Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 28, 2020 at 9:57 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Well, then we should be looking at the numbers not the feelings and come to common denominator.
  2. Jan 28, 2020 at 9:58 AM
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    Edit: Looks like shellshock added an important piece of info that I wasn’t aware of. His quote by Mat should answer the questions.
  3. Jan 28, 2020 at 10:01 AM
    Sierra Nevada
    KDMAX Tooooned
    Generally agree. I think the only thing worth commenting on with limited drive time is tip-in. Everything else should wait till at least around 500 miles.
  4. Jan 28, 2020 at 10:02 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Obviously, but this is not the problem.
    The throttle value (open %) does not change from one truck to another.
    So if person A presses the accelerator and throttle opens 15%, to them it's touchy
    and if person B presses the accelerator and throttle opens 15%, it's not touchy.
    Regardless, modifying the throttle angle limits per gear is not very hard to do.
    Regarding reset AT/LV.
    So this isn't confusing
    Resetting LV/AT after a flash = not required
    resetting LV/AT after a flash = is not harmful, and may be done at your discresion
    resetting LV/AT after a flash = Should be done IF you have drivability issues (very odd shifting behavior, very odd engine behavior, or you hear any knock/detonation)
    Resetting LV/AT after a flash = May make the truck run noticeably rougher for the first few miles (especially the transmission)
    Resetting LV/AT should NOT be done just because you feel like doing it.
    Resetting the LV/AT should NOT be done if you haven't recently flashed.
    if you Reset LV/AT right after a flash = the first 25-50 miles of the trucks characteristics can be ignored.
    if you Reset LV/AT right after a flash = the first 25-50 miles of the trucks shifting characteristics can be ignored
    If you Reset LV/AT/ or even flashed the truck and are making judgements without putting AT LEAST 25 miles on the truck, you are not getting an accurate representation of how the truck will perform.
    BlazinBlue, BOMBS, auskip07 and 15 others like this.
  5. Jan 28, 2020 at 10:03 AM
    Shellshock
    Iowa
    This has been a problem since day one. You really need a tank of fuel before making any real judgements.
    There’s been multiple people who will flash a tune, drive around the block, not like it, flash another, drive around the block, not like it, flash another, drive around the block, not like it. Then wonder why their truck is all pissed off.
    Edit: yeah what mat said ^
    Chipi3s, Inferno__Taco, Yeeyo and 3 others like this.
  6. Jan 28, 2020 at 10:04 AM
    Twoplanker84
    Twoplanker84 Well-Known Member
    Walker
    Sacramento
    2017 DCLB TRD Sport
    Icon coil-over Icon UCA 4.88 gears Method 300’s Cooper stt pros 285-70-17
    Thanks!
  7. Jan 28, 2020 at 10:32 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Despite you having said this many times, it still consistently asked. Possibly add this to the first post. Not that anyone will read it anyhow..
  8. Jan 28, 2020 at 10:37 AM
    SpeySquatch
    2016 TRD OR DCSB
    Indeed, I’m still rocking that tune. I do wish there was a 91oct version of it because I fill up 91 regardless ($2.70/gallon)
  9. Jan 28, 2020 at 10:43 AM
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    Just for more input on resetting lv and trans values. I have never tuned yet. Soon! Recently I re geared to 5.29 and added larger 33” tires and suspension. I reset my values To start fresh About 50 miles after mods and changes and right away noticed how rough shifts were. Shifts seemed much longer and would somewhat hesitate especially noticed in the first 4 gears. They Seemed to have smoothed out after a few hundred miles.
    just some info I noticed on a stock tuned 2019 Truck.
  10. Jan 28, 2020 at 10:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thank you. That is a killer post that I am keeping a hold of.
    One question. If we flash and don't do the Resets, the 5min idle is still needed, right? I'm assuming yes, but just confirming.
  11. Jan 28, 2020 at 11:05 AM
    Burmapeak
    Burmapeak Well-Known Member
    Oregon
    2017 Tacoma TRD PRO Cement
    So when do we get to do more WOT runs? Nothing better than when Mat says "Flash the Tune and do a bunch of Full Gas!"
  12. Jan 28, 2020 at 11:15 AM
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    yes, after a flash the idle time is always required
    tonered[QUOTED] likes this.
  13. Jan 28, 2020 at 11:35 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Whenever you are in the mood to! :burnrubber:
    Burmapeak[QUOTED] and johntoyota like this.
  14. Jan 28, 2020 at 11:46 AM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Unless your truck is a weird 2019 like mine. It doesn’t like wide open throttle much. Does fine then seems the fuel is cut at a certain rpm above 6k and falls on its face then seems to regain fuel and begin acceleration again.
    paleh0rse and RyanDCLB like this.
  15. Jan 28, 2020 at 1:11 PM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Idle for 10 minutes IIRC...
  16. Jan 28, 2020 at 1:16 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I've seen various times with five being the minimum. I only flash on a motor that is up to temp. After 4min, I can't feel anything interesting going on. That last minute is just insurance in my mind.
    Tharris242 likes this.
  17. Jan 28, 2020 at 1:43 PM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    tonered likes this.
  18. Jan 28, 2020 at 1:52 PM
    Vlady
    Issy, WA
    Idle learning happens at 176°F of the coolant.
    Warm up truck, park it, flash it and let it idle until RPMs stabilize. About 5 min
    ..and turn air, a/c, butt warmers and dont touch a steering wheel..
    Tharris242 and tonered[QUOTED] like this.
  19. Jan 28, 2020 at 1:54 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep!
    Shellshock likes this.
  20. Jan 28, 2020 at 1:55 PM
    tgarza74
    tgarza74 Well-Known Member
    Mario
    2016 SSM TRD OR
    OvTuned
    Reminds me of this....
    auskip07 and SpeySquatch like this.
Thread Status:
