Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 8, 2019 at 7:48 AM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Maybe a "change log" is in order at the top of the beta page.
    "Date - Files added/files removed"
    And so on...
  2. Oct 8, 2019 at 7:52 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I'm not sure how that's possible since these are not on my AWS server. But I will double check.
    It would be great to have a single setup / single file type for everyone but not if dongle users are going to fight us on it.
  3. Oct 8, 2019 at 7:52 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    @OVTune any progress on the PCM dump tube files for the M/T crowd?
    ETA I am fine going dongle-less if that can speed up the process...
  4. Oct 8, 2019 at 7:54 AM
    Bagow
    Bagow Well-Known Member
    Arizona
    2016 DCSB OR 4x4
    I downloaded these files as well.
    SC4333, Taco16LB and DES2009 like this.
  5. Oct 8, 2019 at 7:54 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I've a dongle and prefer it, but if we have to update then we have to update. :notsure:
    SpeySquatch, tonered and nxcess like this.
  6. Oct 8, 2019 at 7:55 AM
    Taco16LB
    Taco16LB Well-Known Member
    Both the 19800 pcm and p5f 87 and 91 octane files were there as I have them also. There was no 4:88 gear files though .
    DES2009 likes this.
  7. Oct 8, 2019 at 7:55 AM
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    FFS. Relax people. Beta is Beta, not final. I don't panic because I don't have the latest beta version for my particular truck. Drive the tune you have and wait for the next round of updates. I just download them when they post and install them when I get a chance. Every round for me has gotten better, Beta or not. If you missed the last round just wait for the next round for your particular config until it's Final.
    SK808, Mkime and ihatemytruck like this.
  8. Oct 8, 2019 at 7:56 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Speaking as a dongle user, you have every right to switch us all over to the current dongle-less setup. It's your business and if it makes things work more smoothly and is more secure, then by all means, you should do it.
    SK808, Mkime, TFly and 1 other person like this.
  9. Oct 8, 2019 at 7:56 AM
    OVTune
    OVTune
    Here is all of our 19800 build files on our server.
    So something isn't right. I'll figure it out.
  10. Oct 8, 2019 at 7:56 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    As a dongle user who has had the kit since August of 2017 and run every version of the tune so far I am looking forward to ordering the hand held unit to use the p5f files so I don't need to drag my ancient laptop out every time I want to update something.
    Shellshock likes this.
  11. Oct 8, 2019 at 8:04 AM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    The 19800 PCM unicorn files are indeed out in the wild, I've been running it since Oct 3rd, and loving it :cheers:
    It would be great for everyone to use P5F, this simplifies development and distribution process. I simply like you to consider method used for switching dongle user. Instead of going to a software based registration using Windows hardware key, update Toyflash to handle USB dongle authentication. Or update PCMflash to handle P5F? I know there are complex encryption methods used to build these files, if this isn't feasible, I understand. Just know I accept software reg under protest :crapstorm:
    paleh0rse and Shellshock like this.
  12. Oct 8, 2019 at 8:05 AM
    TFly
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    I second...or third...or fourth this. The dongle works for me, but if it means less work and quicker updates...send me a dongle-less registration right now.
    KanPanic, Mkime, M1Awolf and 3 others like this.
  13. Oct 8, 2019 at 8:06 AM
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    That's odd because I also downloaded the 19800 pcm file for 04B04 when you first released it last week. Link was on the page to download but not anymore.
  14. Oct 8, 2019 at 8:07 AM
    OVTune
    OVTune
    okay clearly the fault here is mine and I am not sure how or what happened but I will get this corrected asap.
  15. Oct 8, 2019 at 8:12 AM
    perkj
    perkj Well-Known Member
    I down loaded the same 91 19800 pcm file on 10/1 and two attempts to install it resulted in it being "unsuccessful" and with one of the attempts resulting in "brake override malfunction". I've submitted ZD ticket #10472 on 10/5 and no response yet. Based on the info from @OVTune above, starting to wonder if these files were prematurely placed on the beta download link before they were deemed ready.
  16. Oct 8, 2019 at 8:17 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Mistakes happen, and I'm glad that it was only a mistake.
    It didn't make sense to me that all of the .pcm files would be removed without explanation, and now we know that they were removed by accident or in error.
    All's well that ends well . . .
    :thumbsup:
    BlkTaco47 and Taco16LB like this.
  17. Oct 8, 2019 at 8:18 AM
    Shellshock
    Iowa
    yep same. Products and technology change over 2-3 years. The days of running the same thing for 10 years are long gone
    move to dongleless or pick up a handheld. I don’t think it’s really that big of an inconvenience, especially when my flashing computer is unchanged since I set it up in November 2017 :notsure:
    tonered and mZiggy like this.
  18. Oct 8, 2019 at 8:21 AM
    mZiggy
    mZiggy Honey badger
    Marc
    I moved to a new dedicated tuning laptop earlier this year, I won't be upset if @OVTune has us move to dongle-less
    tonered likes this.
  19. Oct 8, 2019 at 8:33 AM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Oh.... we pay attention. TW style of course.
  20. Oct 8, 2019 at 8:57 AM
    Steelhead Taco
    Steelhead Taco Oncorhynchus mykiss
    Fred
    2016 OR DC SB MT
    just a joke kids....
    taco 16, double_duez, perkj and 2 others like this.
Thread Status:
