Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Oct 13, 2019 at 11:00 AM
    Chipi3s
    Chipi3s Does it rub?
    San Diego
    Not submitting a ticket yet as im trying to gather more info, but i wanted to know if anyone else has had this issue with the latest 19800 beta (04b04).
    I will be driving (speed does not seem to matter) and ill give about 70-80% throttle and the rpm will climb to 5k and drop to 4-4500k then literally bounce back to 5k. It seems like maybe torque converter issue possibly? I need to recreate this issue a few more times b4 making a ticket. Anyone have something like this happen?
    conceptmachine likes this.
  2. Oct 13, 2019 at 12:02 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Well it seems like you could purposely avoid it too.
  3. Oct 13, 2019 at 12:38 PM
    Dirk_Pitt
    Dirk_Pitt Well-Known Member
    Carrollton, GA
    2017 Barcelona Red Tacoma Limited
    On my "all factory stock" 2017 Limited, 10867 has been the best too. My only complaint with it is the tip-in.
    I currently have about 700 miles on 19800 91 octane, but the 2-3 and 3-4 early shifting feels like the stock programming.
    G8R_Taco and El Chivo Norteño like this.
  4. Oct 13, 2019 at 1:59 PM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    I hope Mat comes out with a 19770 for 87 octane. That alone should soften the tip-in a bit. I have had no issues whatsoever with 19770 including the dreaded brake override malfunction disaster. 2.0 has eliminated that issue altogether. And the 2-3 and 3-4 shifts are appropriate for given throttle pedal input. Easily modulated with throttle pressure. Head and shoulders above any other beta thus far. 19800 was a dud for me. Thanks again Mat!
    Slammer6 and El Chivo Norteño like this.
  5. Oct 13, 2019 at 2:08 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    OG there!
  6. Oct 13, 2019 at 2:20 PM
    L-SCHLEGS
    L-SCHLEGS Well-Known Member
    Nashville, TN
    2017 CEMENT TRD PRO
    Anybody installed CATTED dump tubes with URD Y pipe yet? I’m pulling PO420 and PO430 check engine codes with this combo.
    Anybody else have this setup and getting these codes?
    Trying to figure out if I have a leak or some other issue or if it is just the combo of these pipes...
  7. Oct 13, 2019 at 2:20 PM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    100% agree
    19770 on 04B31 premo! Crossing fingers Mat makes an 87octane tune on this 2.0 build.
    Slammer6 and G8R_Taco[QUOTED] like this.
  8. Oct 13, 2019 at 2:48 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Yeah, there is something off with 2-3, 3-4 shifts on 19800. I drove on 92 and currently on 87 octane and got the same exact behavior. I see more falling flat on 2-3 shift.
    Driving in stop-n-go traffic is getting annoying.
    Other night was driving and noticed if in 6th, tc locked, absolute throttle position is limited to 43.9%. Kept pushing slowly and it would not advance, cycling between 40%?? and back to 43.9%
    Chipi3s likes this.
  9. Oct 13, 2019 at 3:27 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Did you see my post about the exact same issue. Matt replied with a solution that solve my problem. Look one page back.
  10. Oct 13, 2019 at 4:27 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    There is no difference with the shift tables between 19770 and 19800.
    0.00% difference.
    If you are seeing a difference in how it shifts it is because of the given throttle angle.
    Throttle angle at a given speed will change the shift point, on top of the shift limits for a given speed.
    in the end I think the best solution is going to be a 19770 type of build with a 19800 1rst gear throttle map
    perfect shifting in every possible situation / rpm / drive speed / throttle angle simply is impossible. We can play with this transmission forever.....
  11. Oct 13, 2019 at 4:59 PM
    thedriza
    thedriza Well-Known Member
    Portland, OR
    2017 Tacoma DCSB
    5.29 gears, OME HD lift, OVTune
    In @OVTune We Trust
  12. Oct 13, 2019 at 5:08 PM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    That’s a little much
    Spike91321 and FritoBandito like this.
  13. Oct 13, 2019 at 5:16 PM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Clear LVs. Fixed my issues with falling flat.
  14. Oct 13, 2019 at 5:35 PM
    Local_Smokey15
    Local_Smokey15 Well-Known Member
    Atlanta
    16 Silver DCSB sport 4x4
    AudioControls lcq, JL 13tw5, JL 500\1 and JL 300\4 on JL door speakers. 5% tint all the way around. 5500k HIDs and a 3 inch lift with 33s. Firestone ride right air bags. Black Oak LED 30 inch SR and spartanx hoodscoop LED.
    I think that’s what I did. When I couldn’t get it to work last week I unhooked everything and cranked the truck to see if it still worked. When I came back it worked. Must have hit clear dtc before I walked away the first time.
  15. Oct 13, 2019 at 5:42 PM
    RushT
    North Texas
    Oooh, I like the way you think.
    I’ve been missing the excellent throttle response of 19700 once above 20mph. Town cruising and Texas highways were great.
    I’ve been trying to figure out how to ‘suggest’ a throttle map edit, but didn’t want to come across as ‘that guy’. I can only assume you’ve tried it all. I didn’t know if a switch to a logarithmic (yes, log) curve vs linear would help? Or perhaps a linear quadratic that is initially exponential but turns linear after some value?
    I don’t know about tuning tables, but I do know a bit about curve fitting and response functions.
    Perhaps there’s just not enough resolution in the tables for this approach to work. Or maybe the best method is your empirical hand fitting of the tables to match the desired acceleration.
    Keep on keepin’ on Mat! :hattip:
  16. Oct 13, 2019 at 5:43 PM
    ohioboater
    ohioboater Well-Known Member
    2017 DCLB 4x4 Sport
    Which I will, now that I've documented the issue. This is a beta, after all - the whole point is to identify issues.
    Mike O, Shellshock and Turd Hawg like this.
  17. Oct 13, 2019 at 6:17 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Did you update pcmflash?
    Here are Matt's instructions. Follow them exactly.
    Do this:
    First, make sure you have the latest version of pcmflash (if it needs to update then update it. *generally this isn't a problem, but good to try)
    Turn your truck on, click CLEAR DTC in pcmflash
    shut the truck off
    START THE TRUCK for 1-2 mins
    shut the truck off
    turn the truck on
    try to flash
  18. Oct 13, 2019 at 6:47 PM
    Vlady
    Issy, WA
    I think even the exrapolation will work. And I'm being serious. Cause it does make sense why changing one parameter is throwing the whole calibration off from driver's prospective.
    ...and yes, I did reset values about 250 miles ago...
  19. Oct 13, 2019 at 7:06 PM
    RushT
    North Texas
    Perhaps if 'tip in' value was a linear multiple of speed somehow? So zero mph gets the minimum tip in, and the faster you go, the more aggressive tip in gets. It would be linear, with a non-zero intersection, perhaps with a maximum value. I'm sure Mat's got reasons why this theory won't work, but who knows... sometimes you get ideas from the zombies and improve on them. Maybe it's as simple as the 'tip in' calculation can't access speed values, or 'tip in' is hardcoded into tables and that's that. :confused:
    Mods... can we get an 'I dunno' icon :)
    <edit> here he is.... :notsure:
    Vlady likes this.
  20. Oct 13, 2019 at 7:10 PM
    Deucer01
    Deucer01 Well-Known Member
    North Georgia
    2023 Tacoma ORDCSB 4x4, 2024 4runner TRD ORP
    :notsure:
    Spike91321 and RushT[QUOTED] like this.
Thread Status:
