Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 19, 2020 at 10:22 AM
    SandyTaco4x4
    SandyTaco4x4 Well-Known Member
    Southern CA
    17 DCSB/AT QS TRD Sport 4x4
    What does this mean? Sorry for my ignorance.
    Also any changes to stock 87 2.0 file so that I should reflash it? Flashed it on the first set of links.
    Thanks!
  2. Apr 19, 2020 at 10:24 AM
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    Reflashed and idling right now. Much better!
    Scralatchtica824 likes this.
  3. Apr 19, 2020 at 10:24 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    sorry I won't get them likely until monday.
    it is an ignition setting.
    And for the record, I don't like the stock ignition code at all. The changes we have made so far to the ignition logic is very helpful though.
    But I am testing an all new ignition scheme that doesn't switch tables depending on port injectors on or not, and simplifies how knock retard is determined.
    That patch will be available in vF Tuner. It's pretty much a requirement for knock based tuning.
    dingel5, GPatriot, Shellshock and 2 others like this.
  4. Apr 19, 2020 at 10:27 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Idles much better on the new files. @OVTune
    TacoLoco17, wahoobie and welterbf123 like this.
  5. Apr 19, 2020 at 10:28 AM
    OVTune
    OVTune
    Great to hear.
    Are you guys seeing or noticing the cold / initial start up time is reduced.
  6. Apr 19, 2020 at 10:34 AM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Same here. Smooth idle. Will run and top off tank shortly and if all goes well do a afternoon road trip for giggles.
  7. Apr 19, 2020 at 10:34 AM
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    I was warm when I loaded the second file so hard to say.
  8. Apr 19, 2020 at 10:39 AM
    SandyTaco4x4
    Southern CA
    I don't know how to use clear AT and clear LV I just flashed it how I have in the past with instructions from the website.
    Also any reason for me to flash it again with the new links? I flashed it this morning on the first set of links.
  9. Apr 19, 2020 at 10:42 AM
    godzilla888
    godzilla888 Just a plain white T
    Paradise
    2017 Super White SR5 DCSB AT
    Ok, stupid question here, 2.0 final to test/review, is it just the base files from the links above?
    Thanks in advance
    btw, thanks Matt! this is one of the best birthday presents ever! :bananadance::cheers:
    GPatriot likes this.
  10. Apr 19, 2020 at 10:42 AM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    Much better!
  11. Apr 19, 2020 at 10:44 AM
    peppinoss
    peppinoss Well-Known Member
    Los Angeles
    2016 TRD OR 4x4
    ToyTec Boss 2.0 lift TRD Pro Wheels 265/70/R17 KO2s Mobtown Offroad Sliders
    I definitely noticed something different at cold startup after flashing 2.0 87 with 31-33. Now i guess i know what it is/was. Seemed quieter and less roar when starting up. only started it up once so far, but i noticed a difference for sure.
    Also noticed a twitchy idle, but after driving around for about 20+ miles and having it idle a few more times it seems to be good now. will keep an eye on it
  12. Apr 19, 2020 at 10:47 AM
    Shellshock
    Iowa
    I’d flash it with the new links
  13. Apr 19, 2020 at 11:00 AM
    GPatriot
    GPatriot Well-Known Member
    Cincinnati, Ohio
    2016 Black Tacoma Sport 4x4 V6 DCSB AT Loaded
    KDMaxPro 10.0, OME 2" Med Duty lift, RCI Sliders, RoofRack, Skid Plate, etc.
    @OVTune I had over 60 miles on stock gear 91 31+ and I pulled over to the side of the road because it was still running and shifting bad. Got caught up on the forum and reloaded the new 91 31+, and yes idle is fixed. Also it was not up-shifting into 5th I think, had hard downshifting, shifts from 1 thru 3 were pretty ugly, under high load power was cutting off at 4k Rpms, and it was also misfiring and sputtering. I just pulled over again after another 15 miles and whatever you did seemed to fixed it all. Getting back on the road...
  14. Apr 19, 2020 at 11:02 AM
    SandyTaco4x4
    Southern CA
    I'm not experiencing any of the problems reported here, I'm wondering if it was only a 91 problem or something. @OVTune was there any changes made to the stock 87 2.0 file?
  15. Apr 19, 2020 at 11:02 AM
    OVTune
    OVTune
    Okay for future reference for everyone, when you reset AT and LV, it will run a little rough but never this rough.
    If anyone has rough issues like that, stop, and flash back to stock / other file and contact us
  16. Apr 19, 2020 at 11:04 AM
    Shellshock
    Iowa
    It takes 30 seconds to flash. He took down the old files and posted new ones..
    just flash the new one lol
  17. Apr 19, 2020 at 11:15 AM
    SandyTaco4x4
    Southern CA
    Lol don't you have to drive around for like 30 miles for the tune to settle? I already did that, don't make me put shoes on again :rofl:
  18. Apr 19, 2020 at 11:16 AM
    OVTune
    OVTune
    Shouldn't be an issue on the 87s, they use different base values
    SandyTaco4x4 likes this.
  19. Apr 19, 2020 at 11:27 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I did not have any idle issues. 87 base. Purrs and smooth.
    Edit. Flashed on cold, did not reset lv's
  20. Apr 19, 2020 at 11:30 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Got 87 base flashed and it had a slight stumble on the first fire up, but the engine was completely cold. It's idling now, and I'll take it out once it's idled for about 10mins or so (you do still have to let it idle for a few mins after flashing, right?)
Thread Status:
