in the gas station and reflash to a different tune...
    Slammer6, PB FAB, nxcess and 5 others like this.
  19. Aug 15, 2019 at 11:00 AM
    Fozzymandius
    2018 Black TRD DCSB
    Currently Stock
    I don't believe that's what I implied. There is certainly a period shortly after a reset where the vehicle is more aggressive in "learning" what it's working with. This has happened on ECUs for over a decade, my 07 subie does this when in closed loop after a flash.
    This is a good takeaway that describes my point:
    This type of behavior would make sense from a safety standpoint, and once a vehicle has learned what it can do for timing advancement I don't see a lot of reason for it to go advancing timing further periodically just to test whether or not previously observed knock will return.
  20. Aug 15, 2019 at 11:08 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    "If the truck has already learned on 87, there is a good chance it's programmed not to ever push the tables back up to 93"
    Ok, I guess I totally misunderstood what you said here.
Thread Status:
