Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 3, 2020 at 12:12 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    "brake override failure" shows up under any error.
    You are stuck with a half-flashed ECU.
    I'll get back to you via Zendesk right now
  2. Mar 3, 2020 at 12:16 PM
    Tbrooks2444
    Tbrooks2444 Well-Known Member
    Email sent. Request #13550
  3. Mar 3, 2020 at 12:26 PM
    RKG
    RKG New Member
    Robert
    2017 SILVER TRD OR DCLB
    Ok. I got the P5flash button to be clickable. But when I click it the bottom left says “ready” and nothing else happens.
  4. Mar 3, 2020 at 1:24 PM
    Fletcher37
    Fletcher37 Well-Known Member
    PNW
    No brake override issue with mine.
    I could open the P5flash program. All the functions would try to run but would yield "unsuccessful" results. It wouldn't identify the ecu, wouldn't flash to any of the tunes or stock, wouldn't search for DTCs, clear the LV, etc.
    Not sure what happened to begin with other than I had a bad flash that was resolved by unplugging battery and all and retrying. Past flashes were super fast and easy. This time around, wife was loading truck, opening closing doors, inside lights on/off, etc. Not sure if that could have affected things. Maybe I had a bad USB connection. (I use a MacBook Pro with a USB adapter device and run Windows on Boot Camp. Previous flashes were easy and fast).
    Either way, I've been on stock tune since then. Waiting for the 2.0 update to drop and maybe try again.
  5. Mar 3, 2020 at 2:05 PM
    LstMinutePanic
    LstMinutePanic Well-Known Member
    Colorado
    2018 Black Tacoma OR DCLB AT
    I found this in a post from @BadKitty , and it worked for me:
    If its a windows defender issue:
    -Go to Start > Settings > Update & Security > Windows Security > Virus & threat protection.
    -Under Virus & threat protection settings, select Manage settings, and then under Exclusions, select Add or remove exclusions.
    -Select Add an exclusion, and then select from files, folders, file types, or process.(OV tune stuff)
    I actually ended up taking a slightly different route by turning off "real time protection" under Virus & threat protection settings while running Flash Manager. While "real time protection" was off, I was able to use Flash Manager without any issues. I was sure to turn "real time protection" back on once I was done though.
    dskakie and perkj like this.
  6. Mar 3, 2020 at 2:45 PM
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    I’m going to try that approach. I’ve got my OVtune folder added as an exclusion and triple checked it’s there correctly and still tries to block it every time I flash.
  7. Mar 3, 2020 at 3:57 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Email sent 13561
  8. Mar 3, 2020 at 8:19 PM
    cdoghump
    cdoghump Well-Known Member
    Amarillo, TX
    17' TRD OR DCSB 4x4
    I had to turn off "real time protection" and "firewall" .
  9. Mar 4, 2020 at 5:19 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    I am ready to flash sooner. It must be good given the time invested on this round.
  10. Mar 4, 2020 at 6:07 AM
    cdoghump
    Amarillo, TX
    17' TRD OR DCSB 4x4
    Since I have the OVT kit and Techstream downloaded, would I be able to help/diagnose/ update 4runners or other vehicles?
    These are my waking thoughts.....:bored:
  11. Mar 4, 2020 at 6:52 AM
    OVTune
    OVTune
    Good morning.
    wanted to let everyone watching this thread know we are having some Zendesk issues at the moment. They may be doing some maintenance.
  12. Mar 4, 2020 at 6:53 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    Yes,you will be able to connect to any Toyota vehicle that Techstream supports.
    xxTacocaTxx and Shellshock like this.
  13. Mar 4, 2020 at 6:54 AM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    Yes, as long as your Techstream version is at or higher than what the vehicle requires.
    xxTacocaTxx likes this.
  14. Mar 4, 2020 at 6:55 AM
    Tbrooks2444
    Yesterday as well, I’m assuming.
  15. Mar 4, 2020 at 7:07 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Zendesk has been working for me all week, I work in it extensively.
  16. Mar 4, 2020 at 7:08 AM
    OVTune
    OVTune
    I am having a problem where I login and it logs in, kicks me right back to login again.
    working on figuring out what is going on.
    GreyBaldTaco[QUOTED] likes this.
  17. Mar 4, 2020 at 7:10 AM
    wahoobie
    chris
    Suffolk, VA
    If we need to do something different for the 2.0 testing volunteer ticket/emails just let us know.
  18. Mar 4, 2020 at 7:11 AM
    OVTune
    OVTune
    not necessary.
    This isn't the first time I've had this issue. it happens sometimes logging through google...sometimes when they are doing something.
    but I'll be back online asap
    wahoobie[QUOTED] likes this.
  19. Mar 4, 2020 at 7:13 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Hmmmm.... Maybe your computer has the Orange Virus. :anonymous:
  20. Mar 4, 2020 at 7:21 AM
    GreyBaldTaco
    2019 F150 5.0
    What browser are you using? Are you using a Zendesk login or are you using SSO?
Thread Status:
