Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. Apr 26, 2020 at 5:41 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    I understand that it’s all in the test tune. Try it out for yourself. Enjoy.
  2. Apr 26, 2020 at 5:42 PM
    jrdills
    jrdills Well-Known Member
    please, please Move far far away to an isolated island, It would make this forum so much better.
  3. Apr 26, 2020 at 5:46 PM
    dwillhere1
    dwillhere1 Well-Known Member
    Dan
    Surprise, AZ
    2017 TRD OFFROAD
    Thanks man! I appreciate your help
    wiljayhi[QUOTED] likes this.
  4. Apr 26, 2020 at 5:48 PM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    @OVTune
    Can we get a pool together to give the expert a refund so you can rid yourself of his nonsense once and for all?
  5. Apr 26, 2020 at 5:54 PM
    Saeros
    Saeros #dealermole
    Canada, Eh!
    2022 Venza Limited
    I'm in
    AgedFlatulence, svermilyea and perkj like this.
  6. Apr 26, 2020 at 5:59 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Not necessary. I am certain I have offered one in the past which he refused.
    Regardless, occasionally he has provided something useful. If he left his opinion out, it would be 10x as useful.
    ownubad, dingel5, honey and 8 others like this.
  7. Apr 26, 2020 at 6:11 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Sure, here is my clarification.
    You said that under DI injection is easy for you to maintain stoichiometric ratio and DI behifits the truck.
    Well, you did go that route, but inadvertently change the injection mode, cutting PI+DI mode off after the coolant reaches 200°. Pretty much radically altering the engine ops design.
    Whatever vision you had about controlling afr,etc., it failed you to see the whole picture, hence "getto" tuning.
    Otherwise you would see startup issues before release and your statement on PI+DI usage contradicts the data.
    Scralatchtica824 likes this.
  8. Apr 26, 2020 at 6:16 PM
    Vlady
    Issy, WA
    BS right there about refund. I already stated I'm not desperate...
  9. Apr 26, 2020 at 6:24 PM
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    No one cares
  10. Apr 26, 2020 at 6:26 PM
    siKjiTz
    siKjiTz Well-Known Member
    E
    Oahu, HI
    2017 DCSB TRD Sport Inferno
    TUNED 2.0 Beta 87 Eibach Pro Truck Lift Kit Stage 1 Wheelers 1.5” Progressive AAL Level 8 MK6 17x8 Falken Wildpeaks 265/70/17” Redline Tuning Hood struts Matt Gecko LED Bed lights OEM Roof racks GoRhino RB20 Running boards A/C drain Mod Kicker speaker upgrade w/kicker key amp. MESO Stage 1 Tail light upgrade OEM Bed Mat
    yes this is what I’ve experienced. Yes I did extend wires on the wiring harness.
  11. Apr 26, 2020 at 6:27 PM
    OVTune
    OVTune
    I tested this on our dev truck a long time ago, its right here in this thread. I did not run into this problem or I wouldn't have released it for further testing.
    Toyotas OEM fuel design is terrible considering the year it was released, and a a huge change to the logic was required to actually make the engine run more efficiently.
    Don;t believe me? take a few years and study the logic and design of current model calibrations of different manufacturers, read the patents.
    Then study Toyotas.
    They use a fuel logic design that is 13+ years behind other manufacturers fuel control logic.
    What does that do? that makes the fuel control much less refined.
    It is actually 1 step ahead of old narrow band design.
    Which I bet you dont know what that is, but its 1990s level design.
    Nissan for example produced a better fuel control in 2007 than this truck has in 2020. A few bugs can be expected during testing, which is why I released it to test.
    Mazda,a tiny company in comparison had full closed loop control 10 years ago.
    Toyota still does not have this. The front 02 sensors are not even accurate at richer AFR, that's how far behind the tech is.
    Also, if you think radically changing fuel control on tuning D4S systems is getto, dont look up about tuning FRS/BRZ.
    Never called you desperate, but I do recall offering it more than a year ago.
    stokesrm, Rainoffire, ownubad and 7 others like this.
  12. Apr 26, 2020 at 6:32 PM
    SpeySquatch
    2016 TRD OR DCSB
    Rainoffire, thedriza, ownubad and 3 others like this.
  13. Apr 26, 2020 at 6:41 PM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    Why keep addressing it?
  14. Apr 26, 2020 at 6:41 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Maybe a bad to time to interject, but...
    Anyone get their P5F registries today?
    Skydvrr likes this.
  15. Apr 26, 2020 at 6:44 PM
    lapoltba
    CT - 06076
    This....
    I specifically did not address "it" directly. This is one of the things in life that will go away if you just ignore it, literally by clicking on "ignore". Best forum function ever.
  16. Apr 26, 2020 at 6:47 PM
    Turd Hawg
    i agree, when I’m trolling there’s nothing more deflating than someone ignoring me...lol
  17. Apr 26, 2020 at 6:53 PM
    jrdills
    Vlady has already admitted he’s not a tuner in an earlier post so he has 0% validity in anything he says, he’s trying to sound technical cause he clicks some buttons in techstream. Like everyone says just ignore him cause he has no experience in tuning. Problem solved.
    rdpoe likes this.
  18. Apr 26, 2020 at 6:56 PM
    Doogle
    Doogle Well-Known Member
    Jonathan
    2017 Black Tacoma Dbl Cab
    Divac....
    TFly and Phich like this.
  19. Apr 26, 2020 at 6:57 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    :rofl::rofl:
    Doogle[QUOTED] likes this.
  20. Apr 26, 2020 at 7:01 PM
    Doogle
    Jonathan
    Vla Di Da Di, we likes to party
    We don't cause trouble, we don't bother nobody
    perkj, VB25, honey and 3 others like this.
Thread Status:
