Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 17, 2020 at 1:09 PM
    Ron1965
    Ron1965 Go Bruins.......
    Ron
    Socal
    2018 Cement TRD ORSB PREMIUM/TECH
    OVtune Mooseditty Custom;DD Exhaust;Nitro 5.29’s;SCS Brushed Copper;AFe Custom CAI
    FM should be 1.30.Go to page one and get link for correct FM. Be sure you delete old one
  2. May 17, 2020 at 1:12 PM
    thrust
    thrust Member
    2017 MGM DCSB TRD OR
    Same. Everything grayed out.
  3. May 17, 2020 at 1:16 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Like the others said, about a month ago he made the requirement. The upside for you, is when you send in your dongle you get the new vFtuner software for free. Go to ovtuned website, in the homepage scroll down a little for the link.
    Shellshock likes this.
  4. May 17, 2020 at 1:24 PM
    oly51
    oly51 Well-Known Member
    Gary
    S.E. MA
    2017 Tacoma, TRD Sport, MGM
    I cleared DTC by mistake. What is DTC?
  5. May 17, 2020 at 1:25 PM
    pkang0915
    pkang0915 Well-Known Member
    Bay Area, California
    2017 Tacoma DCLB OR (first time Taco owner)
    TOYTEC 2.5 kit, SPC UCA, N-fab side steps, TRD pro grille, FN FX PRO Wheels, BFG KO2S (265/70/17 C Rated), TRD Skid plate, Tyger Tonnue Cover, OVtune, Borla S type exhaust
    Just flashed and went for a 20 mile drive. Drives great! Did have a slight hesitation when starting and a slightly rough warm up but that's expected when clearing AT & LV. Will report back after a few h uh bdred miles.
    Flashed stock 91 tune for 31-33 inch tires
  6. May 17, 2020 at 1:26 PM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    I missed the part where we had to revert back. Is it neccesary?
  7. May 17, 2020 at 1:26 PM
    Loaded NightraiN
    Loaded NightraiN Well-Known Member
    17 TRD Off Road
    Same issue with new FM. hmmmmm
  8. May 17, 2020 at 1:31 PM
    Ron1965
    Ron
    Socal
    Try right clicking the FM icon and run as administrator
    Did you load the tactic drivers? If not look under tuning dropdown in FM and do so
  9. May 17, 2020 at 1:33 PM
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    Diagnostic Trouble Code. You’ll be fine.
    oly51[QUOTED] and Skydvrr like this.
  10. May 17, 2020 at 1:34 PM
    Neutron
    Neutron Well-Known Member
    East Tennesse
    2016 Tacoma TRD OR, black, 4x4
    Redline hood struts A/C drain hose Rear Diff vent Pop & Lock Hella Sharp Tones RAV4 mirror Clazzio seat covers HomeLink mirror Cargo bed lights (mattgecko) Puddle Lights ShiftSense Pro TRD Pro grille LEDs throughout Many minor mod$$- Thanks TW!
    @OVTune
    I have to ask- this is not the real final version, right? You’re releasing tunes in careful stages until the the final, final version with mode (mood?) switching to base, performance, etc.? At any rate, thanks for the excellent product. It just gets better and better.
  11. May 17, 2020 at 1:51 PM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    From what I understand this is the final release for 04B04 if no additional issues are reported and then released for the other ECUs. And I don't believe there is base or performance. Just octane and tire size.
    In normal operation its the base tune. With ETC enabled it will run the performance tune. And S is now gear lock and works great. S + ETC should be tow mode meaning Atkinson cancel full Otto cycle. And can keep it in S4 to keep it out of overdrive.
    wiljayhi and Skydvrr like this.
  12. May 17, 2020 at 1:51 PM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Just loaded Updated 2.0 91 31-33. No issues with software or Flashing the tune. Have a 60+ mile drive home through the mountains shortly and my 60ish mile commute tomorrow. Excited, start up was smoother even after resetting LV and AT.
  13. May 17, 2020 at 1:52 PM
    thrust
    thrust Member
    Yea tried running as admin and loading/reloading the drivers. No deal.
    Loaded NightraiN likes this.
  14. May 17, 2020 at 1:58 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Sounds like we need to ask @OVTune what the schedule/plan is as well as what is what
  15. May 17, 2020 at 2:04 PM
    crunchytaco13
    crunchytaco13 Well-Known Member
    ‘17 PRO MT Cement
    TRD CAT
    You mean you reset the values after the car was above 176, not flash after the car was above 176, right?
  16. May 17, 2020 at 2:07 PM
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    I wouldnt worry about this. Its been discussed many times in this thread. Just flash the truck, click reset LV/AT, idle for 10 min and you are good. Your truck will learn and set trims and all. This is why he asked for testers to drive 100 miles before reporting feedback
    Bagow and SpeySquatch like this.
  17. May 17, 2020 at 2:08 PM
    sig916
    sig916 Well-Known Member
    Why am I grayed out on p5flash utility?
    p5flash update.
    Tactrix drivers downloaded.
    OBDll cable insert.
    Truck is on.
  18. May 17, 2020 at 2:10 PM
    Sierra Nevada
    KDMAX Tooooned
    The following method is old school and maybe doesn’t make a difference, but I flash on a warm truck, then reset. I understand this way allows learning to occur sooner/faster.
  19. May 17, 2020 at 2:11 PM
    riz_atx
    Sohail
    Spicewood Texas
    This was one of the last times this was brought up. Do whatever you want, but its not required
  20. May 17, 2020 at 2:18 PM
    Sierra Nevada
    KDMAX Tooooned
    @JaTe and I are not saying it’s required. Only that there’s reason to believe it helps the truck learn faster as described. Mat said cold is ok, not that it’s better or preferred.
    JaTe likes this.
Thread Status:
