Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 5, 2019 at 6:41 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    P5F versions loaded.
    more files will be loaded to this page for other ECU IDs, pcm versions, and MTs.
    87 and 91 octane options
    Options are:
    Stock exhaust
    Stock exhaust + 4.88 gears
    Decatted dump tubes + stock gears
    Decatted dump tubes + 4.88 gears
    Catted dump tubes + stock gears
    Catted dump tubes + 4.88 gears
    87 / 91 build of each.
    https://www.ovtuned.com/pages/2-0-public
    BOMBS, Knapz, 07taco and 15 others like this.
  2. Oct 5, 2019 at 6:44 AM
    tkwny
    tkwny Well-Known Member
    Randy
    Wylie, TX
    2016 Quicksand Tacoma TRD Off-Road
    Toytec 3" Lift w/AAL Demello Hybrid Sliders BFG KO2 285/70/17
    Any update on these emails? I haven't seen anything yet but I know you were without power for a bit.
    Thanks!
  3. Oct 5, 2019 at 6:45 AM
    OVTune
    OVTune
    We were without power for 8 hours yesterday, so I have not got any of those emails out as of yet.
    Chipi3s likes this.
  4. Oct 5, 2019 at 6:49 AM
    tkwny
    Randy
    Wylie, TX
    No worries. Thanks for the update!
  5. Oct 5, 2019 at 6:55 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Catless dump tubes installed last night runs strong on 2.0 beta even with the check engine light on. Waiting on 04B13 PCM files...
    offgrid taco, mZiggy and Deucer01 like this.
  6. Oct 5, 2019 at 6:57 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    Thanks for the feedback. How long did take for the install and which 2.0 beta build are you on?
  7. Oct 5, 2019 at 7:06 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    How much louder is it? Is that the only modification to your exhaust?
  8. Oct 5, 2019 at 7:38 AM
    MrWednesday
    MrWednesday Well-Known Member
    Colorado
    2018 DCSB TRD OR MGM
    Any progress on the handheld instructions?
    Heights Tacoma and dpippel like this.
  9. Oct 5, 2019 at 7:42 AM
    M1Awolf
    Rob
    Montana
    FWIW I am a mechanic, I used the shop and hoist after work and I have all the tools possibly needed for the job. It took me just a little over an hour on the hoist. I am on the latest 2.0 beta for the 04B13 M/T. I also have the URD cat delete Y pipe and a flowmaster dual outlet system with a resonator installed so I am completely catless now. It is noticeably louder after the install but I knew this going in. I am hoping Mat will consider a file that can turn of the CEL so I can get my traction control and ABS back...
  10. Oct 5, 2019 at 7:42 AM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    Yes @OVTune , any update on this? I've got a handheld that's been sitting on my shelf like a brick ever since it was delivered 2 weeks ago.
  11. Oct 5, 2019 at 7:49 AM
    OVTune
    OVTune
    This is exactly what I was talking about emailing to people yesterday but could not because we had no power for 8 hours. I am working on sending these emails out today.
  12. Oct 5, 2019 at 7:51 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    I saw the files for 2.0 with dump tubes on his Facebook a little while ago.
  13. Oct 5, 2019 at 7:52 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    also, please make a video.
  14. Oct 5, 2019 at 7:52 AM
    OVTune
    OVTune
    it's right here..
    Inferno__Taco likes this.
  15. Oct 5, 2019 at 8:01 AM
    Dirk_Pitt
    Dirk_Pitt Well-Known Member
    Carrollton, GA
    2017 Barcelona Red Tacoma Limited
    Zendesk Ticket 10465
    2017 Limited 4x4 Completely Stock
    ~22,000 total miles
    ~300 miles on build 19800 tune
    Always run 93 octane fuel (Exxon or BP)
    2.0 Build 19800 91 Octane Feedback
    Tip-In is perfect.
    2-3 and 3-4 shifts are still way too early, even under modest acceleration. Torque converter lock in 3 and 4 compounds the problem. Straight line acceleration at mild to 1/2 pedal makes the truck labor after the 2-3 shift, almost like it still doesn’t know the throttle position or load requirement. Nine times out of ten, TC lock occurs immediately after the 2-3 shift, and then a second later unlocks. Same for 3-4 shift and TC lock. If the TC is going to lock and then immediately unlock, I prefer it to just stay unlocked and not lose the truck’s accelerating momentum. I still question why TC lock is even needed in third. You mentioned on Tacomaworld that the 2-3 and 3-4 shift timing would be tricky (too soon verses too late), I would love to help test “too late” shifts. Of all the tunes that I have used (v1.04 and up), the 2-3 and 3-4 shifts, along with TC lock, have been the shortcoming.
    I will also say that 2.0 Build 10867 (both 87 and 93) had much better 2-3 and 3-4 shift timing than any other tunes. Except for tip-in, both variants of 10867 were the best my truck with my driving style has ever experienced.
    I am 100% on pavement, mostly city driving. 53 years old, just looking for it to drive like a "normal" vehicle. I am eager to help if needed.
  16. Oct 5, 2019 at 8:05 AM
    dpippel
    Phoenix, AZ
    Awesome. Thanks Mat!
  17. Oct 5, 2019 at 8:11 AM
    M1Awolf
    Rob
    Montana
    Nothing for 04B13's M/T with PCM flash (dongle versions) yet.
  18. Oct 5, 2019 at 8:13 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks, @OVTune !
    :anonymous:
    CorbinDallas and Shellshock like this.
  19. Oct 5, 2019 at 8:19 AM
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    Well said. Spot on in every regard. I think your concerns are already on Mat’s radar though. Keep in mind, the only difference between this latest version and the last one is the tip-in.
    TFly likes this.
  20. Oct 5, 2019 at 8:37 AM
    mexanese.502
    mexanese.502 Well-Known Member
    Kentucky
    2017 Limited BADASSMF
    OV Tuned
    So I'm still running the Octane learning version of 2.0, and my setup required the dongle to tune. Looks like these new files are all for dongle less using the P5Flash utility and not the PCM Flash version.
    Is this correct?
Thread Status:
