Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Sep 22, 2019 at 12:54 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Do it and report back :thumbsup:
    Spike91321 and Pruby18[QUOTED] like this.
  2. Sep 22, 2019 at 1:35 PM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    I had stumble at multiple speeds with 1.05 and the current beta got rid of all that.
  3. Sep 22, 2019 at 2:18 PM
    SpeySquatch
    2016 TRD OR DCSB
    I always do, but since I will be going from the first 4.88 beta to the newest (91 oct) 4.88 beta, I think I will try not doing it.
    honey and Spike91321 like this.
  4. Sep 22, 2019 at 2:19 PM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    I always reset both for a new tune. You get clunky shifts for about 50 miles. I feel you need to level the playing field to truly evaluate.
    SpeySquatch likes this.
  5. Sep 22, 2019 at 2:29 PM
    SpeySquatch
    2016 TRD OR DCSB
    Yep. And “getting on the gas” and ripping through the first tank seems to help it level out quicker...driving conservative on the first tank really only needs to be about a third or half the time for it to learn that procedure. After doing this the second or even third tank gets the nice consistent mpgs.
    (My observations since 1.03)
    wahoobie and G8R_Taco[QUOTED] like this.
  6. Sep 22, 2019 at 2:35 PM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    For real. I pussyfooted a couple flashes and that never worked out well in the long run. Clear all that shit and romp on it baby!!
  7. Sep 22, 2019 at 2:38 PM
    SkunkTaco
    SkunkTaco Well-Known Member
    Kahl
    2017 Cement TRD PRO
    Sorry if this has already been asked, but i can’t cycle through all these posts.
    does the trucks transmission try to “relearn” and adjust after applying OVTUNE? I know it kind of does with the TSB flashes, which sucks.
    basically, will I have to reflash OVTUNE every couple of months or is the learning logic disabled with this flash?
    thanks!
  8. Sep 22, 2019 at 2:38 PM
    SpeySquatch
    2016 TRD OR DCSB
    Add some injector cleaner and it’s a 2fer!
    :bananadance:
  9. Sep 22, 2019 at 2:39 PM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    Techron and Seafoam dood!!
  10. Sep 22, 2019 at 2:41 PM
    SpeySquatch
    2016 TRD OR DCSB
    The tune disables/overwrites the ECU (sluggish driving experience) learning. The tune takes time to settle in (300+miles) to run optimally. A flash stays flashed until you flash another tune.
    SkunkTaco[QUOTED] likes this.
  11. Sep 22, 2019 at 2:47 PM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    That’s about fucked up! No CC on I’m sure.
  12. Sep 22, 2019 at 2:49 PM
    Pruby18
    Pruby18 Well-Known Member
    2019 DCSB OR 4X4
    Will do! Just flashed so i’ll Do the 50 miles this week and see what the hype is about.
  13. Sep 22, 2019 at 2:54 PM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    We need our beloved throttle cable back dammit!! This fly by wire shit....
    wahoobie and Spike91321 like this.
  14. Sep 22, 2019 at 3:02 PM
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    If you have ECT on and don’t have a gear selected via “S mode”, your truck won’t downshift until it’s critical. Please read and understand the page that you pulled your tune off of. This is most likely not a valid post. And even if it is, you should be taking it to Mat after flashing back to a previous tune that you know works for your truck.
  15. Sep 22, 2019 at 3:04 PM
    Taco-Bandit-1
    Taco-Bandit-1 Member
    Jonathan
    2016 Quicksand Tacoma TRD OR
    When you have ECT on + D mode you lockout downshifting. The 2.0 Beta is a mixture of 1.05 Performance w/Gearlock and new 2.0 stuff.
  16. Sep 22, 2019 at 3:05 PM
    SkunkTaco
    Kahl
    2017 Cement TRD PRO
    Awesome, thanks. Considering the plunge, I’m fine with the way the truck drives except when towing, and I’d like to just use the “manual” shifting mode on the 1.5 tune while towing.
  17. Sep 22, 2019 at 3:13 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    If you don't fully, completely, totally understand how current implementation of gearlock works, don't use the files.
  18. Sep 22, 2019 at 3:24 PM
    Spike91321
    Spike91321 Well-Known Member
    2017 A/C Off Road 4X4
    Let's see what have I done to my Taco? 1st Mod, bought a 2017 4X4 OFF ROAD ACCESS CAB - Barcelona Red! Yes. THEN!!! HOLD ON..... Seat Covers, outside rearview mirror inserts. TRD PRO (OEM) grille. BugFlector hood insert. Window in channel vents. Trailer brakes wiring/instal Tekonsha controller. PIAA back up lights. Black Oak front bumper 20" LED lights. Weather Tech mats, all around. Snug Top Sport shell - lined. Dash cover (So. Ca). Wheels, MOTO METAL LINKS 17"X 9. BFG KO2's, 275/70/17. High/low LUMEN Performance lighting. Lift kit 3" Tuff Country. Fog lights, Lumen H11 XHL C-G7S led conversion kit. Fox 2.5" Remote reservoir adjustable shocks (rear). Hypertech speedo calibrator. White Knuckle rock sliders. Seat covers, again, hard on them! "ORANGE VIRUS TUNED" - YES!!! Decals, AMOCAT, for the doors = (HUNTER) (RELOADER) = Tacoma, backwards! VooDoo Fab anytime rearview camera. TJM front bumper. TJM rock lights. Smittybilt (98510) front winch, 10,000 lbs. NAPA 725 CCA battery. Under hood LED light strips, high intensity C.O.B. 50" Blackoak roof top light bar, curved. Fab Fours rear bumper. Speakers front and rear, JBL 6X9, JBL 61/2, Kicker Amp. Total Chaos bed stiffeners. Headlight assy. Spyder 9039256. ECGS 8" clamshell sleeved bushing. Diff. breather extension. Fumoto oil drain. Yukon 4.88 (REM) gearing. Pop N Lock. ICON Stage IV lift/shocks. Radio knobs. iPhone mount, (A/C vent). Clazzio front seat covers, leather, yea, I'm really bad on seat covers. Sabell Co. tailgate lock. Redline hood struts. Bushwacker fender flares. RoadMasterActiveSuspension. WHEW! I think I'm done???? NOT!!! HA HA HA HA . WE'LL SEE. Oh yea, forgot the Garmin dash GPS! And, the MESO Gashole, Locking gas cap, K&N air filter
    Any. word on H.H. instructions? Are they the same as the Scion instructions? thanks. @OVTune So far I have a $359 paperweight.[/USER]
  19. Sep 22, 2019 at 3:45 PM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    Hey brother. I’m just curious as to why ECT is important for a DD. The way this blended performance beta drives I can’t imagine wanting to hold gears longer. Do you tow often?
    Crimson Flam3s likes this.
  20. Sep 22, 2019 at 4:13 PM
    VoodooPro
    VoodooPro Well-Known Member
    2019 Voodoo blue TRD Pro
    OV 93 tune, TRD pro intake, LED headlights, LED interior lights, tuffskinz interior overlays "RCF", tailgate inlay, Illuminated kickplates, blue interior compartment inlays. Painted voodoo blue interior trim, nitto ridge grapplers, bara 1 inch spacers, redline pro hood struts, trd oil and radiator caps.
    I currently have an issue with the OVtune software I used to tune it to 93 gear lock. I wanted to reflash it a few days ago, opened the software and followed the same instructions as last time "nothings changed on laptop" and now the flash programs wont actually open. Also had to redownload the tunes, as they were not in the location I had originally saved them, almost like it had deleted it all after it finished its tune. If I cant get it to work, I cant update as they roll out. I may be forced to put it on another PC if that is possible.
    Spike91321 likes this.
Thread Status:
