Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 21, 2020 at 6:30 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    today's the day lads. I feel it in my nuggets.
  2. May 21, 2020 at 6:40 AM
    Doogle
    Doogle Well-Known Member
    Jonathan
    2017 Black Tacoma Dbl Cab
    LTacoman, CG256, HolyReptar and 6 others like this.
  3. May 21, 2020 at 8:29 AM
    ownubad
    ownubad Well-Known Member
    Cory
    2017 Silver Sky OR
    Drop in AFE Pro Dry Filter Inchannel Vent Visors Bedlinered Rear bumper and plastic flares
    Wow. 7 pages later and none of it was useful. This forum just keeps adding up with more and more non related. First people having a at vs mt , than more vftuner talk and other non sense. Man yall take this crap to PM or something
  4. May 21, 2020 at 8:30 AM
    Hank Heel
    Hank Heel Well-Known Member
    WA
  5. May 21, 2020 at 8:33 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Do worms fart?
    Tac0Tic0 and dingel5 like this.
  6. May 21, 2020 at 8:55 AM
    Doogle
    Jonathan
  7. May 21, 2020 at 9:09 AM
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    i got a legitimate question- im on 265 75 16 now with the 31-33 tune. if i throw my 245 75s on for a trip, how much would it wack out the shift points? or should i just flash to the stock size tire version of the tune?
  8. May 21, 2020 at 9:14 AM
    Shellshock
    Iowa
    about 3.5%
    you can always try it and if you don't like it, flash to stock tire size.
    Skydvrr and tonered like this.
  9. May 21, 2020 at 9:26 AM
    wolfman00
    matt
    '16 dclb
    this is true. ill try it this weekend.
  10. May 21, 2020 at 11:40 AM
    BigBeej
    BigBeej Well-Known Member
    Bryan
    Vista, Ca
    I finally think I got the 1.05.1 installed. Dumb question time after the last few posts. I did the 1.05.1 stock tune. My truck is on kings with 33" tires. Should I be tuning it differently?
    Tac0Tic0 likes this.
  11. May 21, 2020 at 11:48 AM
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    FYI, version 1.05.1 is intended ONLY for those who experienced stuttering with 1.05. The stutter issue only affected a very small subset of trucks.
    If you did not install 1.05 and experience stutter problems, you should not use 1.05.1.
    Also, if you selected "stock" in the flash manager, you didn't actually download and install an aftermarket tune. Instead, all you did was re-flash the stock tune that was already on the truck from the factory.
    You need to download and flash either the 87, 91, or 93 octane versions of 1.05 -- and, of those, choose either the base, performance, or gear lock versions, specifically. Those are the actual aftermarket tunes.
  12. May 21, 2020 at 11:58 AM
    BigBeej
    Bryan
    Vista, Ca
    I believe I downloaded and flashed the 1.05.1 87 octane base. I thought the 1.05.1 was gfor people experiencing the low speed shudder on take off? I get the second or two of vibration shudder when I take off in my truck. 0-15mph.
  13. May 21, 2020 at 12:05 PM
    paleh0rse
    Raleigh, NC
    That's what I said -- 1.05.1 is for those who experienced the shudder/stutter on the regular 1.05.
    Your post made it sound like you went straight to 1.05.1 without first testing 1.05, and you also described what you flashed as the "stock tune."
    There is no version of 1.05 for different size tires. That concept/feature was only later introduced in the 2.0 beta versions.
    If you tested 1.05 first, experienced shudder/vibration, and really did install the 1.05.1 87 octane base, then you're fine. I was just making sure.
  14. May 21, 2020 at 12:09 PM
    BigBeej
    Bryan
    Vista, Ca
    Forgive my stupidity on this. I went straight to 1.05.1 base 87 tune. I had the shudder prior to ovtune.
  15. May 21, 2020 at 12:16 PM
    paleh0rse
    Raleigh, NC
    Ok, then you should probably go back and try 1.05 first. If the shudder persists after letting 1.05 settle in for 150+ miles, or so, then swap back to 1.05.1. You basically don't want the changes made in 1.05.1 if the shudder isn't there in 1.05. Make sense?
    Trust me, you're not the first to get confused about that. A lot of people have done the same.
    :cheers:
    Inferno__Taco likes this.
  16. May 21, 2020 at 12:18 PM
    BigBeej
    Bryan
    Vista, Ca
    Got it. Do I simply redo the instructions as if I have never tuned it before? Or do I need to do something else to wipe the other tune clean? Feel free to speak to me without filters. I'm a big boy and have thick skin. lol
    dubs66, double_duez and paleh0rse like this.
  17. May 21, 2020 at 12:31 PM
    paleh0rse
    Raleigh, NC
    Just re-flash it using the 1.05 87 base file using the same flash process you used for the other one. No need to do any other steps in between.
    You can always clear the learning values after flashing, but I personally don't think it's necessary when simply switching between 1.05 versions.
  18. May 21, 2020 at 12:35 PM
    BigBeej
    Bryan
    Vista, Ca
    I will give it a go when i get a minute. Thank you.
    paleh0rse likes this.
  19. May 21, 2020 at 2:08 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    So what’s your pick? AT or MT?
    What do you think about VF tuner?
    Did you know that many scientists believe it is a possibility that there are more dimensions than just ours but our dimension is ironically limited to only 3 dimensions?
  20. May 21, 2020 at 2:13 PM
    paleh0rse
    Raleigh, NC
    As I sit here watching the end of AO...
Thread Status:
