Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 9, 2019 at 9:37 AM
    Burmapeak
    Burmapeak Well-Known Member
    Oregon
    2017 Tacoma TRD PRO Cement
    I also saw those files available but didn't download due to them having GL.
  2. Oct 9, 2019 at 9:39 AM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    I get that every time I flash, along with a bunch of other crazy notices on my display as soon as I hit ‘write’. Anyway, good luck.
  3. Oct 9, 2019 at 9:50 AM
    perkj
    perkj Well-Known Member
    The "brake override malfunction" ends up being a permanent message with a permanent CEL after the "unsuccessful" flash attempt. the truck is then put in limp mode and remains there. This is not normal as you're suggesting above.
    SC4333 likes this.
  4. Oct 9, 2019 at 10:01 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I believe he's just referring to that popping up AS you flash(successful flash). All those messages do pop up on the dash but they do go away once the flash is succesful.
    Obviously, if it's staying there and your truck is in limpy mode..that's not normal.
    SC4333, Turd Hawg and perkj[QUOTED] like this.
  5. Oct 9, 2019 at 10:10 AM
    perkj
    Agreed with everything stated and yes "brake override malfunction" is staying there with the end result being the truck is in limp mode. (ZD Ticket 10472)
  6. Oct 9, 2019 at 10:37 AM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    What year truck and what ECU?
  7. Oct 9, 2019 at 10:41 AM
    SK808
    SK808 Well-Known Member
    Ewa Beach, Hawaii
    2017 Tacoma TRD OR DCSB 4X4
    Magnuson Supercharger, Kings w/Resi front and rear, ICON UCA, Allpro STD leaf pack, C4 Fab Hybrid Front Bumper, RCI Rear Bumper, X20 winch, All Pro U-bolt Flip Kit w/ wheelers bump stop, Method 701, 17X8.5 w/0 offset, BFG KM3 285/70/17, All Pro Sliders, TRD CAI, Spec-U exhaust, Total Chaos bed stiffener, RCI Skid Plates (all skids), Wet Okole seat covers, Diamondback tonneau cover, Grillcraft MX Grille, Husky front floor mats, Weather Tech rear floor mats, bed mat, various Baja Design lights, mobtown tailgate reinforcement plate, and a bunch of other stuff.
    Thanks for looking out! I actually already have 2 spare round gaskets from when I installed the URD spec-u exhaust.
  8. Oct 9, 2019 at 10:42 AM
    perkj
    2017 Auto 040B4 (included in ZD Ticket 10472)
  9. Oct 9, 2019 at 10:44 AM
    SK808
    Ewa Beach, Hawaii
  10. Oct 9, 2019 at 10:56 AM
    El Chivo Norteño
    Central Oregon
    The more I learn about these trucks, each ECU / Year is totally different in how they handle the various tunes. I was getting an intermittent Break Override error on 1.5 and 1.5.1 during normal driving conditions. It wasn't until these 2.0 betas came about for that error to go away on my 2019 / 04B31. Hopefully @OVTune has a solution to this new problem for your truck/ecu. My guess is what ever throttle adjustments were done to fix the error on 04B31 is now causing errors on your 04B04.
    perkj[QUOTED] and G8R_Taco like this.
  11. Oct 9, 2019 at 11:06 AM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    I'm not sure but I thought the Brake override malfunction on our 2019 04B31 ecu's had to do with the OVtune throttle code and the fact that we have the adaptive CC which acts directly on the throttle. 2017's don't have radar cruise If I'm not mistaken. This is the first I have heard of this as a result of trying to flash. I know you @El Chivo Norteño and I only experienced the malfunction while driving after a successful flash. Very interested to see how this works out. Good luck @perkj .
    Edit: Have you checked what the DTC is that illuminates the CEL? Ours was a P2119 having to do with throttle valve positon not being where it is expected to be.
  12. Oct 9, 2019 at 11:13 AM
    perkj
    I didn't pull the DTC code unfortunately. Thanks for the clarification on your issue....clearly not the same as mine. Hoping Matt (@OVTune) is able to assist once they look at my ticket as I'm still awaiting a response on it...submitted back on 10/5 (ZD #10472)
  13. Oct 9, 2019 at 11:15 AM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    It should still be there unless your truck is at the dealership. You can check with the p5 flash utility if you are not a dongle user or of course any scanner will work. Very interested to know what that code is.
    Can you still pull it?
    Edit: I see you are a dongler. :D Techstream or scanner then.
    El Chivo Norteño likes this.
  14. Oct 9, 2019 at 11:28 AM
    G8R_Taco
    FLA
    2019 TRD OR 4x4
    @perkj can you flash the stock tune successfully?
  15. Oct 9, 2019 at 11:37 AM
    El Chivo Norteño
    Central Oregon
    Ah didn't know the '17s didnt have radar cc. yeah this is a totally separate issue then.
  16. Oct 9, 2019 at 11:43 AM
    perkj
    Here is where I am with this issue. When I faced this same issue on 16012, @OVTune had me do a Clear DTC, turn off truck, start truck and verify no CELs, then proceed with flash. This procedure corrected the flash of 16012. When I attempted 19800, the first attempted ended with just the immediate "unsuccessful" (no CEL or brake override malfunction message). After a second attempt, the end result was where I got not only the "unsuccessful" immediately but also the CEL & brake override malfunction. From this I performed the same procedure Matt gave me for when I ran into this issue on 16012. After running thru the procedure, the next flash attempt ended with the immediate "unsuccessful" with no CEL/Brake override. I assumed a second attempt would result in the CEL popping up again, so rather than risk getting into that state again I opened the ZD ticket (10472) and awaiting guidance from Matt. As the truck sits now, I have 16012 installed and the truck is running as expected with no CEL and no Brake Override
    Malfunction message.
    Below is exactly what I sent to Matt via ZD 10472:
    2017 Tacoma Pro Automatic with 04B04 ECU. Stock vehicle.
    I attempted to install the latest 2.0 beta today 19800 w/91 oct for 04B04. I’m a dongle user. When PCM Flash attempted install, it ended within seconds with unsuccesssful right after what I believe is hearing the fuel pump getting energized or some noise from under the truck. I tried again and same thing but this time I got a “brake override malfunction” error on my dash and a permanent CEL. I had this exact same problem with the previous octane learning beta build. From that ticket you had me to a Clear DTC, shut the truck off, verify no CEL, and then retry flash. At that time the retry was successful. So as instructed last time I did a Clear DTC, shut the truck off, verified no CEL, and then tried again. This resulted in the same unsuccessful message within seconds...though no brake override malfunction or CEL. Rather than trying again which I assume would likely trigger the brake override malfunction and CEL, I’m submitting the ticket. Clearly there is something going on as I never had this issue prior to the last beta build and it continued with this one. Hoping you can help determine why for the last two beta build this issue is happening and at present preventing me from installing the latest beta.
  17. Oct 9, 2019 at 11:48 AM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    Have you tried flashing it back to stock, or one of the 1.05 tunes?
  18. Oct 9, 2019 at 11:51 AM
    perkj
    see my post one thread up. No I have not tried stock or 1.05...I'm awaiting guidance from Matt for ZD 10472 I submitted on 10/5.
  19. Oct 9, 2019 at 12:29 PM
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    Look back a couple pages. The PCM version of 19800 was an error and the link for it has been removed. Do not try to use it anymore...
  20. Oct 9, 2019 at 12:32 PM
    perkj
    I didn't see Matt said it was posted in error, rather he just forgot he posted it and accidentally removed it. There has been confirmation of several dongle users having successfully installed 19800 pcm.
    paleh0rse likes this.
Thread Status:
