Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Feb 11, 2020 at 3:08 PM
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    I run 265/75R16 in the winter and 255/85R16 in the summer so 32” and 33” for me please!
  2. Feb 11, 2020 at 4:02 PM
    Twoplanker84
    Twoplanker84 Well-Known Member
    Walker
    Sacramento
    2017 DCLB TRD Sport
    Icon coil-over Icon UCA 4.88 gears Method 300’s Cooper stt pros 285-70-17
    Also, the A/T’s I’m running are 12lbs lighter than the M/T’s I previously had. Same size but huge difference in power.
  3. Feb 11, 2020 at 5:36 PM
    SpeySquatch
    2016 TRD OR DCSB
    Oh...8” diff...:facepalm:
    Shellshock likes this.
  4. Feb 11, 2020 at 5:37 PM
    SpeySquatch
    2016 TRD OR DCSB
    Hence 8” rear is pointless. Even if you don’t tow the OR is a better option for the $ just for the diffs
  5. Feb 11, 2020 at 5:49 PM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    agreed... but skewp!! :rofl:
  6. Feb 11, 2020 at 6:27 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Did somebody say skewp??? Obligatory commendation.
  7. Feb 11, 2020 at 6:39 PM
    G8R_Taco
    G8R_Taco Just passin thru….
    FLA
    2019 TRD OR 4x4
    Damn. I wonder how long before we get a TSB for the 2019...
  8. Feb 11, 2020 at 7:03 PM
    Dbronco20
    Dbronco20 Dbronco20
    RJ
    Gilbert, AZ
    2017 Toyota Tacoma TRD Sport 4X4
    Bilstein Suspension, OME Leaf Springs, Full Skid Plates (steel), Ditch and Fog Lights, OVtuned , Thinking about 4.88 Gears
    I am hoping someone can help me understand what TechStream does. I feel like I have read a few things and its just gets confusing. It seems like it either resets the truck, or resets the tune. I just don't know which, and I feel like I have read a few different takes on it.
    Anyone have a link to a good description, or maybe explain it here.
    much appreciated
  9. Feb 11, 2020 at 7:05 PM
    Shellshock
    Iowa
    Techstream is the diagnostic tool that Toyota uses. You can use it to program, read or clear various settings of the truck.
    ihatemytruck and xxTacocaTxx like this.
  10. Feb 11, 2020 at 7:06 PM
    RushT
    North Texas
    Briefly, it’s a tool used by Toyota to access the car and change certain settings. It’s not part of, or required by the tune. It can however, reset some of the learned values of the truck and in some cases clear some bad behavior that *should* work itself out albeit over a longer time.
  11. Feb 11, 2020 at 7:17 PM
    cdoghump
    cdoghump Well-Known Member
    Amarillo, TX
    17' TRD OR DCSB 4x4
    Whats the draw back of crawl control?
  12. Feb 11, 2020 at 7:32 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    The post I quoted was regarding the *current* inability to make the selected tune persistent after a power cycle. Until Mat finds a way to access non-volatile memory to maintain state, all tune switching methods have the same issue.
    ihatemytruck likes this.
  13. Feb 11, 2020 at 8:01 PM
    CRCs Reality
    CRCs Reality Well-Known Member
    Pittsburgh-Ish
    2017 DCSB TRD Sport (OVTuned)
    In for .001" incremental selections, so as my tires wear I can tune for exactly where they are now :p
    J/K, I agree, 1" increment are MORE than fine!
  14. Feb 11, 2020 at 8:52 PM
    Ysrracer151
    Ysrracer151 Okopipi
    Nate
    Huntington beach
    Voodoo tacoma pro
    Matt. I have a carista obd. In the menu it has options for remember last or return to default for the cruise radar distance. Idk if that helps but its somewhere to start.
    xxTacocaTxx likes this.
  15. Feb 11, 2020 at 8:58 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That has to do with the radar cruise recall and how Toyota wouldn't perform the work if folks were lifted or had an a/m grille. They simply set it to off and it would persist unless the owner changes it.
  16. Feb 11, 2020 at 9:15 PM
    Ysrracer151
    Ysrracer151 Okopipi
    Nate
    Huntington beach
    Voodoo tacoma pro
    Matt was looking for code. Code that has a remembered setting written in code could corrillate with the code he is looking for.
  17. Feb 11, 2020 at 10:21 PM
    BlazinBlue
    BlazinBlue Blue Taco Dude
    2018 TRD SPORT DCLB V6 2WD A/T
    Does your Guy Friend know you've gone public? :spy:
    2017TRDpro and mAtTyG04[QUOTED] like this.
  18. Feb 11, 2020 at 10:52 PM
    BlazinBlue
    Wow, 35" wheels. I can't imagine how big the tires might be on 35" wheels.
    G8R_Taco, LTacoman, BOMBS and 2 others like this.
  19. Feb 12, 2020 at 6:52 AM
    TacoLoco17
    TacoLoco17 Well-Known Member
    Craig
    Conshy, PA
    17 TRD OR DCSB Super White
    TRD Sport Hood swap TRD Exhaust TRD Intake TRD Skid plate TRD Pro Faux grille w/ Raptor lights MORIMOTO XB LED Headlights Rigid D series Fog lights Rigid E series 20” lightbar Spot/Flood MESO Ultimate Turn signal MESO Stage 1 Tailights 3x Remote Start Hypertech In-line Speedo Calibrator OV Tune Bilstien 6112/5160 Set at 5/6 OME Dakar Medium Leaf Pack Pioneer Avic 8400 NEX Headunit Infinity Reference 6x9s Front 6.5"rear Kicker Subaru Tweeters JL Audio Stealthbox w/ JL Audio RD500/1 amp ARE CX series cap Toyota OEM Trifold Hard Tonneau Body Armor HiLine Front Bumper Smittybilt X20 Gen 2 10K Winch SCS Ray 10 17x8.5 Gunmetal Rims 275/70 Falken Wildpeak AT3W tires
    I’ll take that 04B04 AT 25600 beta also Please and thank you
    wahoobie[QUOTED] likes this.
  20. Feb 12, 2020 at 6:54 AM
    russ.moura
    russ.moura Well-Known Member
    2019 Cement TRD Off Road DCLB
    @OVTune
    I had sent a few emails to the zendesk trying to get an answer unsuccessfully, so I figured I'd ask here (ticket number 10675). I order the tablet around Labor Day of last year and received the tablet around the end of October, only to end up being unable to use the tune due the OFT 10003 error with the tablet. Unfortunately, I have a 2019 OR auto and fall into the category of folks who are still waiting for the engineers to fix this bug. In communication with your team I have been given the option to send back the tablet and receive the flash kit as a substitution. I have been dying to get this tune since I purchased back in September of 2019 and was on the fence about ordering this until the tablet came out which is why I ended up pulling the trigger. Given the amount of time (almost 6 months) I have been waiting and it still unclear how much longer I must wait- is there any way i can swap this tablet out for the flash kit then once the handhelds have been resolved I would receive the "tuner flash kit accessory"? I suppose this would be no different than if I had bought the tune earlier then bought the tuner flash kit accessory later in another transaction. If not, what would the difference in cost be to me?
    GA_Goat likes this.
Thread Status:
