Tacoma - OVTUNE - VFTUNER - Update Info and Original Development
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Jun 9, 2017.
Thread Status:
Not open for further replies.
  1. May 22, 2020 at 6:38 AM
    c.morris89
    c.morris89 Well-Known Member
    Kingsport TN
    2021 PRO MGM 6MT
    A little
    @OVTune your in Abingdon?? I'm over in Kingsport. Who knew!
  2. May 22, 2020 at 6:47 AM
    Watkinseli91
    Watkinseli91 Well-Known Member
    Eli
    Greenville, SC
    2021 LR PRO
    Working down in Hampton! Ha
  3. May 22, 2020 at 7:03 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    wondering if the cold start issues are related to the bad fuel pumps, and the recall for them? appears some have this start problem, and some dont. Ski
  4. May 22, 2020 at 7:10 AM
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    Previous beta gave me the rough cold start. This newer one, i think mat took it down already, I dont get them anymore.
  5. May 22, 2020 at 7:23 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Nope. I'm not on the recall list and the issue was after the flash. Highly unlikely
    dubs66 likes this.
  6. May 22, 2020 at 7:25 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    mine did yesterday. Sounded like it was running on 5 cylinders for about 30seconds then it smoothed out.
    GPatriot[QUOTED] likes this.
  7. May 22, 2020 at 7:30 AM
    c170b
    c170b Active Member
    TRD SPORT
    EIBACH LEVEL KIT
    I Have 100 miles on mine 04B04+2.0+Base+93 Runs Great.. Never had cold start issues. mileages is up from 21 to 24. I'm happy the way it Preforms now. The way it should of allllllways been...
    e46_ema and Scott4032 like this.
  8. May 22, 2020 at 7:32 AM
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    What originally sparked this startup "issue" I believe was a hesitation or weird start while *cranking*. The weird idle for 30s after startup is normal. The stock tune does this.
  9. May 22, 2020 at 7:37 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I’ve had my truck 4.5 years and 95k miles, it’s never idled as rough as it did yesterday. I’m going to flash back to 1.05, until the next test tunes are released.
  10. May 22, 2020 at 7:51 AM
    wolfman00
    wolfman00 Well-Known Member
    matt
    Gambrills/Crofton MD
    '16 dclb
    sortof stock. 6112/5160, pro wheels and a tune.
    your truck basically stock?
  11. May 22, 2020 at 7:58 AM
    Shellshock
    Iowa
    Right after flashing? That’s not unusual, especially if you did resets.
    if it doesn’t smooth out, that’s a problem.
  12. May 22, 2020 at 8:08 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I’ve got approximately 60mi on the newest test tune. I’ve had to startup hesitation the last two test tunes, but haven’t had any idle problems until yesterday. I’ll try it again later today and see if it does it again.
  13. May 22, 2020 at 8:08 AM
    CementTaco89
    CementTaco89 Member
    19 taco
    04B30 deleted the learn values etc. uploaded 2.0 beta 87.... anyone notice the shifting is quite laggy? It wasn’t like that on my 1.05
  14. May 22, 2020 at 8:17 AM
    lapoltba
    CT - 06076
    Laggy as in RPMs too high, or laggy between gears? Higher shift points were "requested" because a large number of people did not like how quickly the truck got into the higher gears.
    Also, definitely get some miles on it before evaluating. It will change in the first 500-1000 miles.
    Skydvrr and Shellshock like this.
  15. May 22, 2020 at 8:23 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    :gossip: Not related.
    Skydvrr likes this.
  16. May 22, 2020 at 8:29 AM
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    Stock tune roars to life immediately and idles just fine. The Tacoma ECU is like a giant ball of yarn. Loosen one thread; another gets too tight.
  17. May 22, 2020 at 8:38 AM
    MacFly
    MacFly Well-Known Member
    2018 Cement Tacoma TRD Off Road AT
    OVTune, AT Habitat, Firestone RRs, ARB CKMA12 compressor
    Of course now I can't find the post, but I'm pretty sure Mat said that there are no startup specific tables, the truck uses all existing tables for startup. So, it sounds to me like he can only fix startup issues by tweaking the entire tune... Or I could have been hallucinating.:crazy:
    Skydvrr likes this.
  18. May 22, 2020 at 8:38 AM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Youve done this already? Or are planning to?
  19. May 22, 2020 at 8:38 AM
    Shellshock
    Iowa
    Correct. It’s all the same table.
    MacFly[QUOTED] likes this.
  20. May 22, 2020 at 8:39 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Nah, u right. No startup specific tables.
Thread Status:
