Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 15, 2020 at 12:37 PM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    Listed as 91 but I’ve been running 89 with no issues.
  2. Jan 15, 2020 at 12:39 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Id run it with 91 or higher. Not recommended to run lower octane unless you are running the 87 tune in the mountains at elevation and only have access to 85.
    This was asked before. The first one I found is above
    And Mat said:
    "It will detonate"
    "We do not recommend it"
    Umm.....
    GreyBaldTaco and xxTacocaTxx like this.
  3. Jan 15, 2020 at 1:07 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Regarding 2.0.
    It is still actively being worked on, and a few things are being changed around.
    Also we received information that there …. *may be* another software update regarding this fuel pump recall with trucks that "stall at high speed"... (possibly another ECU reflash).
    We also are working on our own replacement fuel pump controller.
    We are doing a lot of code changes to the PI and DI system, due to how the fuel pump control works, this will benefit N/A as much as it does boosted scenarios.
  4. Jan 15, 2020 at 1:09 PM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Thanks Mat, we like getting these periodic updates when there's still work ahead...thanks for this one.
    SandyTaco4x4, LTacoman and AKGSD like this.
  5. Jan 15, 2020 at 1:13 PM
    fxrman
    fxrman Well-Known Member
    palm springs
    Quicksand 2016 trd double cab off road
    OVT 1.03 Tacoma bed matt Husky floor liners Insain fab aluminum bumper with Baja design s8 30" light bar DB custums grill with Baja design s8 30" light bar
    PCM is for dongles?
  6. Jan 15, 2020 at 1:15 PM
    riz_atx
    Sohail
    Spicewood Texas
    Yes
    fxrman[QUOTED] likes this.
  7. Jan 15, 2020 at 2:22 PM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    the drop down menu In the FM shows 1.05, 1.05.1, and some version of 2.0 as options for my vehicle. These are all “base” versions but they are 3 different versions available?
  8. Jan 15, 2020 at 2:23 PM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    The 2.0 you see in FM is just a placeholder. The only way to get 2.0 is by direct download from OVTune's website.
    xxTacocaTxx likes this.
  9. Jan 15, 2020 at 2:25 PM
    TacoTime850
    2019 DCSB 4x4
    Thank you for the info.
    Which version is best for my 2019, 1.05 or 1.05.1?
  10. Jan 15, 2020 at 2:27 PM
    marinemonkey
    marinemonkey Instagram - @tacomaturner @torxfabrication
    Cory
    Canton
    2016 Blue Toyota Tacoma TRD Off Road 4x4
    All-Pro Apex sliders Mobtown full skids SCS Ray 10s brushed copper Chevy 63 swap
    I have a 16 Tacoma and 04B04 ECU but when I download the tunes I can not pick 16 with 04B04, I have to pick 17. Will this be a problem? Should I ask this here or send this to the zendesk or whatever? Thanks for the help
  11. Jan 15, 2020 at 2:28 PM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Correct, go to 17
  12. Jan 15, 2020 at 2:30 PM
    dpippel
    Phoenix, AZ
    1.05.1 is only intended for vehicles experiencing the "shudder" described at length in this thread. If your truck exhibits this then that version might be for you. If not, just 1.05. Of course, you can also download one of the 2.0 beta tunes as well:
    https://www.ovtuned.com/pages/2-0-public
    as long as there's a version for your ECU.
    Cricketeer likes this.
  13. Jan 15, 2020 at 2:36 PM
    TacoTime850
    2019 DCSB 4x4
    Great! Thank you very much for the simple explanation.
    dpippel[QUOTED] likes this.
  14. Jan 15, 2020 at 2:38 PM
    dpippel
    Phoenix, AZ
    You bet! Happy flashing!
  15. Jan 15, 2020 at 3:22 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Just got done flashing my truck to the 91 octane 2.0 Beta a little while ago. Overall the process was very easy and not confusing in the least. I did the LV and AT reset after the flash, let it idle for 15 min, and then took it for a quick spin.
    First impression is that the transmission is greatly improved over stock (04B61) imo, and I no longer have the clunk when I stop for the first time on each drive. It's completely predictable now, and while I wasn't too sour on the stock programming it really is a big improvement using the 2.0 beta flash. I can't wait to take it for a longer drive and out onto the highway to see how it runs.
    Thanks for the help with documentation @PhogDog
  16. Jan 15, 2020 at 4:02 PM
    Cricketeer
    Cricketeer owned by bird dogs
    Jeff
    Everett, Washington
    2017 Inferno DCLB TRD OR
    Leer 180, Bilstein 6112/5160, OME Dakars, OVTune
    DUDE! I'm not sure a guy in a bathrobe should be saying, "Happy flashing!"
    GreyBaldTaco likes this.
  17. Jan 15, 2020 at 4:04 PM
    dpippel
    Phoenix, AZ
    AKGSD, paleh0rse, wahoobie and 2 others like this.
  18. Jan 15, 2020 at 4:07 PM
    Cricketeer
    Jeff
    Everett, Washington
    Ah, I see you come from a long line of guys in bathrobes. I'll warn my wife before we park our Crickets next too each other. Of course, that just means she'll keep the windows open, watching.
    paleh0rse likes this.
  19. Jan 15, 2020 at 4:10 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Was the shitter full?
  20. Jan 15, 2020 at 4:11 PM
    dpippel
    Phoenix, AZ
    :crapstorm:
Thread Status:
