Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 5, 2019 at 8:38 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Correct, for now. pcm version files will be posted on that page, along with MTs
  2. Oct 5, 2019 at 8:41 AM
    mexanese.502
    mexanese.502 Well-Known Member
    Kentucky
    2017 Limited BADASSMF
    OV Tuned
    Cool. Thanks man
  3. Oct 5, 2019 at 9:00 AM
    n6vmo
    n6vmo Well-Known Member
    Sahuarita, AZ
    2018 DCLB OR AT Super "Priviledged"
    Bilstein 6112, ICON UCAs, 5160, AAL, 265/75/16 Falken Wildpeaks
    Edit: Zendesk Ticket 10467
    The zendesk will get the exact assessment from me too.
    I'm running 04A61 19800 and can corroborate Dirk_Pit's assessment. My 19800 tune has only ~100 miles on it, using 87 octane fuel and I reset LV and AT at flashing.
    Coming out of a street corner, it seems the the truck doesn't know what to do or what gear for the required load is needed.
    I'll give it a full tank before deciding if I am going to flash back to 2.0 Base, which for me, has been the best tune.
  4. Oct 5, 2019 at 9:08 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I've been driving with monitoring app for about a year and never seen TC locked in 3rd.
    On stock and any versions.
  5. Oct 5, 2019 at 10:19 AM
    Texaslaw
    Texaslaw Well-Known Member
    2018 Quicksand TRD OffRoad (OVTuned)
    I agree with all of this on my A61 truck also.
    HardTaco712 and TFly like this.
  6. Oct 5, 2019 at 10:36 AM
    jrdills
    jrdills Well-Known Member
    Has anyone ran 4.88 gears tune on a stock geared truck to see if the shift points are better for some?
  7. Oct 5, 2019 at 11:13 AM
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    Do you get the shudder/surge feeling when you come out of a corner at about 1100-1200rpm? I get that and I have to give it more throttle for it to finally downshift and get out of it. That’s really the only complaint about 19800
  8. Oct 5, 2019 at 11:35 AM
    ry18Tac
    North Texas
    Ovtuned
    Zendesk #10468
    I am 04A61 2018 TRDOR with no mods other than a drop in air filter. I’ve been running 93 octane with the 91 tune. The only issue I’ve been having is while cursing between 30-50mph the truck with shift up and cruise at 1100-1200 rpm which is fine but when it comes to accelerate the truck seems to lug with a slide shudder/surge. It’s not major you can just feel it. It seems as if the truck wants to downshift then it decides not to and back and forth until you finally give it enough gas, which I’d say is about 1/4 the pedal travel and it will downshift and all is well. It does something similar to this while cruising at highway speeds 65-75 but when you go to accelerate it doesn’t lug and shudder. You just press the pedal down about 1/4 of the way and it downshifts and goes. That’s the only thing I’ve noticed so far. Mpg’s are up, tip in is perfect and the power is there. I’ve ran about 250-300 miles on the tune. I plan on switching to 87 tune since I travel for work now and it’s too expensive.
  9. Oct 5, 2019 at 12:03 PM
    n6vmo
    Sahuarita, AZ
    I believe I get the surge after the corner, where the truck falls on its face and then, without any more throttle, it downshifts to get it where it thinks it needs to be and then up shifts. It should have been in the lower gear as I first slowed and encountered the turn.
    Every 2.0 tune that I have flashed, shifts perfect when the engine/trans is cold and warming up. The first 5-10 minutes of my commute through town each morning is 'shift heaven'.
    But, once warmed up, all these TC lock/unlock and now cornering surge issues manifest themselves.
    TRDOBSESSED and TFly like this.
  10. Oct 5, 2019 at 12:38 PM
    sigh824
    sigh824 Active Member
    2017 Magnetic Gray Tacoma TRD Sport
    Turbo soon?!
  11. Oct 5, 2019 at 12:43 PM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Here you go,one video with a normal start and a hard pull in 2nd to 6800rpm and into 3rd until I may or may have not passed triple digit mph before shifting to 4th.
    This one is normal driving up to a 75mph cruise.
    uploadadventure, SK808 and tonered like this.
  12. Oct 5, 2019 at 12:46 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Dayum. That sounds good.
    Windows open?
    :cheers:
  13. Oct 5, 2019 at 12:52 PM
    M1Awolf
    Rob
    Montana
    Closed
    tonered[QUOTED] likes this.
  14. Oct 5, 2019 at 12:54 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's some good growl.
    The catted DTs are moving up my list.
    :cheers:
  15. Oct 5, 2019 at 1:04 PM
    M1Awolf
    Rob
    Montana
    Here's one of me leaving work to do the other videos with the passenger window down about 3",the wind was blowing to hard to have it down all the way. Normal driving for the most part, I kept it in third going up the hill so I didn't lug the engine, I could have pushed the car in front of me as I had plenty of power at that rpm. Near the end when I got froggy I skipped a gear and went from 2nd to 4th.
  16. Oct 5, 2019 at 1:05 PM
    M1Awolf
    Rob
    Montana
    Mine are catless with the URD cat delete Y pipe ;)
  17. Oct 5, 2019 at 1:06 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep. Pretty much open other than that resonator insert, right?
  18. Oct 5, 2019 at 1:10 PM
    M1Awolf
    Rob
    Montana
    Yep and it isn't restricted much,I used a 2 1/2" spiral core glasspack as a resonator in front of the flowmaster dual outlet muffler.
  19. Oct 5, 2019 at 1:13 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have a cut up MBRP and resonator in the crawl space. I need to get a welder and play around with it.
  20. Oct 5, 2019 at 3:20 PM
    ry18Tac
    North Texas
    Ovtuned
    I know exactly what you mean. My truck is the same way when it first gets started and I start my commute.
Thread Status:
