Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Mar 11, 2020 at 11:34 AM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    This guy likely has a 2019 automatic trans. Early 3-4 shift is not possible in a manual unless the driver does it of course. If you’re a 2019 at then wait patiently for the 2.0 final tune update as that should have the fix in it.
    Edit - read full part of post where he said 2019 :). Yeah man just wait it out should be fixed in 2.0. Another issue is wide open throttle. Try it out you’ll experience it where the truck seems to stall for a second then resumes acceleration.
  2. Mar 11, 2020 at 11:37 AM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    I thought I read OLE did cover those. You just flashed the version you currently had in your tank to get you closer initially.
    GPatriot likes this.
  3. Mar 11, 2020 at 11:42 AM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    My understanding is the two different octane tunes are to start closer to the octane you have in the tank. So if you have 87 in the tank it doesn't have to adjust all the way to 93.
    Instead you'll just load the 91 tune and it only has to adjust to 93 if you're running that (like I am).
    IOW you can install the 87 and it will still learn to 93, it will just take longer.
    PhogDog and Karminski like this.
  4. Mar 11, 2020 at 11:50 AM
    2017TRDpro
    2017TRDpro Well-Known Member
    2017 TRD Pro
    You might be right. Pulled from the 2.0 MT final blog.
    Note, we have 2 versions, and octane version for regular gas, and octane version for premium fuel. No longer are the tunes "87, 91, and 93" instead, there are 2 versions, Octane Learn Regular. This covers octane ratings from 85 to 89 octane. and Octane Learn Premium. This covers octane ratings from 90 to 94 octane.
    Note** you can technically run 87 or even lower on the premium file. However, you will get continual diminished performance.
  5. Mar 11, 2020 at 11:51 AM
    Karminski
    Karminski Well-Known Member
    Virginia
    2016 Tacoma D/C M/T TRD Off-Road
    That's my understanding as well:
    See if this helps as well.
  6. Mar 11, 2020 at 11:57 AM
    2017TRDpro
    2017 TRD Pro
    This helps a lot. It must be from the MT thread, which I don't keep track of.
  7. Mar 11, 2020 at 12:00 PM
    Shellshock
    Iowa
    Yeah. I believe it’s a starting point but they will still go up and down. You just want to avoid extremes like going from 93 to 85 or it’ll run crappy for a bit until it adjusts for the huge diff
    GPatriot[QUOTED] likes this.
  8. Mar 11, 2020 at 12:01 PM
    Karminski
    Virginia
    I'm sure more info will be posted here or on the Blog once the AT files are available.
    GreyBaldTaco, Shellshock and GPatriot like this.
  9. Mar 11, 2020 at 12:08 PM
    GPatriot
    Cincinnati, Ohio
    There's exactly 100 people watching the thread... :D
    wahoobie and GreyBaldTaco like this.
  10. Mar 11, 2020 at 12:10 PM
    dskakie
    dskakie Well-Known Member
    Dan
    Northern CA
    2016 TRD OR DCSB
    Feels like I never left after MT started getting rolled out... cmon AT!! :fingerscrossed:
    GreyBaldTaco and wahoobie like this.
  11. Mar 11, 2020 at 1:01 PM
    Shadowmachine
    Shadowmachine Well-Known Member
    Ken
    Saltsburg Pa
    2018 inferno dcsb 6mt
    Baby lift, carven muffler, s&b intake, jba uca, ovtune
    Assuming Matt's silence today is a product of him working his tail off to slick you AT guys up. He's as excited as we are for this.
  12. Mar 11, 2020 at 1:08 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    :bananadance::dancingbacon::broccoli::kona::jellydance::taco:
    Dance party while we wait?
    johntoyota, runmc, wiljayhi and 2 others like this.
  13. Mar 11, 2020 at 1:11 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
  14. Mar 11, 2020 at 2:03 PM
    txags92
    txags92 Well-Known Member
    2016 DCLB TRD OR 4x4 BBP
    Chasespeed likes this.
  15. Mar 11, 2020 at 2:24 PM
    Scorpion Rider
    Scorpion Rider Member
    40 Acres of heaven
    2019 DCLB TRD Sport
    Got my Key registration key number email from Mat early this morning. Now I’m patiently waiting for 2.0 for the 2019 automatic trans. I was going to try the beta version, but I might just wait for the full 2.0.
    thanks for the hard work Mat
    stu8319 likes this.
  16. Mar 11, 2020 at 2:26 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Same here.
    stu8319 likes this.
  17. Mar 11, 2020 at 3:18 PM
    Anchovy
    TRD Ferguson
  18. Mar 11, 2020 at 3:24 PM
    cdoghump
    cdoghump Well-Known Member
    Amarillo, TX
    17' TRD OR DCSB 4x4
    :rockband:
    KG Fz1, wahoobie and GreyBaldTaco like this.
  19. Mar 11, 2020 at 3:27 PM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    "Note** you can technically run 87 or even lower on the premium file. However, you will get continual diminished performance."
    This is something I've been wondering for a while. My Camaro (2002/LS1) runs 91 only, BUT if you need to put 87 in due to lack of 91 (common in small towns here in Kansas or in Colorado where it's 85) it will still take 87 and run. Sure it detunes itself but it will get you to the next station or city that has 91.
    What I wanted to know is if when running the 91 tune if I was in a location where the station only carries 87 if I could throw in 5 gallons or whatever to get on to the next town to put 91 in without harming the truck. Performance decrease would be expected as long as it's not physically harmful to the engine. I've seen some highly tuned cars that grenaded when using 87 vs 91, is why I was curious. So that is nice to read assuming it applies here as well.
    Also curious about Colorado where 85 is basically 87 at high altitudes what I would need to put in as premium can be bonkers expensive. Probably just carry a laptop with me and the dongle to flash back to 87 when out of state or on a road trip.
  20. Mar 11, 2020 at 3:31 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Well looks like I'll check back next month.
Thread Status:
