Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Aug 19, 2019 at 11:24 PM
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    2.0 4.88 for me is wonderful. As stated above, Drive mode all the time. I feel like whatever percentage I apply it shifts accordingly.
    My truck is 7” lift with 33” MTR’s, no additional weight comments at the moment. But empty bed, it’s superb!
  2. Aug 20, 2019 at 4:58 AM
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    So how obvious is the whine/knock sound? Anyone else have that issue? I hope this is not going to be common. You guys with 4.88's, what rpm does it run at 75-80 mph in D or 6th with 32" tires?
    Jackpatt9 likes this.
  3. Aug 20, 2019 at 5:33 AM
    Jackpatt9
    Jackpatt9 Well-Known Member
    Jack
    2017 Tacoma TRD Offroad
    Xenon leds Toyo M/T 295/70/17 XD hoss2 17x9
    And to follow up with this question what 4.88 brands would you guys recommend?
    I also would like to know which tune you guys would recommend to help hold 5th and 6th? My truck is a 2017 and the ecu calibration file came up as a 04B02 which isn’t an option for the 2017? Have any of you experienced this?
    Thank you guys in advance
  4. Aug 20, 2019 at 5:48 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    That's because it's one of the oldest ECU's. Tell Flash Manager your truck is a 2016 and you'll be able to access the 04B02 tunes.
  5. Aug 20, 2019 at 5:52 AM
    CVOTRDSPORT
    I have a 16 and had to choose 2017 to get the trans code. Mine was flashed to 04B04. Nitro gear is the only gear set to use. I looked to a lical diff shop and they told me for tacoma nitro gear has it down pat.
  6. Aug 20, 2019 at 5:55 AM
    Jackpatt9
    Jack
    Thank you for this and I figured but wanted to get some input
  7. Aug 20, 2019 at 6:14 AM
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    So I was super skeptical of this tune but have been following this thread on and off since it first started. When I saw there was a gear lock option I decided it was time to give it a try since I do use my truck to tow a trailer. I received my kit yesterday and immediately plugged it into the truck and found I was still on 0B400. I called the local dealer who said they couldn't get me in until Friday and they would need to truck 2-3 hours for calibration. I was way too impatient so I decided to download the techstream and the 04B04 CUW and re-calibrated at home. After, I put about 20 miles on the truck to burn up the last of the 87 octane and did notice some improvement but nothing too drastic. I filled up with 91 and loaded up performance gearlock 1.05. All I can say is HOlYFUCKAMOLY. The truck accelerates faster with 35s than it did when it was bone stock!!!! I do have 4.88s but the big heavy 35s were taking their toll compared to the previous set of 255 85r16s. Ill be taking the trailer up to the mountains in a couple weeks and can't wait to use the gearlock function. Also really excited about reading all these 2.0 reviews and talk of a SC. Thanks @OVTune from a very satisfied customer!!
    taco 16, dustynaka, ToyoDrew and 8 others like this.
  8. Aug 20, 2019 at 6:44 AM
    JabambyBrew
    JabambyBrew Well-Known Member
    JB
    Denver NC
    2019 Toyota Tacoma TRD PRO
    We want we want 04B31 2.0!:cheers:We want we want 04B31 2.0!:cheers: :rockband:
  9. Aug 20, 2019 at 6:50 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    You spelled 04B30 wrong. :D
    taco 16, Frito, Knapz and 2 others like this.
  10. Aug 20, 2019 at 6:53 AM
    JabambyBrew
    JB
    Denver NC
    Lol we we both want it right?
  11. Aug 20, 2019 at 7:06 AM
    Shellshock
    Iowa
    If you are 04b02, you should update to 04b04. Its easy to do yourself if you can follow directions.
    mZiggy and Jackpatt9[QUOTED] like this.
  12. Aug 20, 2019 at 7:07 AM
    TEXAS BS
    TEXAS BS Formerly known as MMXVII
    JB
    Texas
    2017 ACLB TRD OR 4X4
    I’m another, after 4 tanks of fuel I can’t stand the tip-in of 2.0 OLE. The lurch from a dead stop or rolling idle is just no longer tolerable. I’ve flashed back to 1.05 93 Base.
  13. Aug 20, 2019 at 7:36 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    I have not had this surface yet but I still need some more miles. Tip in has been 100% better then prior 1.05 uses.
  14. Aug 20, 2019 at 8:14 AM
    habanero_taco
    habanero_taco Well-Known Member
    Randy
    2016 Tacoma TRD Sport
    OVTuned
    Yeah, tip in on 2.0 is more aggressive than 1.05, takes a little getting use to on a stock weight truck. I don't think it's terrible, but wouldn't mind it tweaked down just a tad myself.
  15. Aug 20, 2019 at 8:22 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Just flashed 1.0.5 last night! 91 perf tune, it drives a lot better around town!! I did a freeway run going up this hill and I still felt it was struggling to get up then I really had to put the pedal to the floor to get it to shift. I saw there is like a 1.0.5.1 tune, should I flash that and see if it fixes the issues I had on the freeway having to put the pedal near all the way down to downshift, when going up a hill? I'm not sure what that flash does, though.
  16. Aug 20, 2019 at 8:25 AM
    Technique
    Alex
    Utah
    Pretty sure I saw that as an option to flash...idk I was pretty tired last night when I was doing this maybe I had double vision lol.
  17. Aug 20, 2019 at 8:36 AM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    I think he has one too many dots.
  18. Aug 20, 2019 at 8:41 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Flash 1.05.1 only if you have a TC shudder issue at low rpms, like driving on a washboard. If you don’t, 1.05 is good. Give it a few hundred miles to settle.
    Inferno__Taco and PhogDog like this.
  19. Aug 20, 2019 at 8:43 AM
    Derrick2972
    Derrick2972 Well-Known Member
    2016 Toyota Tacoma SR5 4x4
    I'm running 4.88's and I don't experience any whine or knock sounds and I'm already past 2000 miles on them. I also have 33" tires with 18" rim's. I dont really hit 6th gear in D, but at 5th my RPM's are at 2300. Which is much lower than the stock gear ratio, during that time my RPM's were around 2800 - 3000 plus constant gear hunting. All of that went away as soon as I swapped out the gears.
    I ordered my gears from East Coast Gear Supply. They told me they use Nitro Gears which in my own opinion are the best ones out there. No issues what so ever, everything was pre assembled and in total cost me $2600 but ended up getting $1100 in return when I sent them my stock cores.
  20. Aug 20, 2019 at 8:43 AM
    paleh0rse
    Raleigh, NC
    1.05.1 is NOT for everyone. It's a patch meant only for those who experience shudder issues with the standard 1.05.
    If you don't experience shudder on 1.05, do NOT flash 1.05.1.
    Inferno__Taco and BlkTaco47 like this.
Thread Status:
