Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 8, 2020 at 4:39 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Definitely go 88 with the 87 tune and not 86.
  2. Feb 8, 2020 at 4:55 PM
    Markc1024
    Markc1024 Well-Known Member
    You'll be fine with 86 while at your elevation, but if you tend to drive to lower elevations 88 would be a safer bet. Remember the octane recommendations are baselined for sea level. Those of us at higher elevations (6600 ft and 85 octane) are just fine with the grades adjusted for our altitudes.
  3. Feb 8, 2020 at 5:36 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    List of available tables with our 2GR-FKS Tacoma tuning software
    in case you were wondering ^_^
    This list is still being added to. But our software will ship with at least these tables
    Fuel Maps
    Fuel Map Target AFR 1
    Fuel Map Target AFR 2
    Fuel Map Catalyst Adder 1
    Fuel Map Catalyst Adder 2
    Fuel Map Catalyst Adder 3
    Fuel Map Catalyst Adder 4
    Fuel Map Catalyst Adder 5
    Sensor Scaling Tables
    Intake Air Temperature Sensor Scaling
    Engine Coolant Temperature Sensor Scaling
    Oil Temperature Sensor Scaling
    Oil Level Sensor Scale
    VVT Sensor Scaling i-eVVT
    Ignition Coil Dwell
    Port Injector Control Tables
    Port Injector Lag time
    Port Injector Pressure Component
    Port Injector Scaling
    Port Injector Minimum time adder
    Port Injector Voltage Component
    Port Injector Flow Calculation
    Port Injector Target Fuel Pressure 1
    Port Injector Target Fuel Pressure 2
    Port Injector Target 1 Flag
    Port Injector Target 2 Flag
    Port Injection Pre Injection Calculation
    Port Injector Minimum Pulse
    Port Injector Throttle vs Temp Injection Adder
    Port Injector Fuel Pressure Multiplier
    Port Injector Throttle Angle Compensation
    Port Injector Battery Voltage base offset
    Port Injector Base Injector Spray on DFCO Lift
    Limits
    Engine Rev Limiter
    Engine Knock listen Limiter
    Knock Control
    Knock Base Retard
    Knock Magnitude Retard
    Low Pressure Fuel Pump Control
    Base Fuel Pump Duty
    Fuel Pump Max Duty
    Fuel Pump Duty Limits
    Fuel Pump Duty for High OutPut
    High Pressure Fuel Pump Control
    Base High Pressure Fuel Pump Duty
    Fuel Pressure Limit Flag 1
    Fuel Pressure Limit Flag 2 (Minimum)
    Fuel Pressure Required to use Direct Injection
    High Pressure Fuel Pump Sensor Scaling
    High Pressure Fuel Pump Pressure Correction Rate
    Direct Injector Control Tables
    Direct Injection Pressure Target 1
    Direct Injection Pressure Target 2
    Direct Injection Pressure Target 3
    Direct Injection Pressure Target idle
    Direct Injection Fuel Throttle Component
    Direct Injector Fuel Flow Calculation
    Direct Injector Fuel Flow Ratio
    Direct Injector Pressure to Flow Offset
    Direct Injector Pressure Correction
    Direct Injector Minimum Pressure
    Direct Injector Maximum Pressure
    Direct Injector Scale
    Direct Injection Limit for Injection Quantity
    Direct Injection Flow to Time Calculation 1
    Direct Injection Flow to Time Calculation 2
    Direct Injection Pre-Injection Timing Calculation - Crank Angle
    Direct Injection Cold Start Catalyst Stratofied Mix Adder
    Fuel Split Calculation
    Direct Injector to Port Injector Cat Warm
    Direct Injector To Port Injector Split Ratio Target Cold
    Port Injector Target Cranking
    Direct Injection Split Table Byte Flags Coolant Temp
    Fuel Spray Calculation Tables
    Direct Injection Crank Angle Timing 1
    Direct Injection Crank Angle Timing 2
    Fuel Split Angle Table 1
    Fuel Split Angle Table 2
    Fuel Split Angle Table 3
    Fuel Split Angle Table 4
    Fuel Split Angle Table 5
    Air Fuel
    Stoic Fuel Target
    Stoic 02 Sensor Allowance
    02 Sensor Rich and Lean Rough Limits
    02 Sensor Correction Limits
    02 Sensor Rich Target Base
    Mass AirFlow Correction At Idle
    Mass AirFlow Sensor Scaling
    Mass AirFlow Sensor Scaling During High Frequency
    Mass AirFlow Correction Multiplier 1
    Mass AirFlow Correction Multiplier 2
    Mass AirFlow Multiplier Table Flag
    Primary Wideband 02 Sensor Scaling
    Calculated Air Fill
    Calculated Air Fill Modifier for Angle
    Engine Torque Calculation
    Torque Calculation Multiplier for Coolant Temp 1-16 - 4D Table
    Wide Open Torque Calculation
    Engine Torque
    Engine Torque Sport Mode
    Minimum Cylinder Filling VE
    Maximum Cylinder Filling VE
    Cylinder Calculated Fill (one Cylinder)
    Mapped Engine Fill for Multiplier
    Engine Torque AirFlow
    Engine Torque AirFlow 2
    Ignition Timing
    Ignition Timing Efficiency MBT Inverse 1 - 25 - 4D Table
    Ignition Timing Efficiency MBT Calc 1-25 - 4D Table
    Ignition Timing Base Retard
    Ignition Timing Base PI
    Ignitiong Timing Base DI
    Ignition Timing Low Knock PI
    Ignition Timing Low Knock DI
    Ignition Timing High Knock PI
    Ignition Timing High Knock DI
    Ignition Timing Valve Angle Transient Retard
    Ignition Timing Valve Angle Base Retard
    Ignition Timing Limit
    Ignition Timing Adder - Cold Engine
    Ignition Timing Adder - Cold Engine 2
    Ignition Timing Multiplier AirFlow vs ECT
    Ideal Ignition To MBT Inverse 4D Calculation Output Flow 1
    Ideal Ignition to MBT Inverse 4D Calculation Output Flow 2
    Ignition Base Maximum
    Ignition Base Minimum
    Throttle Tables
    Throttle Target based on Calculated Split Torque
    Torque threshold for acceleration
    Throttle Tables For Each Gear
    Throttle Angle Limit based on Coolant Temp
    Throttle Flow Delta 1
    Throttle Flow Delta 2
    Throttle Flow Delta 3
    Throttle Flow Delta 4
    Throttle Flow Delta 5
    Throttle Flow Delta 6
    Throttle Flow Delta 7
    Throttle Flow Delta 8
    Throttle Flow Delta 9
    Throttle Flow Delta 10
    Shift Torque Tables
    Optimatal Torque Model For Shifting 1
    Optimatal Torque Model For Shifting 2
    Optimatal Torque Model For Shifting 3
    Optimatal Torque Model For Shifting 4
    Optimatal Torque Model For Shifting 5
    Optimatal Torque Model For Shifting 6
    Optimatal Torque Model For Shifting 7
    Optimatal Torque Model For Shifting 8
    Optimatal Torque Model For Shifting 9
    Optimatal Torque Model For Shifting 10
    Optimatal Torque Model For Shifting 11
    Optimatal Torque Model For Shifting 12
    Optimal Shift Torque Model High Speed 1
    Optimal Shift Torque Model High Speed 2
    Shift Control Up
    Base Shift Selection Up 1 - 2
    Base Shift Selection Up 2 - 3
    Base Shift Selection Up 3 - 4
    Base Shift Selection Up 4 - 5
    Base Shift Selection Up 5 - 6
    ECT Shift Selection Up 1 - 2
    ECT Shift Selection Up 2 - 3
    ECT Shift Selection Up 3 - 4
    ECT Shift Selection Up 4 - 5
    ECT Shift Selection Up 5 - 6
    Base Acceleration Shift Selection Up 1 - 2
    Base Acceleration Shift Selection Up 2 - 3
    Base Acceleration Shift Selection Up 3 - 4
    Base Acceleration Shift Selection Up 4 - 5 - Lockout
    Base Acceleration Shift Selection Up 5 - 6 -Lockout
    Torque Converter Tables
    Torque Converter Locking speed 1-2
    Torque Converter Locking speed 2-3
    Torque Converter Locking speed 3-4
    Torque Converter Locking speed 4-5
    Torque Converter Locking speed 5-6
    Torque Converter Locking speed 1-2 - ECT
    Torque Converter Locking speed 2-3 - ECT
    Torque Converter Locking speed 3-4 - ECT
    Torque Converter Locking speed 4-5 - ECT
    Torque Converter Locking speed 5-6 - ECT
    Torque Converter Unlocking speed 1-2
    Torque Converter Unlocking speed 2-3
    Torque Converter Unlocking speed 3-4
    Torque Converter Unlocking speed 4-5
    Torque Converter Unlocking speed 5-6
    Torque Converter Unlocking speed 1-2 - ECT
    Torque Converter Unlocking speed 2-3 - ECT
    Torque Converter Unlocking speed 3-4 - ECT
    Torque Converter Unlocking speed 4-5 - ECT
    Torque Converter Unlocking speed 5-6 - ECT
    Valve Timing
    Intake Valve Timing Base
    Intake Valve TIming Angle Limit
    Exhaust Valve Timing Base
    Exhaust Valve Timing Angle Limit
    Idle Control
    Cold Start Idle - Park
    Cold Start Idle - Drive
    Warm Start Idle - Park
    Warm Start idle - Drive
    Hot Start Idle - Park
    Hot Start Idle - Drive
    Gears
    Gear Ratios
    Differential Ratio
    Catalyst
    Exhaust Temperature Model 1
    Exhaust Temperature Model 2
    Exhaust Temperature Model 3
    Exhaust Temperature Model 4
    Chipi3s, G8R_Taco, dpippel and 23 others like this.
  4. Feb 8, 2020 at 5:52 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Phew! That was a lot of reading.
    CorbinDallas likes this.
  5. Feb 8, 2020 at 5:53 PM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
  6. Feb 8, 2020 at 6:00 PM
    Twoplanker84
    Twoplanker84 Well-Known Member
    Walker
    Sacramento
    2017 DCLB TRD Sport
    Icon coil-over Icon UCA 4.88 gears Method 300’s Cooper stt pros 285-70-17
    But what does that mean???
    LstMinutePanic likes this.
  7. Feb 8, 2020 at 6:02 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    You should be able to tune your own truck at the kitchen table
    Tac0Tic0 likes this.
  8. Feb 8, 2020 at 6:12 PM
    SpeySquatch
    2016 TRD OR DCSB
    It means never go full retard, just knock magnitude retard
  9. Feb 8, 2020 at 6:29 PM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
  10. Feb 8, 2020 at 6:41 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Hope that helps the 2019’s :).
    Anyway finally made it home from Florida. Did several wide open throttle full pulls from a stop as well as a roll while towing a trailer with a total weight of around 2300-2400 lbs. 1st - 2nd no issues. 2nd - 3rd, cute out and rev limit kicks in then falls forward then grabs momentum again. Did it every time I tried to test it while towing so towing, for me, doesn’t remedy the dead stick feel when shifting 2nd - 3rd.
    I didn’t bother trying to top it out while hauling a trailer to get it to do the same going from 3-4 but while mentioning 3-4 shift while towing it still shifts too early even with weight on. However, without weight it shifts early and just slows the acceleration process. While hauling a trailer it does the exact same early shift but since it shifts too early, the added weight makes the truck then turn around and downshift back to third since 4th is too tall of a gear while pulling weight to accelerate. Hope this explanation helps.
    paleh0rse likes this.
  11. Feb 8, 2020 at 7:03 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Holy crap that's a lot of tables...
    CorbinDallas, wahoobie and Shellshock like this.
  12. Feb 9, 2020 at 3:44 AM
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    I assume you held back some super proprietary tables, but still, this is quite impressive, if not intimidating. There are very few tables that I personally would consider altering.
    I know that you enjoy this, but finding all of this still has to be very difficult.
    Thanks for all you do, and for sharing it with us.
    Frank
    wahoobie and Tac0Tic0 like this.
  13. Feb 9, 2020 at 5:26 AM
    buckyop
    buckyop Well-Known Member
    2018 Tacoma off-road xp Black maverick edition
    Bets on what day?
  14. Feb 9, 2020 at 5:27 AM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    I’m betting on one that ends in “y”
  15. Feb 9, 2020 at 5:43 AM
    OVTune
    OVTune
    yep, this is not all the tables.
    For my work/tuning, I have access to 2500 + tables on this truck.
  16. Feb 9, 2020 at 5:55 AM
    OVTune
    OVTune
    If you have a 2019 04B31, and 5.29 gears, and would like to do a 5.29 test for us today, please send us a message on Zendesk.
    (Do not message unless you meet the entire criteria, 2019, 04B31, 5.29 gears, available today). After this test we will do a more general release.
    blitzkrieg3002 and Inferno__Taco like this.
  17. Feb 9, 2020 at 6:03 AM
    newdles
    Achmed
    Whenever a test for the stock 04b31 gets a chance I’d like to test to see if the only two issues are remedied. The 3-4 shirt short caused massive shifting issues while towing from Alabama to Florida this weekend and only noticed since this was my first longer haul with 2k-5k. Coming back home was much lighter due to having a dump local to job site to dump shingles but the issue was dreadful while towing.
    By the way the issues were it would constantly dance between 3-4 while towing until truck reached a certain speed. Only way to prevent this was to accelerate hard every time. Downside is while hauling there are times where someone with a load needs to accelerate gradually in order to prevent things from shifting.
  18. Feb 9, 2020 at 6:10 AM
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Sent #13008 thanks for all the hard work Mat!
    OVTune[QUOTED][OP] likes this.
  19. Feb 9, 2020 at 6:23 AM
    OVTune
    OVTune
    Testing shouldn't be necessary for this, it's something we are aware of which will be corrected with 2.0 final.
    fingers crossed we wrap everything up really quick and I get you guys info of all of what has been worked on.
    It's extensive.
    Torque tables for each gear, single torque patch for base transmission calculations.
    different high speed torque tables for gears (stock used are for gears 1, 2, 3, 6) this has been changed and retuned
    just a whole lot.
  20. Feb 9, 2020 at 6:39 AM
    newdles
    Achmed
    Sounds great ty!
Thread Status:
