Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 12, 2020 at 12:14 PM
    ConsumedBeatle01
    ConsumedBeatle01 Well-Known Member
    Collin
    2017 Tacoma TRD OR
    Ovtune 2.0 Beta
    How often/how much per gallon of 87 octane of the Lucas did you use?
  2. Apr 12, 2020 at 12:15 PM
    Taco16LB
    Taco16LB Well-Known Member
    4 oz .each tank . I am not a rep or anything but it is something cheap to try to see if you need the TSB done or not .
    Edit , I am lucky here to be able to get 0E all the time in 87 or 91 . I get the 91 . and only use the Lucas when I can only get 10E gas out of town .
  3. Apr 12, 2020 at 12:25 PM
    ConsumedBeatle01
    Collin
    2017 Tacoma TRD OR
    Ovtune 2.0 Beta
    Thanks! I'm not the most knowledgeable on fuels. Did you ever try the 87 Octane Ethanol free? And if you have, did you ever see results with reduced engine chirping?
  4. Apr 12, 2020 at 12:44 PM
    buckyop
    buckyop Well-Known Member
    2018 Tacoma off-road xp Black maverick edition
    A guy that I work with has a ‘16. Mine is an ‘18. I run 93 octane. 16012 91 octane tune. I don’t seem to hear much of the pinging.
  5. Apr 12, 2020 at 1:28 PM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    This has been my experience anyway. Makes merging on to the highway a little more dramatic than it needs to be. Goes 1-2-3/4-3-4-5-6 due to the need to press it harder again to get back to 3rd. Practically skips it only using it for a few seconds.
    The fix is basically just to push much harder before it gets to 3rd and hold it or just keep pressing and it'll be more inclined to use it. I'd imagine it'll be fixed in the final since it's a known issue.
    Still. I'll take it 10:1 over stock where I can't hold overdrive on the highway for anything. Only a good hill or high headwind makes it drop back to 4th going 70-80 now vs being in 4th 80% of the time.
  6. Apr 12, 2020 at 1:43 PM
    ConsumedBeatle01
    Collin
    2017 Tacoma TRD OR
    Ovtune 2.0 Beta
    I've only had my 17 OR for like 3 months and the transmission is driving me insane...including using the tune.
    2.0 Beta is better than 1.05 & 1.05.1 with shifting points but it still rides in too high of a gear. It will shift into 5th gear going at like 35 MPH making the engine bog to 1100 RPM's! It will also upshift into too high of a gear every time I make a turn onto a street.
    Anyone else getting these undesired shift points?
  7. Apr 12, 2020 at 1:58 PM
    wizard1
    wizard1 Haunted
    Socal
    OVtune-Prinsu cabrack-SCS copper wheels-Dirty Deeds exhaust—custom Intake and TBS
    That is fixed in 2.0 final
  8. Apr 12, 2020 at 2:11 PM
    buckyop
    Agreed
  9. Apr 12, 2020 at 2:11 PM
    ConsumedBeatle01
    Collin
    2017 Tacoma TRD OR
    Ovtune 2.0 Beta
    Okay, Thank You.
  10. Apr 12, 2020 at 2:36 PM
    c0pperh34d
    c0pperh34d New Member
    Caleb
    2018 TRD OR
    Got Techstream installed, and I believe I've got the files for TSB 62-18, which should be the one that updates the truck from 04A60 to 04A61. It came as a .zip though, and contained inside were two CUW files, T-0034-18 and T-0036-18. I got the .zip from the MT thread, so I'm wondering if these are correct for an AT, do I need both of them, and is there anything I need to do in between them since I can only flash one at a time?
    EDIT: Also, do I need to flash the truck back to stock, update the ECU, and then reflash OVTune 2.0 Beta, or can I just install the TSB over top of 1.05 and then update to 2.0 Beta?
  11. Apr 12, 2020 at 2:41 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    T-0036-18 is the one you use if I remember right.
  12. Apr 12, 2020 at 2:57 PM
    Karminski
    Karminski Well-Known Member
    Virginia
    2016 Tacoma D/C M/T TRD Off-Road
    I used to run that in my 2nd Gen all the time. I’ll have to give that a try.
    Taco16LB[QUOTED] likes this.
  13. Apr 12, 2020 at 3:22 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    you must be one of the luck ones if you have Final 2.0. Makes rest of us jealous ! Eventually....us '16-'17 and '18 AT owners will get to taste the fruit of 2.0 Final. Until then we can only imagine.
  14. Apr 12, 2020 at 3:24 PM
    GoldenBrew
    Golden, Colorado
    Flash over the top of it and then flash 2.0 Beta over the update. Remember to select the new ECU to reflect the update.
  15. Apr 12, 2020 at 3:49 PM
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    correct. Then you will be at current TSB baseline and you can flash 2.0 beta over that.
  16. Apr 12, 2020 at 7:50 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    TS will not allow you to apply the incorrect .CUW file. Give it a shot, and it gets rejected, try the other.
    ihatemytruck and Shellshock like this.
  17. Apr 12, 2020 at 8:24 PM
    Shellshock
    Iowa
    Can confirm. I’ve tried cuz I was too lazy to see which one was the correct one lol
  18. Apr 12, 2020 at 8:55 PM
    SpeySquatch
    2016 TRD OR DCSB
    Ran the 04B04 4.88 91 octane 2.0 19800 beta for some serious towing miles over the weekend. The 91 octane tunes are undeniably noticeably better. Average 13-14.5mpg towing 4000lbs (that’s 2-3mpg better than the Tundra wouldn’t probably do not tuned). I was very pleased with this setup. (255/75/17’s, 300lbs armor, bed full of gear and a trailer with full tanks - dry weight is 3500lbs and it has a pop out )
    Happy Easter Everyone! Especially you Mat @OVTune
  19. Apr 12, 2020 at 9:03 PM
    c0pperh34d
    Caleb
    2018 TRD OR
    Thanks for the help guys! Successfully updated from 04A60 to 04A61 and installed OVTune 2.0 Beta. Haven't done much more than drive it around the block, but the truck starts and runs so I obviously didn't brick the ECU ahahah
    ihatemytruck, Hichung and FCL30 like this.
  20. Apr 13, 2020 at 6:18 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    The OLD fuel pump TSB is for the HPFP. I had mine fixed at least a year ago. It completely eliminated the chirping at idle, with any fuel. The new fuel pump TSB is for the in-tank low pressure fuel pump. I suggest getting the OLD fuel pump TSB completed. It's a $1,000 part.
    Have you tried the 91 performance tune? It is set up to ride in a lower gear than stock, which makes it much nicer to cruise around in. Give it a shot, you'll love it.
Thread Status:
