Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Nov 12, 2019 at 3:43 AM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Cc in S5 w/ GL holds for me. S6 will too unless the grade drops the rpms enough to force a shift.
  2. Nov 12, 2019 at 6:22 AM
    BFRT_King Ranch
    BFRT_King Ranch Well-Known Member
    Northern VA
    '18 Cement TRDOR DCSB
    Lucky you, not me. 75 and going over a overpass GL in 5 and will still drop to 4. Maybe it's fixed in final 2.0 but love it either way.
  3. Nov 12, 2019 at 6:36 AM
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    Based on what I've read here and emails via ZenDesk, we can use our HH whenever the "ECU lock" error is fixed by OpenFlash. I did find the link to OVT's instructions, but they won't work until that error is fixed. This was never communicated to me as a HH purchaser, I only learned this by reading here.
    I would hope that OVT would contact HH owners, but haven't heard of such a plan.
    MrWednesday likes this.
  4. Nov 12, 2019 at 6:39 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Correct, but that's only on 2018+ Trucks, and we sent an email out for all orders regarding that. There are still some I need to reply to though
    So that nobody is confused the accessory handheld is not included in this, and those are to be updated with 2.0.
  5. Nov 12, 2019 at 6:44 AM
    jerzsubbie
    Davidson, NC
    ‘13 GX460
    Sorry but can you clarify what you mean by the "accessory handheld"? Is this for those who already have the tune via dongle or tactrix, and THEN purchased the HH?
  6. Nov 12, 2019 at 6:45 AM
    OVTune
    OVTune
    The accessory handheld is the handheld version for people who already own the flash kit, and is ONLY for those customers.
    if there is still confusion it will all be cleared up on the 15th on our site
  7. Nov 12, 2019 at 7:45 AM
    gozfast
    gozfast Member
    So, to be clear, on the final 2.0, I will not be able to access map 3 "tow mode" (ECT+S mode) without using gear lock? I tow 5000# pretty regularly and would still like the truck to shift on its own as required. Towing with the stock tune was ECT with S mode in S4 or S5 to lock out the over drive gears, but still had auto operation.
    Mike O, Turd Hawg and paleh0rse like this.
  8. Nov 12, 2019 at 7:50 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    I think there will still be non-gearlock versions of the tune, but that part of the info is a bit murky/confusing. I'm not sure what the AT maps/options will look like when there's no gearlock at all.
    I personally don't want anything to do with GL -- especially when towing!
    xxTacocaTxx and Turd Hawg like this.
  9. Nov 12, 2019 at 7:55 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Manitoba
    3G, Tuned
    I believe that with 2.0 final, gear lock will be an option you’ll select when downloading on FM. Some will want the gear lock feature, some won’t.
  10. Nov 12, 2019 at 8:00 AM
    uptaco
    uptaco Well-Known Member
    Adam
    Pittsburgh, Pennsylvania
    '19 Cavalry Blue OR 6A DCLB
    Is it clear that on Nov 15 everything will be available for sale again? Same pricing as before the shutdown? Will shipping times be any better or still on the order of weeks? Are free updates gone for good because of trolls?
    Edit: Black friday deals?
  11. Nov 12, 2019 at 8:06 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    It will still downshift when the rpm and speed drop too low, and it will not upshift past the gear you select. When you come to a stop, it will upshift through the gears until you get to the gear you lock on, you don't need to shift up through the gears yourself.
  12. Nov 12, 2019 at 8:10 AM
    OVTune
    OVTune
    Our prices will not be changing. Just a different structure to how things are done, and some new products.
    We will be having a sale yes.
    Free updates are not gone
  13. Nov 12, 2019 at 10:46 AM
    Stoked4
    Stoked4 Well-Known Member
    2017 trd sport DCLB (OVtuned)
    Not getting it from website to computer
    How do I know if the last TVs I got from Toyota is the latest one?
  14. Nov 12, 2019 at 11:07 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Mat - ETA on handheld instructions? is it going to be the 15th / whenever, or should i keep refreshing my emails?
  15. Nov 12, 2019 at 1:33 PM
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    Getting 5:29 and OVtune installed tomorrow. 2019 auto double cab.
    Running 35’s with amour.
    Any input on which tune I should run with this setup? Base or performance with gear lock? Shop owner is telling me he has had a few similar trucks recently start with performance but brought back in shortly after to switch to base. ‍♂️
    Anyone with a similar build have any input? The shops 4hrs away so I’d like to get it right the first time.
    Question concerning the Performance gear lock... can it be locked (ect button) on the fly or does it have to be shifted i to “S mode” from a dead stop?
  16. Nov 12, 2019 at 1:45 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    On the fly I believe but would wait for others to confirm, I’m not on latest GL.
    mAtTyG04[QUOTED] likes this.
  17. Nov 12, 2019 at 1:50 PM
    OVTune
    OVTune
    beta version of 2.0 for 2019s
  18. Nov 12, 2019 at 3:03 PM
    wiljayhi
    Jim
    Manitoba
    3G, Tuned
    Mine works on the fly in D or S mode. Turns on and off with ECT on and off. (2.0 beta 19800).
  19. Nov 12, 2019 at 3:49 PM
    Cricketeer
    Cricketeer owned by bird dogs
    Jeff
    Everett, Washington
    2017 Inferno DCLB TRD OR
    Leer 180, Bilstein 6112/5160, OME Dakars, OVTune
    Since beta file sharing is okay, can these be sent through e-mail to another person who has already bought in, but, say, missed a tune they want to try but missed?
    "asking for a friend"
    If not, how are you sharing?
  20. Nov 12, 2019 at 3:57 PM
    awdvkd115
    awdvkd115 Well-Known Member
    Bud
    2017 Tacoma TRD OR
    Toytec lift, White Knuckle sliders, RCI Armour, ECGS (Nitro Gears), Victory 4x4 Striker Front bumper, Smittybilt X20 10K winch, Dobinson snorkel, Spidertrax 1.25 spacers and 255 R80 16 BF Goodrich KM2s.
    Yes I wish there was a place to get some of the old tunes. I was hoping they would just keep adding them and not take them down. I was 04B03 for a long time until I shamed the dealer into doing update. I should have just been storing them the whole time but by the time 04B03 was abandoned for 04B04 it was to late. It was against the rules for a long time to share the files. If anyone has them all I would like to figure a way to get them all especially the 105. And early ole 2.0.
Thread Status:
