Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 10, 2020 at 7:57 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    :ohsnap:
  2. Feb 10, 2020 at 8:03 AM
    El Chivo Norteño
    El Chivo Norteño Well-Known Member
    Central Oregon
    2020 White DCLB 4X4 Off-Road
    I take it the no news about HHs update for +2019 trucks means nothing yet avail to make them functional :confused:
  3. Feb 10, 2020 at 9:08 AM
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    to make sure I'm understanding this correctly, you have written the optimal tune for stock gears and tires, then have the ability to add in other gear ratios and tire sizes to correct to the stock shift tune???
    if this is correct, is this done on your end via "custom tuning" or is it gonna be on the user via your tuning product?
    perkj and GreyBaldTaco like this.
  4. Feb 10, 2020 at 1:19 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    @OVTune . . .
    The Germe Labs RFCC Rear/Front Camera Controller uses the steering wheel "Mode" and "Up/down" buttons to control its operating modes.
    I haven't ever seen exactly how the OVTune update will handle Gearlock switching. Hopefully, the camera controller and OVTune will play nice together? :fingerscrossed:
    blitzkrieg3002 likes this.
  5. Feb 10, 2020 at 1:22 PM
    Shellshock
    Iowa
    Last i knew, tune switching was being done via the cruise control stick
  6. Feb 10, 2020 at 1:50 PM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Is this a departure from
    D = Base
    ECT = Performance
    Sport = Gear lock
    johntoyota and MajinRonin like this.
  7. Feb 10, 2020 at 1:54 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It changed for the ATs and is still in the air for us MTs.
  8. Feb 10, 2020 at 1:57 PM
    Shellshock
    Iowa
    I’m not sure it’s been finalized / announced. Just different options that had been discussed as possibilities being researched.
    tonered likes this.
  9. Feb 10, 2020 at 2:17 PM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    That's the last thing Mat has posted on the topic
  10. Feb 10, 2020 at 2:17 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    And that's why I asked the question. Mat will tell us how it works when the time is right.
    But if it may conflict with this Germe Labs device... it would be nice to know before I buy the Germe device.
  11. Feb 10, 2020 at 2:34 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I think there was stuff posted here since New Years about both AT and MT. It was definitely said that the MT still needed a solution. @lapoltba posted about the CC stalk, but I don't think there was a reply.
  12. Feb 10, 2020 at 2:36 PM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    I went back through all the posts from Mat, didn't see anything.
    tonered[QUOTED] likes this.
  13. Feb 10, 2020 at 2:38 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    The issue with using the CC right now is I've not found a way to save your selection after you shut off the truck.
    So imagine you have 3 maps, and switch to "93 map 2"
    You'd have to do that every time you start the truck.
  14. Feb 10, 2020 at 2:38 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    I'm assuming Mat is looking at alternatives, but as far as I can tell, it is the only thing that goes into the ECU that would be available on the majority of trucks.
    And what he said... Lol ^^^
    There must be nonvolatile storage somewhere, the trick is figuring out how to access it I suppose.
    How much access do you have to the Gauge Cluster software like you did with the boost Gauge for the Tundra. Maybe add a screen there to be able to at least show which tune is active? Even if it isn't persistent it will be obvious. Not good if switching octane tunes though.
  15. Feb 10, 2020 at 2:40 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I am totally down with that as long as the default can be our 'preferred' tune. Such as FOB for me.
    Is that a problem in the file creation for you / flashing for us?
    Shellshock likes this.
  16. Feb 10, 2020 at 2:41 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl::rofl:
    rdpoe likes this.
  17. Feb 10, 2020 at 2:41 PM
    ITDude
    ITDude Well-Known Member
    Dan
    2017 TRDORDCLB Barcelona Red
    Mat, is there any way you can allow users to enter tire size for shift points? Or, is there a setting in the system that can be read?
  18. Feb 10, 2020 at 2:42 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Might want to hold off.
  19. Feb 10, 2020 at 2:51 PM
    Shellshock
    Iowa
    Pretty sure those buttons only interface with the headunit, not the ecu. I have the same device in my truck as do many others.
    Ron1965, ihatemytruck and dpippel like this.
  20. Feb 10, 2020 at 3:13 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Mat, this is great news. Will tire size be a selectable variable in FM or will it require OVT to email files?
Thread Status:
