Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 2, 2019 at 9:35 AM
    Tacomafitch
    Tacomafitch Active Member
    Peter
    2018 Inferno sport automatic and a 2020 cement Off Road 6M/T
    The 04A60 Beta did not post that I can see ? I am happy running 1.05 for many miles now
    BlkTaco47 likes this.
  2. Oct 2, 2019 at 9:38 AM
    16taco-trd
    16taco-trd Well-Known Member
    Thanks for all of the hard work Mat. I loaded 19800 this morning and noticed the tip-in changes immediately after a ten minute idle period. I will provide a full review after driving through a tank of gas, but thanks for the effort! I liked 19770, but trying to feather the throttle when hooking up to a trailer was challenging. It should be much easier with 19800.
    bluzharp likes this.
  3. Oct 2, 2019 at 9:40 AM
    jubreunig
    jubreunig 3" RC, 20x9 285/55
    Juergen
    Tuscaloosa
    2018 TRD OR
    20x9 +18 BigBlock 726m, 1.25in Hubcentric, 285/55 LEXANI SLAYER AT PLUS
    ok, i found this entry, but this is mention to the brake behavior:
    "Vehicles with an automatic transmission: To maintain engine braking
    efficiency and charging system performance when using engine
    braking, do not use the transmission in D. If in the S mode, the
    transmission shift range position must be in 5 or lower."
  4. Oct 2, 2019 at 10:20 AM
    SpeySquatch
    2016 TRD OR DCSB
    Is this true for the 4.88 tune as well?
  5. Oct 2, 2019 at 10:25 AM
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    Dump pipes came in today but I wont be able to get them installed for another month or so due to moving. I did get the DirtyDeeds exhaust installed yesterday which has been sitting in the garage for two months and it sounds really nice, no raspiness at all. Got a CEL so when the new 4.88 tune is up on the site I will scan the ECU to see what the code is and then flash new tune and clear all learned values and check engine codes. Hopefully when OVTune releases the tune file for the catted dump pipes it will take care of the CEL if it comes back. I saved the secondary cats from the stock exhaust in case I need to get them welded in to the DirtyDeeds mid pipes.
    paleh0rse and tater taco like this.
  6. Oct 2, 2019 at 10:27 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    you got a check engine light from their exhaust? Assuming you still have stock manifolds right? You should not be getting any check engine light with our catted dump tubes or any exhaust POST cat
  7. Oct 2, 2019 at 10:43 AM
    Venator_2033
    Venator_2033 Well-Known Member
    4" inch lift Dakar leafpacks/Bilstein 5100 B110/Fox 2.0 coil-overs/Catless Dual Exhaust w/H-pipe/OVtuned1.05/RCI Sliders/HID kits Hi/Low/AFE Intake with scoop and 76mm throttle body/Total chaos Fab UCA's
    Sounds like you have an exhuast leak somewhere if that code is related to the emissions system.
  8. Oct 2, 2019 at 11:04 AM
    Kclamer
    Konstantin
    Yes the stock dump tubes are still on, the new mid pipes from DirtyDeeds have no cats. I will run the code tonight to see what it is.
  9. Oct 2, 2019 at 11:10 AM
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    your mid-pipes are most likely causing the CEL if there were O2 sensors in it.
  10. Oct 2, 2019 at 11:11 AM
    Kclamer
    Konstantin
    Just ran the code and it is
    P0430: Catalyst System Efficiency Below Threshold (Bank 2)
  11. Oct 2, 2019 at 11:16 AM
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    Flashed 19800 91 oct this morning with 55 miles and the tip in feels spot on. I put it in 4hi/lo for a quick test and the throttle felt sooo much better. I will report back after a couple tanks of both 91 and 87 to get a better feel.
  12. Oct 2, 2019 at 11:24 AM
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    This version doesn’t have octane learning enabled. If you flashed 91, don’t run anything lower... at least it’s not recommended (by Mat)
    SC4333 and Inferno__Taco like this.
  13. Oct 2, 2019 at 11:34 AM
    Pistol Pete
    Eric
    Oklahoma
    Yeah, there is an 87 version...
  14. Oct 2, 2019 at 11:37 AM
    Sierra Nevada
    KDMAX Tooooned
    just saw the post without looking at the username. You’ve been around a while and know better, but can’t say the same about others.
  15. Oct 2, 2019 at 11:37 AM
    Pistol Pete
    Eric
    Oklahoma
    :hattip:
  16. Oct 2, 2019 at 12:30 PM
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    Reset both LV if going from 2.0 OLE version to 19800?
    Excited to try this one out!
  17. Oct 2, 2019 at 12:54 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    The second set of cats? I'd thought that they weren't monitored or something like that?
    MOC221_ likes this.
  18. Oct 2, 2019 at 12:54 PM
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    19800 loaded... headed out for some errands
  19. Oct 2, 2019 at 1:03 PM
    OVTune
    OVTune
    You must have some sort of exhaust leak
    Inferno__Taco likes this.
  20. Oct 2, 2019 at 1:03 PM
    Kclamer
    Konstantin
    Thats what I thought too, Im gonna have to crawl under and check for exhaust leaks and O2 sensor connections. The mechanic said that the lack of back pressure from the secondary cats may decrease effectiveness of the primary cats and cause the CEL to come on. I bet the catless dump tubes will throw a check engine light for those that went with those. Waiting on the 4.88 19800 build to post so I can flash and reset everything.
Thread Status:
