Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 9, 2019 at 2:31 AM
    memphis212
    memphis212 /facepalm
    Daniel
    2018 Tacoma SR5
    n/a
    You should be able to use your MacBook, but you would have to install a copy of windows on it. It is not a hard process using boot camp.
    https://support.apple.com/en-us/HT201468
    Spike91321 likes this.
  2. Oct 9, 2019 at 4:06 AM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    You'll also need Fel-Pro 23591 2.25" circle gaskets for the other end. Got mine at Advanced Auto but you can also get OEMs from Toyota.
    taco 16 and SK808[QUOTED] like this.
  3. Oct 9, 2019 at 4:47 AM
    Slammer6
    Slammer6 Active Member
    2019 Tacoma TRD ORDC AT White
    OV Tuned
    There are performance and base tunes for both 87 and 91+. There are base tunes for both. My suggestion is try them all. What works for someone else may not make you happy.
    MandosTaco[QUOTED] likes this.
  4. Oct 9, 2019 at 4:51 AM
    L-SCHLEGS
    L-SCHLEGS Well-Known Member
    Nashville, TN
    2017 CEMENT TRD PRO
    When will pcm tunes drop? First time my dongle has pissed me off. Just put one his catted dump tubes and can’t try any 2.0 tunes :(
  5. Oct 9, 2019 at 4:56 AM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    When they’re ready.
    Spike91321 and Shellshock like this.
  6. Oct 9, 2019 at 5:21 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Come on Matt I need help with this. Just sent this message to zendesk.(10531)
    Hello
    I emailed you two weeks ago and still no response. I have a 2018 Tacoma M6 and have been running OVT for the last two years (dongle user). I've been trying to flash to 2.0 beta and I get the unsuccessful message right after it tries to ID the pcm. I tried to load other tunes and get the same result. I decided to see if the stock tune would work and it managed to load. Now the issue is I'm stuck on the stock tune and nothing else will load. I've tried three different laptops, made sure all the anti virus is off and a dozen other suggestions from forum members and still no luck.
  7. Oct 9, 2019 at 5:39 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Sorry I thought I already responded to your ticket about trying to load a 04B30 file into a 04B03 ecu..
    Do this:
    First, make sure you have the latest version of pcmflash (if it needs to update then update it. *generally this isn't a problem, but good to try)
    Turn your truck on, click CLEAR DTC in pcmflash
    shut the truck off
    START THE TRUCK for 1-2 mins
    shut the truck off
    turn the truck on
    try to flash
    Spike91321, perkj and Inferno__Taco like this.
  8. Oct 9, 2019 at 5:50 AM
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    I looked this up and its listed as 2.55" OD, and it says "not compatible with 2016 Tacoma"
  9. Oct 9, 2019 at 6:23 AM
    Deucer01
    North Georgia
    Should work. The P/N was given to me by another member who has installed the DTs.
    tater taco[QUOTED] likes this.
  10. Oct 9, 2019 at 6:57 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    @SK808
    This is where I got them for my 17 they will be the same for all years. You will need two of each #2 #7
    https://parts.olathetoyota.com/auto...gine/exhaust-system-cat/exhaust-manifold-scat
    SK808[QUOTED] and mZiggy like this.
  11. Oct 9, 2019 at 8:08 AM
    Deusdeceptor
    Deusdeceptor Active Member
    Vincent
    2017 Tacoma TRD PRO Cement, Evo 9 MR, LS1 swapped FD, LS3 Swapped IS300 WB, 71 240z, Supra TT Widebody
    King Shocks with adjustables, TC UCA, OME heavy duty Dakars Nitro 5.29 Gears TE37x 16x8 -20 315/75/16 Toyo Open Country AT2 Frontrunner complete roof rack system Rigid Industries lightbar, light pods and Rigid Adapt lightbar Detours of Main Hitch Tire Carrier 1UPUSA bike rack Amp Research Power Steps SPOD SE light comtroller Dual Battery System Snug Top Super Sport with all the options
  12. Oct 9, 2019 at 8:14 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Thanks for the reply. I'll give it a shot when I get home, away for a couple of days.
  13. Oct 9, 2019 at 8:27 AM
    M1Awolf
    Rob
    Montana
    It wasn't too bad but I am a mechanic so take that for what that is worth. I thought the hardest part was unplugging the o2 sensors lol. It took me just a little over an hour on my hoist,leave the 02 sensors in and remove them when you get the old cats on the bench and install them on your dump tubes before installing them.
    It is a tight fit but you can get them out without removing any additional parts,you just have to wiggle them the right way ;) Jack the truck up so the front tires hang free and you can go in from the wheel well without removing the tires to get the cylinder heads nuts. You will want a long extension and an impact wobble with a 12mm semi deep socket for the manifold nuts on the cylinder head ;) A 14mm ratchet wrench is also handy for the exhaust brackets where they attach to the transmission. This was on a M/T truck,auto's may be different...
    ETA I also had the URD cat delete ypipe installed beforehand so I did not have the secondary cats in the way...
  14. Oct 9, 2019 at 8:36 AM
    Deusdeceptor
    Vincent
    thanks for the tips!!! im an auto..
    I sent matt an email to request to register my system ID but it has been 4 days now but no reply. He is prob still busy moving.... Hopefully he doesnt overlook my ticket.. Cant wait to try OVTUNE out!
  15. Oct 9, 2019 at 8:50 AM
    perkj
    perkj Well-Known Member
    @OVTune I have a similar problem but I am also getting the "brake override malfunction" after the "unsuccessful" (ZD: #10472) I haven't received a response yet to my ticket...should I follow this procedure as a next step on mine?
  16. Oct 9, 2019 at 9:03 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    try it - doubt Mat would provide info or directions that would intentionally brick an ecu.
  17. Oct 9, 2019 at 9:13 AM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Agreed, I'd go for it.
  18. Oct 9, 2019 at 9:28 AM
    perkj
    Given that this is the second beta drop that has experienced this problem, I'm hoping to get formal direction from @OVTune for specific next steps I should take based on my ticket submission (#10472)
  19. Oct 9, 2019 at 9:33 AM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
  20. Oct 9, 2019 at 9:36 AM
    perkj
    I'm getting the "brake override malfunction" in addition to the "unsuccessful" which renders the truck undrivable, which is different from the issue the other user was seeing where Matt stated the procedure to try. I'll continue to wait for a response from @OVTune on my ticket 10472 as my issue is seemingly a bit different.
Thread Status:
