Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Dec 23, 2019 at 1:41 PM
    Nomis88
    Nomis88 Well-Known Member
    max
    17 taco
    thanks, if anyone is around the Bend, Or I’ll grab you a case of whatever brew to get my ECU up to date
  2. Dec 23, 2019 at 2:06 PM
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    tonered likes this.
  3. Dec 23, 2019 at 2:09 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Where are you? It's not too bad to do yourself if you want to.
    tonered likes this.
  4. Dec 23, 2019 at 3:10 PM
    Nomis88
    max
    17 taco
    I’m always down to tinker. This is my first Toyota, but coming from the Audi world you needed a $300 cable to reprogram the car
  5. Dec 23, 2019 at 3:11 PM
    lapoltba
    CT - 06076
    VCDS is worth it though. You have the Tactrix cable and here's the software \/\/\/\/\/, Go wild!
  6. Dec 23, 2019 at 3:41 PM
    Nomis88
    max
    17 taco
    100% worth it, nothing like getting factory hidden features for free. Bomb.com, so my OVTune cable is essentially like VCDS for the taco?
  7. Dec 23, 2019 at 3:50 PM
    Shellshock
    Iowa
    Yes. The tactrix cable can be used with techstream no problem
  8. Dec 23, 2019 at 4:37 PM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    I’ve asked Mat multiple times via Zendesk with no response, so I’ll ask you guys instead. I assume that the ECU file I read from my truck and sent to Mat when first registering my license *is* my stock Toyota tune file, correct? So if I want to flash back to stock I can just use that file?
  9. Dec 23, 2019 at 4:43 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I don’t think the whole ecu file is read, only the file version (could be wrong here so wait for confirmation). But, flash manager should have the stock file for your original calibration and you can use that file if you haven’t had any tsb’s applied.
    xxTacocaTxx likes this.
  10. Dec 23, 2019 at 4:45 PM
    dpippel
    Phoenix, AZ
    Thanks. It’s a 2020 with no TSBs applied. I’ll check it out. Appreciate the info.
  11. Dec 23, 2019 at 4:52 PM
    dpippel
    Phoenix, AZ
    No bueno. Flash Manager doesn’t have anything for the 2020 yet. AFAIK the only files Mat’s released for it are the 2.0 19800 beta tunes, which are direct downloads not done through FM.
    So, I guess I’ll try Zendesk again to see if I can get a copy of my stock tune.
  12. Dec 23, 2019 at 4:55 PM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    It's been a couple of years since I did this but I was able to make a copy of the existing stock tune before writing the tune. (But mines a 2016)
    Edit: I know once the tune is applied, you cannot read the file, to protect his IP. But before the tune, I believe you can.
  13. Dec 23, 2019 at 4:56 PM
    dpippel
    Phoenix, AZ
    Too late for me there.
  14. Dec 23, 2019 at 4:57 PM
    PhogDog
    20 MGM Sport
    Pretty sure he'll add it to the app. He has for all the other versions.
  15. Dec 23, 2019 at 5:02 PM
    dpippel
    Phoenix, AZ
    Eventually I’m sure. Doesn’t help me now though.
  16. Dec 23, 2019 at 5:06 PM
    lapoltba
    CT - 06076
    Sort-of. Techstream allows some customization, but nothing like the coding you can do with VCDS.
  17. Dec 23, 2019 at 5:25 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I'll send you the stock file in the morning if you need it.
    dpippel[QUOTED] likes this.
  18. Dec 23, 2019 at 5:31 PM
    dpippel
    Phoenix, AZ
    Thanks Mat! Please do. Happy Holidays, and I hope that arm of your heals quickly!
  19. Dec 23, 2019 at 6:12 PM
    RushT
    North Texas
    Sorry, totally missed that it was a 2020.
  20. Dec 23, 2019 at 6:16 PM
    Amchuge
    Amchuge Well-Known Member
    2018 Tacoma trd pro
    With Mats recent injury, the holidays, and the OVtune shop being closed, does anyone know if they are still sending out Tunes?
Thread Status:
