Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 20, 2020 at 3:17 PM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    Can't recall, can someone chime in? Did he get his code changes incorporated with adaptive cruise? If not, that's probably your issue. ??
    Shellshock likes this.
  2. Jan 20, 2020 at 3:29 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Are you using adaptive cruise control ? ACC will screw with the tune and produce results like you’re stating.
    How about ECT? I’m running 2.0 beta, 19800 and switch on ECT when travelling at highway speed. No issues for me.
  3. Jan 20, 2020 at 3:32 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    If you turn ECT on while in D it can't downshift...
  4. Jan 20, 2020 at 3:34 PM
    PhogDog
    20 MGM Sport
    If you are talking about gearlock...it doesn't work in Cruise Control, won't lock
    I wish it did
    GreyBaldTaco[QUOTED] likes this.
  5. Jan 20, 2020 at 3:35 PM
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    I once had an average size 100w tiltable solar panel on top of my ARE camper. Folded down it sits about 4" high.
    It dropped me an easy 2mpg at highway speeds. I was running 1.04 at the time. Wind drag is just that - a drag.
    Anything catching the wind in most trucks will significantly reduce mpg. Just a fact!
  6. Jan 20, 2020 at 3:35 PM
    GreyBaldTaco
    2019 F150 5.0
    Interesting, I was in D, not using cruise control and pressed ect out of old habit just this weekend, took me a second to figure out what was happening.
  7. Jan 20, 2020 at 3:36 PM
    PhogDog
    20 MGM Sport
    I'm saying it won't lock WITH cruise control
  8. Jan 20, 2020 at 3:37 PM
    wiljayhi
    Jim
    3G, Tuned
    It can’t be commanded to downshift with a peddle depression but you can get your downshift from 6 to 4 by pulling the shift lever to S from D. 2.0 final remedies this.
  9. Jan 20, 2020 at 3:42 PM
    GreyBaldTaco
    2019 F150 5.0
    Yes I know, I was just explaining my experience this weekend.
    PhogDog[QUOTED] likes this.
  10. Jan 20, 2020 at 3:46 PM
    PhogDog
    20 MGM Sport
    I'm thinking you can press CC twice to use Cruise w/o the adaptive...I'm thinking I read his code works in that manner. ?? Unsure, but you might give it a try. I may have dreamed I read that though . Mine is a '16 w/o the adaptive cruise, so I may be talking out of my butt!
  11. Jan 20, 2020 at 3:47 PM
    GreyBaldTaco
    2019 F150 5.0
    I believe it's a long hold of the cruise button.
  12. Jan 20, 2020 at 3:52 PM
    PhogDog
    20 MGM Sport
    Yeah, that's it
  13. Jan 20, 2020 at 5:13 PM
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    I put it in S6 on the highway. I find it hits and holds 6th a lot more than being in “D”
  14. Jan 20, 2020 at 5:18 PM
    SogBecks
    SogBecks Well-Known Member
    2018 TRD Off-Road DCSB
    OVTuned + 2" Lift + 17x9 KMC XD133 Wheels + 275/70 Firestone X/T + TRD Intake + Gibson Exhaust + N2 Designs Remote Start + MESO'd + HS AAL + Alpine Halo 9
    Once you upgrade it, for what it's worth I've put at least a thousand miles each on 16012 & 91 octane 19800, only a couple hundred on 19770 due to tip-in. I'm currently running 16012 and it suits my driving style the best. For one thing, it holds third gear longer. Mine still hunts, but not nearly as bad as stock. I'm lifted with heavy wheels (17x9 - 31lbs each) and tires (55lbs each - E-rated KO2's). I'm at a point where the hunting is self inflicted with all that weight the truck needs to sling around. YMMV.
    Also, I had to figure out how to upgrade the ECU and followed the instructions @tonered had linked to you. I wasn't interested in going to the dealer, because...dealer. I'm by no means a tech genius, but was able to figure it out. Just keep the instructions handy. It makes sense when you're actually plugged into the truck and doing it. Good luck!
    tonered likes this.
  15. Jan 20, 2020 at 5:20 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    Did you do the TSB tune before or after you had OVT? I did it about 8mo before I got OVT.
    If you did it after, how much difference did you feel?
  16. Jan 20, 2020 at 5:36 PM
    SogBecks
    I had OVT before I did the TSB and was running 1.05.1. I did the TSB so I could apply the 2.0 Betas. 04A60 wasn't being released fast enough, so my fear of flashing the TSB was negated by my need to FLASH MOAR TUNEZ!
    tonered[QUOTED] likes this.
  17. Jan 20, 2020 at 5:54 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks.
    I can totally understand that. I think the TSB flashing dropped off until the Betas were posted.
    Flashing is fun.
  18. Jan 20, 2020 at 5:59 PM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    6spd drunked slush box in the Taco, Charger has a NAG1 with a programmer, amd one bike is a 5spd, and one is a 6spd....
    When I get a little time, i will bang it out
    I can be very patient....
  19. Jan 20, 2020 at 7:14 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Missin Tom Leykis flashing Fridays..
  20. Jan 20, 2020 at 7:44 PM
    BlazinBlue
    BlazinBlue Blue Taco Dude
    2018 TRD SPORT DCLB V6 2WD A/T
    @OVTune Please read and reply to the post in the link below about Adaptive Cruise Control, TIA.
    https://www.tacomaworld.com/threads...lopment-thread.495735/page-2773#post-22489081
    blitzkrieg3002 likes this.
Thread Status:
