Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 9, 2020 at 6:02 AM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    Bootcamp is part of macOS so has no cost associated with with it, but it carves out a permanent (until you remove it) chunk of your drive for the Windows partition. You have to decide how much drive space to allocate to it at the time you install Bootcamp, and once you do it's a royal PITA to change.
    Parallels costs money, but since it's a virtual machine manager, your Windows installation is basically just a file sitting on the macOS filesystem. You can dynamically change the amount of disc space available to Windows with Parallels, which is handy if your needs change. If you decide to get rid of it, Parallels is much easier to uninstall than Bootcamp is. Parallels also has some nifty cross-platform functionality that Bootcamp lacks.
    Be aware that both require a licensed copy of Windows to work, so if you don't have one on-hand you'll have to buy that as well.
    Bunk Moreland[QUOTED] likes this.
  2. Jan 9, 2020 at 8:19 AM
    BloodyTesla
    BloodyTesla Active Member
    17 TRD OR
    It looks like that’s just the desktop shortcut.
    Parallels has generally been better than VMWare for the Mac. Benchmarks are normally better for Parallels and the features are more mature.
  3. Jan 9, 2020 at 8:24 AM
    Shellshock
    Iowa
    I disagree 100%. I started with parallels back in the day and moved over to vmware. It’s been much more stable and has had better driver and pass through support. I use fusion on a near daily basis.
    BlkTaco47 and GreyBaldTaco like this.
  4. Jan 9, 2020 at 8:39 AM
    ridinhigh95
    ridinhigh95 Member
    Blake
    South Carolina
    2018 Super White Tacoma TRD Off Road AT
    Ovtune 1.05
    Waiting for official Ovtune 2.0 to drop like
  5. Jan 9, 2020 at 8:42 AM
    cstern1
    cstern1 Well-Known Member
    Caleb
    KCK
    2017 DCSB Sport
    I couldn't get the tactrix cable to recognize on a VM I had. Local machine wasn't getting the pass through on the tactrix. Running a Windows 10 VM on an Unraid server, which is Linux. I assume it was a driver issue and support for the tactrix may have been limited on the platform I was attempting.
    It made more sense to me to spin up a VM on a server and try to tie my OV license to it instead of my laptop.
  6. Jan 9, 2020 at 8:44 AM
    uptaco
    uptaco Well-Known Member
    Adam
    Pittsburgh, Pennsylvania
    '19 Cavalry Blue OR 6A DCLB
    If its a VM then its a VM... I think the license would move with the VM and not the hardware the VM is running on.
  7. Jan 9, 2020 at 8:48 AM
    cstern1
    Caleb
    KCK
    2017 DCSB Sport
    That was the idea. I just couldn't get the tactrix to show up. I guess I had that wrong in my prior post. The tactrix wasn't being passed from local machine USB port to the VM. I will admit I don't know much about the virtual USB drivers for the VM I was using. I figured remote into VM on my laptop so I could use any laptop in the future.
  8. Jan 9, 2020 at 8:48 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just curious. Is your server on wheels, or were you planning in using a long USB extension to connect?
  9. Jan 9, 2020 at 8:49 AM
    cstern1
    Caleb
    KCK
    2017 DCSB Sport
    RDP connection from laptop to VM on server.
  10. Jan 9, 2020 at 8:50 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I could be wrong here, but I don't think the license software will play nicely like that?
    Note that @OVTune allows you to request upto three REG files for other System IDs. I thought our old laptop was going to be more or less permanent, but I got a surprise upgrade. It was very easy to get another REG file.
  11. Jan 9, 2020 at 8:51 AM
    Shellshock
    Iowa
    ew no. would not recommend.
    SC4333, xxTacocaTxx and tonered like this.
  12. Jan 9, 2020 at 8:51 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I caught that in your second post. Like I said, my guess is that won't play well.
  13. Jan 9, 2020 at 8:51 AM
    cstern1
    Caleb
    KCK
    2017 DCSB Sport
    It didn't. Was worth a shot.
  14. Jan 9, 2020 at 8:52 AM
    cstern1
    Caleb
    KCK
    2017 DCSB Sport
    I use RDP daily. Not sure why the no recommendation.
  15. Jan 9, 2020 at 8:54 AM
    Shellshock
    Iowa
    USB connections over the network is always sketch.
  16. Jan 9, 2020 at 8:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Keep the resources local.
  17. Jan 9, 2020 at 8:55 AM
    cstern1
    Caleb
    KCK
    2017 DCSB Sport
    Oh that. I thought you meant the connection type in general. I was skeptical it would work since I needed it stable to write to the truck ECU.
  18. Jan 9, 2020 at 9:00 AM
    sorevilo
    sorevilo Well-Known Member
    Running the 2.0 beta and that is smooth can't wait for the official :annoyed:
    Shellshock likes this.
  19. Jan 9, 2020 at 9:03 AM
    Shellshock
    Iowa
    oh no. RDP is fine for a lot of stuff, well unless you have high latency or packet loss :smash:
    You definitely want local resources for flashing as @tonered said
    tonered likes this.
  20. Jan 9, 2020 at 9:04 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
Thread Status:
