Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 17, 2020 at 5:22 PM
    SpeySquatch
    2016 TRD OR DCSB
    I’ve had good highway behavior. The power is different, but there. Cruising at 75mph with 4.88’s and true 32’s I was am getting almost 20mpg with my truck consistently which blew my mind considering it’s been 30 miles. I definitely am waiting a true 500-1000 miles before I critique. In the past that’s when the real “settling” and consistency seems to occur for me
  2. May 17, 2020 at 5:23 PM
    Kleach18
    Kleach18 Well-Known Member
    2016 TRD Offroad
    File downloaded: 04B04+2.0+Base+91+OL+31+-+33T.p5f
    Updated first thing this morning, drove over 100 miles running around today. Cold start it stumbles every time, warm start not as bad but still present.
    Other than that the truck drove great!
    panthro and Skydvrr like this.
  3. May 17, 2020 at 5:28 PM
    a.dev
    a.dev Member
    Bellingham, WA
    2017 Tacoma SR5 V6 4x4 Access
    Falken Wildpeak 265/75 16 OVTune Bilstein 5100 Softopper Clazzio seat covers TRD Pro grill Kicker Tweeters
    Mine stumbled on cold start 91 octane 31-33 base tune. I flashed to 87 31-33 and it didn't stumble (but the truck was at operating temp.). I'll check tomorrow morning.
    panthro and 2017TRDpro like this.
  4. May 17, 2020 at 5:32 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I’m on 87 the last two versions and it’s stumbling for me. I don’t think it’s a matter of octane.
    Skydvrr and 20tacoma17 like this.
  5. May 17, 2020 at 5:33 PM
    n6vmo
    n6vmo Well-Known Member
    Sahuarita, AZ
    2018 DCLB OR AT Super "Priviledged"
    Bilstein 6112, ICON UCAs, 5160, AAL, 265/75/16 Falken Wildpeaks
    :eek:
    blitzkrieg3002 and Mike O like this.
  6. May 17, 2020 at 5:34 PM
    InternationalHarvester
    InternationalHarvester VF Pro Licensed, KDMAX Authorized Vendor
    Sierra Nevada
    2017 TRD DC LB OR 4x4
    KDMAX Tooooned
    91 oct 31-33 tire size stock gear. Got the stubble start
  7. May 17, 2020 at 5:35 PM
    PhogDog
    PhogDog Well-Known Member
    20 MGM Sport
    install this https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads
    should resolve your issuue
    Apologies, I can't recall if it was the x86 or x64 version.
    Can someone confirm? Thanks
    Edit: I believe it is that first x86 one on that page. If that don't work try the 64 bit one, I don't think it would hurt to have both installed.
    panthro likes this.
  8. May 17, 2020 at 5:37 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    CHECK THE DATES PEOPLE. The dates help narrow down which tune is what.
  9. May 17, 2020 at 5:41 PM
    ben dover
    ben dover Well-Known Member
    San Francisco Bay Area
    2017 TRD Pro
    I just appended UPDATED to the end of my file name to ensure I didn’t lose track of the two.
    Skydvrr[QUOTED] likes this.
  10. May 17, 2020 at 5:43 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Yes, That's what I have.
    P5flash_V1.2.2 in \bin directory is the executable
    But I had to remove p5flash from the quarantine this morning. Got quarantine since last use.
  11. May 17, 2020 at 5:44 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Nice :thumbsup:
  12. May 17, 2020 at 5:56 PM
    jrdills
    jrdills Well-Known Member
    Question about octane learning. I know in the past matt said you should bring the rpm’s close to redline a couple of times to initiate the octane learning on the beta files. Is this still the case with these new 2.0 files or just normal driving will work?
  13. May 17, 2020 at 5:58 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Yes this is still required as there are rpm and load points for learning.
    Also the files will be pulled in a moment.
    panthro, Hank_Mille and ihatemytruck like this.
  14. May 17, 2020 at 6:04 PM
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    I agree with this. Why mess with start up. Only needed to fix throttle and shifting. Now this will probably delay the 2.0f another week or so.
    Tac0Tic0[QUOTED] likes this.
  15. May 17, 2020 at 6:05 PM
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    04B04+2.0+Base+91+OL.p5f
    Verified - I'm using the latest file posted today - I know my way around the file system.
    panthro, double_duez and Skydvrr like this.
  16. May 17, 2020 at 6:13 PM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    I haven’t noticed. I just went and started it 3 hours after it was last driven 60ish miles and no start issue. It’s 80+ degrees here today. I guess I’d just make sure those with the start issues flashed the latest releases. I put mine in a new folder when I noticed the names hadn’t changed before downloading them.
    SpeySquatch[QUOTED] likes this.
  17. May 17, 2020 at 6:14 PM
    hawaii_dave
    hawaii_dave Well-Known Member
    2017 trd pro
    Loaded the tunes you posted today 5/17/20 04B04+2.0+Base+87+OL+34-36+5.29.p5f
    Cleared learned values .
    Truck is a 2017 AT, 5.29 gears 35/12.50/17 tires
    Got a little start stumble ( extended crank ) not very bad .
    86 MPH wall still happening.
    Over 120 miles, Other then those 2 things Truck does great even got a little sideways when it up shifted in to 2nd gear on a full throttle launch ( yes road was a little wet)
  18. May 17, 2020 at 6:14 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    So it's another week. No big deal if it's another month if it's how Mat wants it to be. He obviously changed the startup for a reason.
    Shellshock likes this.
  19. May 17, 2020 at 6:30 PM
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
    There's something wrong with the links.
  20. May 17, 2020 at 6:31 PM
    ihatemytruck
    Dave
    Southern California
    He said he was gonna take them down.
    Shellshock and Skydvrr like this.
Thread Status:
