Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 12, 2020 at 6:43 AM
    Shellshock
    Iowa
    Gains with k&n / cai are negligible
    Pedal commander just hijacks the throttle control so for example 10% is now 25%.
    The tuning will bring you much more power on the low end <3000 rpm in addition to fixing the shift points and weird throttle curve.
    If you want even more power, check out the videos in the turbo thread.
    also check out the blog posts on ovtuned.com
    https://www.ovtuned.com/blogs/news/...-tacoma-transmission-and-how-we-are-fixing-it
    More info on vf will be coming as release gets closer. I believe April / May was the timeline.
  2. Apr 12, 2020 at 7:44 AM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    If I have a full tank with a blend around 91.8 octane in it and I plan on replenishing with 93 after a quarter is consumed. You think there is any harm in flashing to 1.05 93 now
  3. Apr 12, 2020 at 7:52 AM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    if you are worried, throw in a bottle of octane booster and that will bring your tank up by 2-3 octane points.
  4. Apr 12, 2020 at 7:53 AM
    LstMinutePanic
    LstMinutePanic Well-Known Member
    Colorado
    2018 Black Tacoma OR DCLB AT
    Luckily, @n6vmo was able to help me out! But thanks for the response and willingness to help. I really appreciate it.
    buckyop[QUOTED] likes this.
  5. Apr 12, 2020 at 7:54 AM
    ConsumedBeatle01
    ConsumedBeatle01 Well-Known Member
    Collin
    2017 Tacoma TRD OR
    Ovtune 2.0 Beta
    Hi, new to TacomaWorld.
    I'm running the Ovtune 2.0 Beta (downloaded from the Public page) and my engine developed an engine chirping sound. Anyone else here experienced this issue?
    Also, should probably add this in there...
    I was running the 1.05.1 93 Octane performance tune, flashed to stock, filled tank with 87 octane when it was slightly less than 1/4 of 93 and then flashed the 87 beta.
  6. Apr 12, 2020 at 8:21 AM
    Karminski
    Karminski Well-Known Member
    Virginia
    2016 Tacoma D/C M/T TRD Off-Road
    When do you heard the chirping? If it is at idle; then it's probably not @OVTune related, its probably the High-Pressure Fuel pump. There is a TSB from Toyota for that. Mine sounds like a really angry cricket if I'm in a drive-thru line and the sound can echo off the wall. Of course every time I try to take it into the dealer, it's quite as a mouse o_O
    I'll see if I can find the TSB Number and post it here.
    Edit: Found a TW Thread here that might help.
  7. Apr 12, 2020 at 8:33 AM
    ohioboater
    ohioboater Well-Known Member
    2017 DCLB 4x4 Sport
    19800 tip in is softer/less aggressive than 16012.
    On my truck the shifting is smoother and more predictable on 19800. With 16012 it would sometimes shift harshly or feel like it was slipping excessively, even after 1000+ miles. Subjective impression of course.
  8. Apr 12, 2020 at 8:49 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
  9. Apr 12, 2020 at 8:55 AM
    ConsumedBeatle01
    Collin
    2017 Tacoma TRD OR
    Ovtune 2.0 Beta
    Thanks for the reply, I only listed it in this thread because it happened immediately after flashing the 2.0 Beta.
    Also for the fuel pump for the TSB, do they replace the existing fuel pump with the same part number? Or an updated one?
    Karminski[QUOTED] likes this.
  10. Apr 12, 2020 at 9:03 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Did you switch fuel (to higher octane, etc), at the same time as flashing.
  11. Apr 12, 2020 at 9:08 AM
    svermilyea
    Scott
    East Tennessee
    Presently, there is no posted fix. I stop by the dealership every week when I wash my truck, just to see what they have come up with.
    Karminski likes this.
  12. Apr 12, 2020 at 9:12 AM
    buckyop
    buckyop Well-Known Member
    2018 Tacoma off-road xp Black maverick edition
    Thanks. Seems to have the quick 3rd to 4th issue as well.
  13. Apr 12, 2020 at 9:22 AM
    ConsumedBeatle01
    Collin
    2017 Tacoma TRD OR
    Ovtune 2.0 Beta
    Yes, I did switch octanes. I was running the 1.05.1 93 Octane but got it to just below 1/4 tank, flashed it to stock, filled tank with 87 octane and flashed the 87 2.0 Beta.
  14. Apr 12, 2020 at 9:24 AM
    BigWhiteTRD
    Ted
    I have not experienced the chirp, but anecdotal evidence by some indicates that some people have much more chirp with different fuels... Can't guarantee its not placebo but you might play with that...
  15. Apr 12, 2020 at 9:58 AM
    Karminski
    Virginia
    Not sure what they replace it with. I would really like to get mine done as is drives me nuts - it's just such a PITA to work with my local dealership.
  16. Apr 12, 2020 at 11:38 AM
    Twoplanker84
    Twoplanker84 Well-Known Member
    Walker
    Sacramento
    2017 DCLB TRD Sport
    Icon coil-over Icon UCA 4.88 gears Method 300’s Cooper stt pros 285-70-17
    Does the chirping increase when your RPM’s go up? I’ve noticed this too recently and I’m not on the recall list
  17. Apr 12, 2020 at 11:53 AM
    ConsumedBeatle01
    Collin
    2017 Tacoma TRD OR
    Ovtune 2.0 Beta
    No, the chirping is mainly when sitting idle in Park.
  18. Apr 12, 2020 at 12:00 PM
    Taco16LB
    Taco16LB Well-Known Member
    I had the chirping in mine when new . It had nothing to do with OVtune . 87 octane gas with 10% ethanol was when it happened and it was bad. I read here on TW that adding Lucas upper cylinder lube to the gas stopped it . IT DID . Also switching to 91 octane 0 ethanol without the Lucas stopped it . I have not heard it since then and it has been over 3 1/2 years . It is a cheap fix to try some Lucas additive and see.
  19. Apr 12, 2020 at 12:09 PM
    buckyop
    Could this be what u r hearing?
    Toyota Advances D4S With Self-Cleaning Feature on Tacoma
    Drivers may hear the self-cleaning taking place during a hot idle, and the process could last from 10 seconds to as long as 10 minutes, depending on driving patterns and the amount of build-up on the injectors.
    Karminski and Inferno__Taco like this.
  20. Apr 12, 2020 at 12:14 PM
    Taco16LB
    I am aware of that system but I do not believe it was what I was hearing . When going through a drive through at MCD to get coffee , the echo was embarrassing each time we went . After the Lucas and then 0E 91 fuel it never happened again .
Thread Status:
