Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 8, 2020 at 6:33 AM
    Ysrracer151
    Ysrracer151 Okopipi
    Nate
    Huntington beach
    Voodoo tacoma pro
    1.05 base or stock? Personally kinda tired of always worried about this or that. Timelines. Checking for updates daily. It had become part of a schedule. Almost obsessive. Seems unhealthy. Stock and stop worrying.
  2. Feb 8, 2020 at 6:37 AM
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    sorry, but I can't answer that for ya, hopefully one of the 04b31 guys can chime in and help you out. good luck
  3. Feb 8, 2020 at 7:02 AM
    Burmapeak
    Burmapeak Well-Known Member
    Oregon
    2017 Tacoma TRD PRO Cement
    Have you tried a 1.05 BASE Tune? Might have the Tip-In your looking for with no 5700 RPM cut out.
  4. Feb 8, 2020 at 7:12 AM
    Ysrracer151
    Ysrracer151 Okopipi
    Nate
    Huntington beach
    Voodoo tacoma pro
    I drove 1.5 about 6 months ago for a short time. But after matt had been saying 2.0 is better then 1.5 all around. I'm unclear as to fuel learning. Is it currently shut off for 2.0 beta and will be active like the website says for final? Does 1.5 learn fuel consumption? There has been so many updates and confusion with all of it. Information everywhere. It's kinda tedious reading and not knowing if the information is up to date with the tunes and the website doesnt seem to change....... if stock is learning fuel consumption and its shifting better then when I first was driving stock from the dealer why not let it ride for a couple thousand miles and see how it does?
  5. Feb 8, 2020 at 7:14 AM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    Mat only released one version of the 2.0 beta with OLE (Octane Learning Enabled) - 01009. The rest of the betas have been octane-specific.
  6. Feb 8, 2020 at 7:29 AM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    Do Not Use 1.05 or 1.05.1 on a 2019 04B31 truck! I repeat don’t do it, you will enevatabily find yourself in the “Break Overide Malfunction” limp mode. It sure will scare the crap out of you if it happens when trying to enter the freeway while merging in front of an 18 wheeler. Just run the stock factory tune until the 2.0 final arrives.
    Edit - added zeros to version numbers :rasta:
    Burmapeak and G8R_Taco like this.
  7. Feb 8, 2020 at 7:30 AM
    dpippel
    Phoenix, AZ
    1.05 or 1.05.1 - ;)
  8. Feb 8, 2020 at 7:32 AM
    El Chivo Norteño
    Central Oregon
    Ha yes thanks for the correction ... need coffee
    :burnrubber:
    dpippel[QUOTED] likes this.
  9. Feb 8, 2020 at 7:37 AM
    Ysrracer151
    Ysrracer151 Okopipi
    Nate
    Huntington beach
    Voodoo tacoma pro
    See so 1.05 is out of the options too. So for 04B31 literally the only tune that has no issues seems to be stock..
  10. Feb 8, 2020 at 7:39 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Won't be much longer and there will be new final tunes for 2019 and all others.
    I know there is quite a bit people are waiting on.
    I hope everyone likes it when we do release.
    The 2019 is especially odd, it is the only one that does that cut out, using same shift maps as others like the 2020, and only the 2019 has the issue
  11. Feb 8, 2020 at 7:58 AM
    Ysrracer151
    Ysrracer151 Okopipi
    Nate
    Huntington beach
    Voodoo tacoma pro
    No indicators as to why? Any possibilities?
  12. Feb 8, 2020 at 8:06 AM
    J_Hacker
    J_Hacker Well-Known Member
    Somewhere in Virginia
    '19 White Tundra Crewmax
    Bilstein 6112, CB +2 Shackles, Soft Topper, Method 316, 295’s
    So is it not worth buying the OVTune for my 2019 right now? I should wait til the final 2.0 version is released? I’m slightly confused. I think that’s what I’m getting out of the earlier post.
  13. Feb 8, 2020 at 8:09 AM
    Rocinante75
    Rocinante75 Well-Known Member
    2018 TRD Pro Cavalry Blue
    RokBlokz Mud Flaps, TufSkinz tailgate lettering, OV Tuned (1.05!!!)
    If you are going to buy the tune, buy now so you are ready when the final 2.0 drops. You’ll also be able to use the betas before it drops if you want.
  14. Feb 8, 2020 at 8:10 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    I would purchase the tune kit now so you will be ready to flash as soon as 2.0 final becomes available. I suspect there will be a rush of orders slowing down the registration process when it drops from people like you sitting on the fence.
    Shellshock and tonered like this.
  15. Feb 8, 2020 at 8:10 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It depends if you like the idea of saving over $100.00 or not?
    G8R_Taco, SC4333, M1Awolf and 2 others like this.
  16. Feb 8, 2020 at 8:19 AM
    Ysrracer151
    Ysrracer151 Okopipi
    Nate
    Huntington beach
    Voodoo tacoma pro
    Ovtune is definitely worth purchasing now. Even with the all of the beta development. Having the ability to switch tunes, clear codes, clear learned memory, and always being able to go back stock. Witch the stock map is loaded is absolutely nothing like my truck when I first bought it. Stock map from dealer brand new was HORRIBLE. Stock map reloaded after 10,000 miles and trying all the other ovtunes is pretty smooth compared to when I first got it.
  17. Feb 8, 2020 at 8:21 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Buy now with the discount and be ready to tune when it drops, if you like to be prepared and save money that is.
    tonered likes this.
  18. Feb 8, 2020 at 8:25 AM
    ownubad
    ownubad Well-Known Member
    Cory
    2017 Silver Sky OR
    Drop in AFE Pro Dry Filter Inchannel Vent Visors Bedlinered Rear bumper and plastic flares
    https://www.youtube.com/watch?v=ztqn1Q7OGfU
    I know a handful of you on here have found some of my videos useful but here is a month review with 91 2.0 and Over a 1000 miles with OVtune. I broke down the video in the YT comments if you want a specific topic.
    CDK1754, Keegs and Inferno__Taco like this.
  19. Feb 8, 2020 at 8:36 AM
    OVTune
    OVTune
    sale right now, free updates, and 2.0 right around the corner. :)
    Here is the really weird part... and why I can't definitively say "what it is."
    1. I have been compiling data of trucks that have this happen (and report it to us) so I can get info about their tire size, if they are using gears, what octane, etc.
    2. It does not happen on all 2019s, even with IDENTICAL tires/wheels.
    3. It does seem to be *most common* on trucks that are stock except have tires size of : p265/65r17
    4. The shift bog is happening under 6000 RPM, even though the rpm limiter is set at 6800. So it's not coming from a fuel cut (not rev limit cut)
    While reports are limited in these areas, so far :
    1. I have not heard of reports of this happening on our 4.88 version tunes
    2. It does not happen on trucks with 4.88 gears or 5.29 gears
    However, 4.88 and 5.29 gears have their own separate issue (speed limitation in 6th)
  20. Feb 8, 2020 at 8:48 AM
    J_Hacker
    Thanks for all the replies. I’ll purchase ASAP
    ihatemytruck likes this.
Thread Status:
