Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 9, 2020 at 7:08 PM
    cdoghump
    cdoghump Well-Known Member
    Amarillo, TX
    17' TRD OR DCSB 4x4
    Is the TSB 0062-18 a necessity before any of the tunes? I have not purchased yet. My last TSB was 0077-16. Thanks.
  2. Feb 9, 2020 at 7:17 PM
    godzilla888
    godzilla888 Just a plain white T
    Paradise
    2017 Super White SR5 DCSB AT
    Not a necessity but recommended, in order to update the trans ecu to 04b04
    Updated trans ecu should have better shifting, and the tunes that used be released on an earlier timeline were for 04b04
  3. Feb 9, 2020 at 7:26 PM
    cdoghump
    Amarillo, TX
    17' TRD OR DCSB 4x4
    Awesome, thanks!
  4. Feb 9, 2020 at 8:15 PM
    kzs7878
    kzs7878 Active Member
    2018 Tacoma Stock 3.5 AT
    None
    I have been wondering why my 2018 sr5 speedometer was slightly slow. Thanks to Matt and a previous post, I find out that the sr5 tire is 30.47 inches in dia. and the Pro tire is 31.65 inches in dia. Toyota must have just picked in the middle (31 in.) for the ecu on both trucks. Thus, mine is just over 1mph slow at 70mph.
    Thanks guys!
    GreyBaldTaco likes this.
  5. Feb 9, 2020 at 8:23 PM
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    Ticket 12429 from 1/17. Was out on the trail today so didn’t see this post. Thanks!
  6. Feb 9, 2020 at 8:29 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    That’s not uncommon for many OEM speedos to underreport speed by 1-3 mph at highways speeds.
  7. Feb 9, 2020 at 8:39 PM
    kzs7878
    None
    I suppose that under reporting the displayed speed is a cya for toyota's protection?
  8. Feb 9, 2020 at 10:07 PM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    With tire sizes and speedometers, the variances for displayed speed will actually change based on actual speed. It's a percentage variance, not a fixed variance, and said percentage is based entirely on revolutions per mile. The faster or farther you go, the higher the variance.
    For example, my own tires look like this:
    31" Stock tires: 682 revs/mile
    33" Coopers: 632 revs/mile
    682/632 = 1.079
    So, in order to get both my actual speed or mileage, I simply multiply each displayed value by 1.079 -- which can also be described as a 7.9% variance.
    In practice:
    Displayed speed: 30.00 mph
    Actual speed: 32.37 mph
    Variance: 2.37 mph
    Displayed speed: 80.00 mph
    Actual speed: 86.32 mph
    Variance: 6.32 mph
    Displayed mpg average: 16.00 mpg
    Actual mpg: 17.26 mpg
    Variance: 1.26 mpg
    Displayed mpg average: 20 mpg
    Actual mpg: 21.58 mpg
    Variance: 1.58 mpg
    etc.
    Of course, all of the above assumes that the factory ECU settings match the factory tires, which isn't always the case. the math should be close enough to help you avoid speeding tickets, though. :D
    (NOTE: you can find most revs/mile info on the tire manufacturer web pages).
    Crasyrapy likes this.
  9. Feb 10, 2020 at 12:11 AM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    so does that mean you don’t need to write separate tunes for 4.88 and 5.29 in all the different flavors of ECUs and octanes now? Just use 1 primary tune for each ECU then change the input to 4.88 or 5.29 and it’ll automatically adjust its own shifting to suit?
  10. Feb 10, 2020 at 3:57 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Incorrect. Pro tire is 30.6, same as TRD OR and Sport
  11. Feb 10, 2020 at 5:41 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    handhelds are sold out until further notice.
    we received an email from the manufacturer that there will be a significant delay in restocking.
    Some of the components are having delays exporting due to the Coronavirus.
    Thanks to this amazing community and the folks willing to help test out, we have confirmed that both Gear settings (3.909, 4.3, 4.88, 5.29) correct shifting on stock tires and tire size calibration fixes gear shifting on larger tires.
    The correction makes the truck shift where it SHOULD shift at as if the truck was stock with a tune.
    that's amazing news and significantly reduces creating of shift maps for trucks with different mods.
    We can now simply input the required settings right into the same tune and it's ready to go.
    jerzsubbie, Mkime, AKGSD and 39 others like this.
  12. Feb 10, 2020 at 6:03 AM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    Damn computers. :)
    wahoobie likes this.
  13. Feb 10, 2020 at 6:05 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    So... soon?
  14. Feb 10, 2020 at 6:08 AM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    Does this mean there will be another drop down menu for tire size for each tune?
    Tac0Tic0 and GreyBaldTaco like this.
  15. Feb 10, 2020 at 6:12 AM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    How can we still order the HH units and use the discount? On the OV page is SOLD OUT and no orders can be placed...that means no discount available.
  16. Feb 10, 2020 at 6:22 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    That's awesome news.
  17. Feb 10, 2020 at 7:06 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Clearly soonER than soon
    blitzkrieg3002 likes this.
  18. Feb 10, 2020 at 7:38 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    He could do it like he did for the M/T pre orders years ago. Place the order with a $1.00 cost as a pre order and charge the balance when they ship...
    mZiggy likes this.
  19. Feb 10, 2020 at 7:47 AM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    Well, finally had some time today. Flashed to 04a61
    Then, switched to gear lock tune while i was at it...
    Time will tell...
  20. Feb 10, 2020 at 7:50 AM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Prolly should have ordered before they were sold out...
    GF8er, GreyBaldTaco and xxTacocaTxx like this.
Thread Status:
